Hit the dragway (several runs)
Old Jan 28, 2017 | 09:04 PM
  #101
Amg63-'s Avatar
CLS63 AMG
127 trap speeds are good, definitely should be getting better than 11.5 ET
did you try any runs without brake torque just to compare?
how exactly are you launching it?
you should be low 11 or high 10s
ive been wondering how much time may be lost with mash and go vs brake boost launch.
Old Jan 29, 2017 | 07:33 AM
  #102
Ralcbah's Avatar
2018 E63S
Tried runs using brake torque and RS. Didn't do mash and go this time. Best run was using Race start this time, but it did bog. I've found that if you launch the car using Race start and launch it as the rpms rise it won't bog near as much, but messed up on this run, and didn't catch it at right time.
Launching at around 2100 rpms, which may be a bit low. I'm either too low or the ECU freaks if I go much higher than that. Need to find that sweet spot.
Old Jan 29, 2017 | 07:42 AM
  #103
Mike450's Avatar
2015 gl450
127 is 10.7's with a 1.6 60' time.
That's a moving trap for your mods. Very nice.
Old Jan 29, 2017 | 10:41 AM
  #104
Ralcbah's Avatar
2018 E63S
Yes, sir. Happy with the trap speed; now need to get some seat time and get better. Also need to log some data...Proper device in car now and ready for next track day.
Old Jan 29, 2017 | 10:52 AM
  #105
Fairbird's Avatar
C300
not sure about that statement
Old Jan 29, 2017 | 11:26 AM
  #106
Amg63-'s Avatar
CLS63 AMG
if he could improve the launch we might even see a 128 in there.
I have the same tune and can confirm its got really aggressive power delivery.
i don't think it will ever hit 10.7. I think 10.9-11.0 is more likely on this tune. Still very good.
Old Jan 29, 2017 | 11:29 AM
  #107
Amg63-'s Avatar
CLS63 AMG
just try one pass without brake torque/RS , just ease into gas first then nail it. This helps eliminate some of the lag off the line. It's not fastest method but will be easier to do, and a starting point.
i think with this you will get low 11s
Old Jan 29, 2017 | 12:12 PM
  #108
Mike450's Avatar
2015 gl450
10.7/10.8 ...
Old Jan 29, 2017 | 12:13 PM
  #109
Fairbird's Avatar
C300
Close ...
I doubt this is stage 1 car .
Old Jan 29, 2017 | 12:20 PM
  #110
Ralcbah's Avatar
2018 E63S
Will give that a shot. Would be awesome to see something low 11s.
Old Jan 29, 2017 | 12:24 PM
  #111
Mike450's Avatar
2015 gl450
It's not, it's one of my cars that's not a MB, but my point was, if he can pull a 1.6, with a 127 trap, he'd be in the 10's.
His car is booking it on the back 1/8 and making some time. Tweak that 60' and he'll be there.
Old Jan 29, 2017 | 12:28 PM
  #112
Fairbird's Avatar
C300
not with stage 1 , not with benz . every car is different
Old Jan 29, 2017 | 12:31 PM
  #113
Mike450's Avatar
2015 gl450
Understood, that why I said "if" in that post... 1.8 to a 1.6. I'm not proposing he cut a 1.4 from a 1.8
Old Jan 29, 2017 | 12:47 PM
  #114
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Moving
Old Jan 29, 2017 | 03:27 PM
  #115
Amg63-'s Avatar
CLS63 AMG
the only problem is the torque limitations in first gear are preventing that 60ft from being as low as it needs to be for solid consistent 10s.
So so with this car because of the torque limits in first few gears you end up with a trap speed that is usually higher than what it should be for the ET it does...
definitely the absolutle most annoying thing about this car, I hate that it does this ****.
Old Jan 29, 2017 | 08:10 PM
  #116
Mike450's Avatar
2015 gl450
So I have been hearing. What tire type are you running?
Regardless, still a smoking fast Benz.
Old Jan 29, 2017 | 08:46 PM
  #117
Amg63-'s Avatar
CLS63 AMG
just the stock pzeros but I'm 4matic so I don't think tires will make much of a difference for the 14+ cars.
Old Feb 7, 2017 | 04:58 PM
  #118
Amg63-'s Avatar
CLS63 AMG
Still can't get below 11.5 ET, but with new tune getting consistent 127mph traps, compared to consistent 124mph traps (with one 126 trap). All with mix of 93 and 100 octane fuel.
Had new motor mounts and trans mounts installed, as mine were shot at 30K miles.
Still working on launching this thing to get my 60 ft down a bit. Haven't been able to find the sweet spot just yet.
There was a beautiful stock c63s sedan that ran 12.0x at 120. Was his first run in the car. Probably into 11s after he ran a couple of times.
I wonder what your trap speed is without the mix of 100 octane.
Does the EC tune give more power with that or is it tuned for max power on only 93 octane fuel?
Old Feb 7, 2017 | 09:09 PM
  #119
Ralcbah's Avatar
2018 E63S
If I attempted to answer that question, it would be pure speculation. When I sent my ECU in I noted I run 93 octane on street and 100 for track. Getting custom dyno tune Saturday; will report back then.
Old Feb 8, 2017 | 12:41 PM
  #120
ced357's Avatar
C63 BS, 2011 SLS, 2014 CLS63-S
You might have mentioned this, but what tires are you running? My 2014 CLS63 with renntech tune and new spark plugs ran 11.2 while running PSS. I threw on Toyo R888's for another run and dropped to 11.1. Maybe try a stickier tire?
Old Feb 8, 2017 | 01:28 PM
  #121
PeterUbers's Avatar
there is SOME wheel slip but unclear if it is significant in the measure of 60ft and 1/4 mile and ET
Old Feb 8, 2017 | 02:15 PM
  #122
Ralcbah's Avatar
2018 E63S
Running Pzeros presently. May try to find some stickier rubber when these are done, which I'm sure will be soon. Thx!
Old Feb 8, 2017 | 03:55 PM
  #123
Amg63-'s Avatar
CLS63 AMG
Will be interesting to see if your custom dyno tune will yield any more power than the stage 2 EC tune.
EC told me they only increased torque output between stg1 and stg 2 because turbos on stg1 already maxed out on horsepower (about 600-610whp without DPs). Now i do wonder if using 100 octane vs 93 on this tune will give a bit more power.
They said if i were to do a custom tune it likely wont make much more than the stg 2 as its already maxing the engine potential safely.
I think between custom tune and 100 octane you can squeeze more out.
Old Feb 8, 2017 | 03:56 PM
  #124
ced357's Avatar
Its definitely worth a shot as I did notice a difference with my AWD CLS63.
Old Feb 8, 2017 | 03:59 PM
  #125
Ralcbah's Avatar
2018 E63S
It will be interesting to see; agreed. My car has other mods as you know, which may provide a platform for more power to be made on my specific car via some real logging and minute changes. Either way, will be fun, and just getting car set up before installing the meth/water injection kit next week. May do some remote tuning changes after install of kit.
