Highest Mileage w212 e63?
Old Dec 5, 2016 | 11:33 PM
The1stWright's Avatar
2014 E63S
As most of you know, I've recently acquired a 2012 e63 with 51k miles and I'm in love so far! I plan to own this car for a long time as well as daily drive the car. The warranty I purchased covers the car for an additional 4 years or 100k miles.
What are are some of your experiences with the e63 bi-turbo in terms of reliablity? Also, what would you recommend having replaced before the warranty runs out?
Thanks in advance!
Old Dec 6, 2016 | 11:22 AM
kponti's Avatar
E63
Airmatic system and sensors will go out.....just don't know when but it will
Old Dec 6, 2016 | 11:49 AM
Amg63-'s Avatar
CLS63 AMG
Damn are you serious?
How will you know that the airmatic system has failed? any clear signs?
Is it expensive to replace it??
Old Dec 6, 2016 | 12:37 PM
2012 CCB E63's Avatar
2012 E63
Thanks in advance!
I've got 60k on mine (bought it with 48k last year).
The following has been replaced under CPO warranty
O2 sensor,
Developed a rough idle (already changed plugs) they diagnosed it to an oil leak which contaminated all 4 cam sensors and crank sensors
Otherwise its been a fun car.
Old Dec 6, 2016 | 01:43 PM
2014 E63S
Good to see they haven't had major issues!
I've been searching looking for failures with the 2012 e63 and I can't seem to find anything really scary which is a good sign. Can't even find turbo failures.
I'm just a natural worrier as I plan on driving the car for a long time.
Old Dec 6, 2016 | 01:45 PM
2014 E63S
Double post.
Old Dec 6, 2016 | 06:33 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
As for the airmatic, never neglect a W212 that continues to sit low on the rear. It might just be a simple shock replacement. If neglected, the airmatic system gets overworked and will fail shortly. Then you have two things to repair instead of one and that will cost ya big time.
Did you get factory warranty, which only goes up to 7 years max? If aftermarket, which one did you get?
Old Dec 6, 2016 | 07:39 PM
2014 E63S
Thanks I appreciate it seems not many have problems with the motor or transmission which is a good thing!
Airmatic only in the rear so I'll set aside $3000 for that.
As for the warranty its through GWC, and apparently it's worthless. But I don't officially take delivery of the car until Friday so that's going to be a bit of an issue
Old Dec 7, 2016 | 10:14 AM
PeterUbers's Avatar
already had in 17,000 miles, bought new:
- air intake tubes torn
- cps replaced- eco failed
- airmatic sensor failed and replaced
- whistling noise from grill fixed
- parktronic sensor replaced
- left belt buckle b pillar rattle fixed
- transmission software updated
https://mbworld.org/forums/w212-amg/...-replaced.html
Old Dec 7, 2016 | 12:18 PM
Amg63-'s Avatar
CLS63 AMG
so for airmatic it was only sensor that failed?
i wonder outside warranty how much airmatic would cost to repair in case I keep the car that long. Which I think I will do.
Either that hat or I'll need to look into a GOOD aftermarket warranty to go with.
Old Dec 7, 2016 | 01:07 PM
PeterUbers's Avatar
yep just sensor
i have Benz elw warranty 7/75k
Old Dec 7, 2016 | 02:41 PM
dinman's Avatar
Most of them
i know you were asking specifically about biturbo e63's, but i have a 2010 w212 with the 6.2. I'm currently at 125,600 miles. Before me taking ownership (102,000) it had the following done
Intake manifold gasket (60K)
Pano roof noise fixed (12K)
Spark Plugs (90K)
Wiring harness repaired (30K)
COMAND knob replaced (92K)
There are obviously many other things done in there but those are the major things
Now, since i have owned it
Voltage regulator on alternator ($117 part)
New battery ($275)
Serpentine belt came apart one morning. ($51)
Glove box dampner and light went out (fixed myself)
Just had the brake fluid changed, rear axle fluid changed, alignment done, and transmission service done around 120k miles.
Now, at 125k, later this week when i get some time to get it up on a lift, i'll be replacing both of the engine mounts, sway bar end links, and somehow my oil fill cap cracked, so i replaced that. Also while doing that i will change the engine oil, install new air filters, and pull the old power steering fluid out and put some fresh fluid in.
Overall it's been a fantastic car, i haven't had it even a year yet, and the 23,000 miles i've put on it have been great
Old Dec 7, 2016 | 03:58 PM
kponti's Avatar
E63
My whole airmatic system has been replaced twice since the car was new, 2012 with 42k miles currently
Old Dec 7, 2016 | 04:00 PM
kponti's Avatar
E63
Airmatic is responsible for the ride height, not shocks. If it's sitting low, it's already done for
Old Dec 7, 2016 | 04:32 PM
Amg63-'s Avatar
CLS63 AMG
How much wouldt a full airmatic system cost if say car is not in warranty anymore?
Old Dec 7, 2016 | 05:03 PM
otakki's Avatar
Please give more infos on this company, "GWC." I have never heard of it before.
Yes, most likely. Airmatic will get worked overtime and fail shortly after...at least that's what I have heard about an owner ignoring the low ride height, from SA at a dealership. I was there at the time for airmatic warning light--that turns out to be a prefuse box problem.
Isn't great now the new W213 E63 will have airmatic both front and rear?!...Hail to more problems and less reliability!
Old Dec 7, 2016 | 05:27 PM
Amg63-'s Avatar
CLS63 AMG
^ Cars seem to be getting uglier on the exterior, faster, and less reliable with every new model generation these days. So sad.
Old Dec 7, 2016 | 05:47 PM
1809's Avatar
2014 E63 AMG S
Dang Peter, how frustrated have you been with all this? Does it sour you on the car at all? I think I'd be hesitant to but another MB if the car I bought brand new had all these issues before 20,000 miles.
Old Dec 7, 2016 | 11:35 PM
Georgee6086's Avatar
1994 E500, 2012 e63
Blind spot assist sensors have been an issue for some including myself, I haven't fixed it yet. Also I notice that my parking brake does not want to release when it's cold outside. I use my left foot and pull the pedal back up while pulling the release handle at the same time, if that makes any sense to you. It only does this when it's cold outside and the car sits over night.
Old Dec 8, 2016 | 10:04 AM
2014 E63S
I've heard GWC is horrible they try to get out of warranty repairs at all times. How much would airmatic cost to replace out of pocket?
Old Dec 8, 2016 | 10:05 AM
2014 E63S
Called my local dealer seems I can buy fidelity platinum warranty for the car as well.
Old Dec 8, 2016 | 11:11 AM
Amg63-'s Avatar
CLS63 AMG
Yea how much would airmatic cost out of pocket to replace it?
anybody know this info?
Old Dec 8, 2016 | 11:31 AM
2014 E63S
Other than that, it's been reliable? How many miles?
Old Dec 8, 2016 | 12:40 PM
otakki's Avatar
That's the problem with lots of insurance companies out there: Take your money and reassure you at the front, then when something happens they drag their feet and point out some fine prints amidst an ocean of fine prints. Of course, that's how insurance companies make money, right?!
Old Dec 8, 2016 | 01:05 PM
Amg63-'s Avatar
CLS63 AMG
Yup they are all scammers and all use the same tricks as one another-fact!
