eurocharged turbo upgrade e63 2012 (picture inside)
#101
I dont remove the code yet ... i have to send the car at mercedes next week i have to repair my air suspention and vlock spring and looking for the check in same time ... cost money again no more warranty im supposed to make this this summer but the trbo upgrade take 8 month more so after this the tt upgrade cost me 17000 for two wheel ahah eurocharged 👌
#102
That started as an awesome build thread, and turned out quite baffling. Subscribed to see how it ends up. I know the M157 is a strong yet old engine. Too bad so many complications appeared.
Hopefully you'll put your car back on the road with full boost and all problems will be solved!
#103
#108
i dont push the car yet im waiting to have the new duck and when my tuner is ready i going to see if the tune is ok with obd2 reader and all ...after i change the air suspension pull the spring and drop the back tint the windows and put the car in storage because the winter is coming
#111
Update
Just installed the h&r spring
Just receive my new air suspention
Im supposed to go on the dyno i have few problem the guy installed the alpha boost cooling kit put the relay not on the good place and the fuse blow so i finish on a towing and i ship the car directly to mercedes dealer and my friend at mercedes put me the spring this morning and put the air shock tonmorow and ajust with his scanner the rear suspention to drop the back too if he dont snow next week i going finally to the dyno but my guy from turboshop tell me to install blowoff on the car to eliminate the backpressure in the turbo ... what do you think of this ? I see weistec just release a kit with diverter valve this week for that so i can make one custom kit for like 500$ what do you think?
The tow ride
The tow ride
#113
i think weistec dont make that for nothing ...he maybe have few problem with is turbo upgrade and finally make something to prevent turbo damage
http://weistec.com/anti-surge-valve-...stem-m157.html
a100steaksauce (11-18-2016)
#115
when my turbo blow the wheel unscrew and my guy at the turbo shop tell me the only time he see that is on a car dont hate blow off or dv ..with the stock turbo is ok but with turbo upgrade bigger wheel more pression maybe its very better to have something to eliminate all the backpressure...
#116
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Copied from MB training document
"With the speed of the shifts, and minimal drop in rpm it is not needed. they sill modulate the waste gate to adequately regulate the pressure"
#119
#120
