ride too hard and noisy
2014 e63 s 4matic sedan, 2010 m3 convertible
new to forum. 2014 e63 s 4matic sedan. crazy love the car and all it brings. just finding the ride too hard and a lot of road noise for anything but short rides. i have p-zero's. checked tire rack for better riding and quieter tires. many better than the p-zero's looking at conti dws06. not freely giving up performance but prepared to give up some for a more pleasant cruise... anyone with suggestions?
Received 2,076 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
tks for reply. recently had to replace defective front under wheel and tire package so bot second front. rears have plenty tread left.
It's ok to get softer quieter tires and unless you're tracking the car you won't notice a huge difference even with spirited driving
Also if your alignment is off it can be noisier
I don't find the ride too hard compared to other sporty sedans I've owned, but the road noise is surprisingly high. It's louder than my 2015 S4 and almost as loud as my 2009 M3, which both had stock 19" wheels as well. It unfortunately makes having the B&O (vs stock) pointless at freeway speeds.
2018 S560 and 2019 E450 Wagon.
Ya, I'd think about trying the Conti w06 tires you mentioned. That will be my next tire. Currently I have the Bridgestone Pole Positions which are a great performance tire but ride not so good and do generate some tire noise especially as they wear. I don't drive my car in New England anymore as where I live here the roads are so bad and the car does not like bad road surfaces. In Florida it's fine though. You don't have to worry about off the line traction as much as I do though as you have AWD and I have just RWD as mine is a 2012. I'm hoping when I switch to the Conti tires when the Bridgestones are worn out in about a year it does not hurt my off the line traction too much.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
1994 E500, 2012 e63
My p zeros were getting bald in the rear so I just put a new set of 19" Michelin AS3+ front and rear and I love em for daily usage. 2 weeks now. Mickey Thompson on order for my 18's for traction
So if you nail it off the line with the AS3's and traction off do they light up real bad? With my Pole Positions they will spin some but not real bad, it really seems to depend on the asphalt surface type. I'm thinking I might get a far better more quiet ride with the all seasons and they should wear a lot longer as the wear rating is double that of most summer only tires. The Pole positions need to be replaced about every year and a half, or 14K miles.
1994 E500, 2012 e63
If I nail it they will spin for sure! I don't think there is a 19" tire out there that will dead hook on the street. The amount of slip is acceptable tho considering all the other benefits. The car still goes forward pretty quickly. Keep in mind my car also had a EC tune.
The comfort setting is good but I find the sport setting to be a bit stiff for long drives. My tires are good and my commute is 100 miles long trip so I know good comfort. If you are running comfort and still find it too bumpy and noisy I'd have to say the culprit are your tires from seeing the picture above.
Stephen
Stephen
The more I think about it I dunno if the all seasons like the conti w06 or the michelin AS3's are gonna cut it with RWD, maybe AWD, but not RWD Cars, just too much power going to only 2 wheels. I'm probably best off keeping performance Summer tires on my 2012 AMG wagon. I may switch over to the Michelins Super Sports next time around. Probably shoulda gone with those from the start, would have had a better ride and hooked up just as good or better than with the Bridgestone Pole Positions I currently have. I've just had a real problem in getting the SS tires in the past, they always seem to be out of stock on my size for some reason.
