2014 E63s Wet Clutch Adaption and Driving Adaption Dealer service
After getting the car back i noticed the exhaust sound was different when you let off the gas, I turn the radio off to be sure... When you hit the paddle to up/down shift it does respond. Where as before it did but very slow. It is a totally different car in terms of shifting and the sound.
The leveling sensors I think was my fault. I had a chassis wash and then parked the car for like 2 weeks during the holidays. I then took it out and go the level error and did not notice any issues.. but now i know the ride was much stiffer like it was in S1 mode.
- is the jerking still there in stop and go traffic in S or S+ mode?
- is the mct clutch enagagement lag still there?
- how bad was your jerking issue to begin with?
thanks for the info and posting your work order
I am not sure if they also added ATF or changed it. When you get off the gas the exhaust sound is different ( can't explain)for a second or two.
I was in Toronto and roads like glass...gears 1-5 shift shift on the redline no issues.... I am so happy they made the change and I did it.. Now for my BMC installation.
also, from a complete stop when hitting the gas not using any kind of launch methods, does the car still have that little split second lag before going or does it launch instantly?
i think this is peters question about the lag from a stop
I rather foot brk the car and take the drive line slack up to not break anything. Plus to me foot breaking seem to be faster....
As soon as you take your foot off the break the car start to roll, before it would just sit like rock. The car actually roll at idle now.
I did about 1700 miles over Easter weekend with a trip to Toronto and no issues. 70-80 avg MPG was 23.7 When in TO I did a few merge into 407 401 hitting around 160 on those entrance ramp.
I am going to add my BMCs and sit back for now.. Even that EC sale on tuning have me thinking.. but I will remain stock for now...
occassionally on cold start the car would slowly retreat backwards while in comfort trans and in drive until I depressed the accelerator a bit but once the engine and mct a bit warm it was fine
sunil I really think you had an atypical problem with your mct and I'm glad you got it fixed, I'll check into the dealer adapting mine to get rid of the jerkiness I get occasionally if I jump on the gas too quickly while in S or S+ and slowly coming to a stop or a rolling stop
Looking at the service sheet I notice 1 ATF. Maybe it was also low on fluid and after warming up it would response faster.
I did a few 0- very high 3 digits pulls when I was in Toronto and all gears were right on.. no delay..shifts were on point.
I am loving this car all over again.
I am 100% stock and now I am going to install my BMC filters and fingers crossed no CEL.
when slowing down abruptly for a stop... before you come to 5 mph, jump back on the gas and accelerate ... does it jerk?
Why is it so difficult to accept reality? If the gears and clutch are not properly aligned IT WILL take longer to find the correct position. I think the translation is hunting for alignment. 2015 and early 2016 have common components and software, mid and late 16 have a few unique parts and software.
Nothing like proving negative...
You don't believe me? ask your dealer to do a Bit compare between the files and get back to me.
The car felt like a rock will not move unless you gave it some gas.
NOW I put it into drive she rolls reverse NO gas...
I am not speak of Turbo lag. I am talk about how long does it feel to have the gear engaged and not moving unless you gas it...
Anyone in NYC area we can meet up.
I know of a 15 63 in the area and I will reach out and swap cars and note difference. My paddle shift is way better that was the worst.
