M157 E63 diy brake pad change
Old Jan 14, 2020 | 02:18 PM
  #76
EckFe1's Avatar
993 cab, 2014 E63 AMG 4matic T
Installed yellows, braking seems more linear but brake dust remains high, no matter what others say.
Old Jan 14, 2020 | 03:16 PM
  #77
10speed's Avatar
E63s
Originally Posted by Richbot
Thanks for this. Had not personally worked with this open-bridge Brembo 6pot before and I was being dumb and needed this to help me get it apart. The rears were cave-man simple.
Happily the rotors are all well abvoe service limits (last changed rotors and pads by previous owner at 21k, he must have had a lot of stop and go driving as I got another 12k out of these pads which were already pretty thin at 26.5k when I got the car. That brake job was his 2nd pad change in 21k miles! So, thankfully, I had to do was pads and sensors all around. Took a couple hours start to finish including cleanup.
Just so it's findable with a search in the future, here's what I found when I looked up the minimum service thickness (the point at which the dealer tech would signal the rotors need to be changed with the pads):
Front: 33.5mm
Rear: 24.5mm
Mine were 34.8-35.3 front, 25.0-25.25 rear, approx, with a rotor caliper
Nice the sensors don't need to be reset etc., much smarter than the BMW system which can freak out and refuse to reset via the dashboard after you trip a sensor, and the connector setup is nice too, much simpler design. I guess that's why the sensors are $5 instead of $25. Continue to be pleasantly surprised by how easy it is DIY on this thing. Shame more people haven't caught on.
The BMW is easy too,just use the icarly coder to retract the rear electronic brakes and clear any codes if needed, easy as 123 , That’s actually the 1 thing I don’t like is that mechanical ebrake seems so old that you have to push a lever with your foot , the new E63s went with the electronic e brake too
Old Jan 14, 2020 | 03:20 PM
  #78
Richbot's Avatar
'26 E53 | '08 E90M
lol BMW's way = 3 extra steps plus purchasing an app plus if you want CPO coverage you have to follow them on instagram
I know the drill - I had Carly back when it was still called BMWhat. Merc's serviceability has been a real surprise for me - i was not expecting it to be much easier for the routine stuff than many of my BMW's have been.
I was also not expecting it to be Certified Pre-Broken and need close to $3k in warranty work that should have been caught and fixed before sale within 6 months of buying the car CPO, but hey, tanstaafl, and it works now
Old Apr 4, 2020 | 08:32 PM
  #79
taelen112's Avatar
'14 AMG E63 w212
Sorry to add on to this thread, but didn't want to start a new one.
For the rear calipers, I can't seem to find a replacement hardware set (pins and tension plate). Anyone know the part #? The only one I found was centric 117.35058, but that's noted for rear ceramics, not iron.
Old Apr 4, 2020 | 09:54 PM
  #80
evilsaint's Avatar
'02 C32, '10 135i M-Sport, '10 E63, '17 GLE63S
Did a ton of searching and I couldn't find specific replacements (via Mercedes part #) for the rear calipers. Break out your wire brush, I suppose?
Old Apr 5, 2020 | 07:43 AM
  #81
taelen112's Avatar
'14 AMG E63 w212
Looks like wire brush it is. I'll probably order that part # i noted above, its only $10...and if its not right, oh well. Maybe someone else will come along with the answer!
Old Apr 6, 2020 | 04:29 AM
  #82
thabigo22's Avatar
2014 E63S
I am going to be doing my front pads soon and I believe I need to do my rotors as well, what is the acceptable measurement for the front rotors before they have to be changed out. I think I have a decent lip on them but I want to make sure as the front rotors are an easy $1k to replace. Also if doing the front rotors how much harder is it from just doing the pads? Is it pretty straight forward?
PS. Great write up OP
Old Dec 20, 2020 | 11:30 AM
  #83
MDNYTE's Avatar
E350
Great write up. This will come in handy when I change pads... any other pad suggestions from the group?
Old Dec 22, 2020 | 02:58 AM
  #84
SAMzE63s's Avatar
E63s
I got the hawk performance ceramic pads, love them. Way less dust than stock and great grip.
