2014 E550 36k misfiring turn out to be dead #6
Old Jun 15, 2017 | 12:29 PM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
It's a daily driver,babied...this is shocking at 36k.
Car just started shaking and CEL came on at a stop light.
Old Jun 15, 2017 | 12:53 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Dead as in broken parts or just no fuel/spark?
Old Jun 15, 2017 | 01:35 PM
PeterUbers's Avatar
M278??? That's very odd... those engines are strong
warranty?
Old Jun 16, 2017 | 09:51 AM
sunil517's Avatar
Low on compression #6
Turn of to be a valve guide issue. Was told excessive wear and will install new head. I request both heads replaced but that is a no go since the other has no damage.
I am not sure if its one valve or both intake or both exhaust that is damage. Car did not smoke or show any sign of guides going bad.I am not sure how a MB head is delivered with cams or not.Maybe the cam is the issue pushing the valve over off center...
Old Jun 16, 2017 | 03:03 PM
Silverp30wagon's Avatar
2012 E63S Wagon, 2005 E500
Stock or tuned? If tuned, who's tune? Shouldn't make a difference to the valve guide but still curious.
Old Jun 17, 2017 | 12:15 AM
sunil517's Avatar
Stock...Daily Driver...
not even filters...
Old Jun 17, 2017 | 01:19 PM
PeterUbers's Avatar
Well it's a good thing you didn't have a tune -- warranty baby
Old Jun 18, 2017 | 04:52 PM
Munich77's Avatar
Mine: 2014 E550 4matic; Hers: 2016 CLS 400 4matic
Make sure to keep us updated - I hope that it will work out for you.
Old Jun 20, 2017 | 01:14 PM
sunil517's Avatar
Peter I want a tune on this car so bad but YES. Wrty...
I might get the car back Friday. Head is being installed (2 days) and 1 day of driving and testing. Waiting to hear if it is just the loaded head or a full head with cams they are installing. I was hoping for new cams...
Old Jun 29, 2017 | 12:39 PM
sunil517's Avatar
All done but somthing interesting I noticed.
note started OIL was found in all 4 of the cam sensors electrical connectors.
I am now thinking if this is true that maybe this was the main reason for the misfiring. After repairs oil was noticed inside the harness of hall sensor harness. I ask if a compression test was done before removal of the head...they did not have that information. The did test compression after the fix. Do these heads come loaded. The sheet is showing a list of every part needed a head assembly, valves for 8 intake/ 8 exhaust.
Now if it was the leaking valve when would the car run good for a few miles after a restart, compression should still be low and a misfire should be detected. The car does have a new head on it or a really good cleaning job on the old one. but now I am thinking if true it could have been the cam sensor leaking. I am going to check of the 14 550 and 14 E63 share the same PN for cam sensors. I have coverage will 75k so I am not worried...
Old Jun 29, 2017 | 02:54 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I was reading about low speed pre-ignition earlier in the week. After MB tech posted about it on instagram.
