transmission service
Old Jul 10, 2016 | 08:26 PM
vdubpower's Avatar
i drive them all, fast and hard
for those of u who have hit the 40000 mile mark or so, have u gotten your transmission service.....is it just a standard, flush, fluid and filter?.....how much are u getting charged...
Old Jul 10, 2016 | 10:17 PM
2012 merc amg's Avatar
2018 S560
I had mine done about 1/2 year ago, as I remember it was around 500 bucks and the dealer. Not cheap but glad i got it done, these Transmissions live tough lives with all the torque these motors put out. There was a amazing change in the car when I got it back, they had to reflashed the module because now it downshifts a lot faster and just feels like it has a lot more pep to it, seems to upshift faster too and less of the jerky type of feeling. I shoulda asked what they did to it, but have not been back since.
Old Jul 11, 2016 | 01:08 AM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
400.00 here. Done by my local dealer. Also, had a loaner for a day and my car was returned washed and detailed.
Old Jul 11, 2016 | 02:08 AM
vdubpower's Avatar
yeah i should get it done now....that and front brakes....better start saving up $$
Old Jul 11, 2016 | 02:44 PM
jylee's Avatar
14 E350; 12 Camaro; 07 Range Rocer; 06 Dodge Ram
Transmission service is not hard to DIY, just messy. There are post to guide you. I think the $400 is a flush. Should be more if the filter is replaced.
Old Jul 11, 2016 | 03:37 PM
The 400.00 was for the fluid change and new filter.
Old Jul 11, 2016 | 04:39 PM
Brucealeg's Avatar
2014 E63 AMG S
Is this a service thats ok to take to an independent? I like using the dealer, but $400 for a flush?
Old Jul 11, 2016 | 06:01 PM
I think 400.00 is very reasonable. The same transmission service for my Genesis 4.6 with the ZF transmission is over 600.00. Its not a flush it is a drain and refill and new filter installed.
Old Jul 11, 2016 | 06:03 PM
PeterUbers's Avatar
How much cheaper can an Indy be?
Old Jul 11, 2016 | 09:03 PM
Brucealeg's Avatar
2014 E63 AMG S
I don't know, it's why I asked
Old Jul 11, 2016 | 09:45 PM
2018 S560
I was pretty happy with the trans service on mine even though it was expensive, I too got a loaner brand new E350 sedan and my car was washed and vacuumed out. The had to have done a software update on my car too as it drives so much better since the trans service.
Old Jul 11, 2016 | 11:02 PM
jylee's Avatar
The ZF transmission filter kit and ZF6 transmission oil is more than $300, due to the filter is intergraded into the transmission pan.
I would think Indy would charge the same rate, as the transmission does not have a filler tube. The tech has to use an over fill tube to drain out extra fluid. If you can't DIY, it is best to let the dealer to do the transmission service.
Old Jul 11, 2016 | 11:37 PM
Georgee6086's Avatar
1994 E500, 2012 e63
Does anybody know if they Re flash the module will it mess with the EC tune I have? I would love faster shifts and fresh fluid
Old Jul 11, 2016 | 11:42 PM
PeterUbers's Avatar
Re flashing the tcu shouldn't affect the ecu tune; but if there is an ecu update they apply then of course it will
Just tell them you don't want any ecu updates ... That won't sound suspicious
Old Jul 12, 2016 | 12:12 AM
1994 E500, 2012 e63
Do you think they would be able to determine if the tcu already has the updated software? And if it did would it be beneficial to Re flash again? I notice in my car it shifts violently into 4th at wot.