Old Dec 22, 2020 | 09:05 AM
  #85
Mojo20032004's Avatar
2014 E63S
Mine arrive today, il do a YouTube diy video so people can save some money on these ridiculous prices
Old Dec 27, 2020 | 08:00 PM
  #86
2014 E63S
Here's the diy video. 15-20min per side. Super simple and easy
Old Dec 28, 2020 | 10:15 AM
  #87
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
LOL R-Rated DIY brake video? I tried Save to playlist and Save to watch later and get this:
"This action is turned off for content made for kids"
Old Dec 28, 2020 | 10:55 AM
  #88
2014 E63S
Check again, I will edit it.. My apologies hehe
Old Dec 28, 2020 | 01:34 PM
  #89
E55 KEV's Avatar
Veteran: Air Force
Thanks. We don't want kids looking at dirty R-rated brake videos LOL!
Old Dec 28, 2020 | 01:38 PM
  #90
2014 E63S
We do want kids to learn how to replace their own brakes!
Old Nov 7, 2021 | 12:46 AM
  #91
san40's Avatar
2015 e63 wagon
Very useful thread, helped me change my front pads (together with RB rotors).
I used https://www.fcpeuro.com/products/brake-pad-silicone brake grease for pads and pins.
My pads https://racingbrake.com/pd1291-391 are without "weights" and have holes (not hooks) for the pins.. doesn't seem to make a difference.
I did not reuse thin metal shims that were on OEM pads per RB recommendation.
Removed some brake fluid to get it under MAX line, used a plastic syringe.
Old Oct 24, 2022 | 07:39 PM
  #92
Red Bull's Avatar
'06 SLK55, '14 E63S Estate
SEP22 Front brake job
Wanted to chime in, having just completed this job a few times in a short period. In late August, I installed new Brembo 2 piece rotors and (FCP supplied) Textar pads on the front axle prior to driving my '14 E63S Estate from Boston to LA. I drive rather aggressively, and had CO canyon driving and Lots of high speed transit in mind so I was skeptical of the FF heat rating on the Textars and their ability to handle the hard use.
Well, the verdict's in: the Textars did poorly. Completely worn down to the backing plates in 6k miles. And the dust was IMMENSE. So, I decided to go back to an OE "GG" rated pad. Come to find out, however, that the current pad being sold for my car at the dealership is a lower temp, FF pad (also less expensive). So, I dug up this part # for proper GG pads: 000 420 63 04. They are semi-metallic, and a bit more expensive but based upon my driving with these pads for a week now they are worth it for the decreased dust alone! Slightly improved bite, and they are perfectly quiet.
One last thing: don't forget to clean and lubricate the 'slides' inside the caliper that the pad contacts!
Old Oct 24, 2022 | 09:25 PM
  #93
vdubpower's Avatar
i drive them all, fast and hard
https://www.fcpeuro.com/products/mer...des-0054206620
i did these pads and the 2 piece rotors on my 2012 e63. I think the pads were labeled amg, and trw and textar. Was pretty funny. What sucks is that they are squeaking so bad on slow stopping. I dont think they are worn. Its been 15000 miles or so. I bed them in proper, Squeaking has only started a few 1000 miles ago. They still work fine
Old Oct 25, 2022 | 11:53 AM
  #94
SilverE5588's Avatar
'15 E63S,'21 LCI M5
Thanks for passing along that front pad # . Wonder if the same can be sourced for the rears . Just to confirm you don't have carbon ceramics correct ?
Old Jul 12, 2023 | 03:22 PM
  #95
san40's Avatar
2015 e63 wagon
Not sure where to check for "GG" but looks like its https://www.fcpeuro.com/products/mer...mer-0074207620
I will consider them when RB pads are due for replacement, they feel too noisy when cold and clunking when initially engaging (although this might not be about the pads).
I also learned that "lubing" the sliding surfaces is quite short lived with a few different greases, with heat and dust it eventually becomes a hardened dirty paste and might contribute to my clunking noises..
MB stealership charged me an hour to tell everything is fine and clunking is due to aftermarket disks and pads
