14 E63 S 1/4 Mile time with UDP Cold Air Boost Kit
Old Aug 27, 2017 | 06:48 PM
727E63AMG's Avatar
2014 E63 S, 2017 GLE 43, 2020 Cadilac Escalade, 2019 Lamborghini Performante
First I would like to say thank you to Shardul for sending me this Kit so quick. Thank you
And the second thank you goes to all the ppl on here that posted about the UDP Cold Air Kit and let me tell you it really works.
My previous best time at the same track (Firebirdraceway in Idaho) was 11.78 using race start and 93 octane. the weather was a little better that night around 63*
Last night I run 11.64 everything was the same except the UDP KIT and the weather was 74* so even with warmer weather I managed to get a better time do to the UDP KIT
I know most ppl are running faster times in their E63 S AMG's but this track is at 2650+ feet altitude...
Any tips on how to get my 60ft down ?
I tried brakeboosting and RS and RS seams to work best for me...any advice is appreciated
Thank you
Old Aug 27, 2017 | 07:28 PM
PeterUbers's Avatar
Thank you
https://youtu.be/b2Bn8AQeCBg
nice run!
best way to get better 60' is buy a different car.
Old Aug 28, 2017 | 02:53 AM
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
nice run!
Very well said !!!
Old Aug 28, 2017 | 08:08 AM
Ralcbah's Avatar
2018 E63S
Very, very good ET and trap for an almost stock ride. Nice to see the mod giving you a boost as well.
If the car is new to you, keep practicing. You can improve your 60 a small amount on the stock tune by learning at which rpm to brake boost to, and then when to release the break. It's not easy on this car, as the ECU freaks out if the throttle request is too high, while the car is not moving (brake engaged).
My experience is this....To see a major improvement in 60', you'll need an ECU config that allows more torque to be deployed in gears 1 and 2. Only then will you see consistent 1.6x-1.7x 60s.
Old Aug 28, 2017 | 09:01 AM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
Nice Run, my friends SL55 with tons of mods runs 11:6
Can you please share your list mods for us.
Old Aug 28, 2017 | 12:59 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Thank you
Thank you
Glad you like it
Old Aug 28, 2017 | 01:07 PM
Juice1979's Avatar
E550
What was your mph on each of the runs?
Old Aug 28, 2017 | 07:05 PM
727E63AMG's Avatar
Thx for the tip will play around with it to figure out the best rpm level for breakboosting.
All stock except the UDP Cold Air Boost Kit
I attached the time slips for 3 of the runs
The fastest run was done using race start...the 11.79 was breakboosting and the 11.99 was a mess up on my end..tried race start..but got too excited and instead of confirming with paddle up to start the race start..I hit the gas paddle so it took of slow..
Old Aug 29, 2017 | 03:20 AM
cocobeex's Avatar
Can tranny take that much torque in the gear 1 and 2 ?
Old Aug 29, 2017 | 07:30 AM
Ralcbah's Avatar
2018 E63S
I'm not qualified to answer this question in any meaningful manner, to be honest. I will say that after 20 days, transmission still works just fine, no slipping ,etc. Folks who've been running strong configs for a while would have to chime in. Surely the condition of the hardware will degrade more quickly, but how much so, no idea.
Old Aug 29, 2017 | 11:21 AM
PeterUbers's Avatar
the question is for how long can the mct take that torque increase before it fails
Old Aug 31, 2017 | 01:13 PM
Amg63-'s Avatar
CLS63 AMG
Are you saying theres now a way to decrease the torque limits in the lower gears?
Old Aug 31, 2017 | 01:32 PM
Ralcbah's Avatar
2018 E63S
Well, I'm not a tuner, so exactly what's done, I don't claim to know. I've bought lots of ecu tunes and run many more on the Dyno, but that's my only 'qualification'. I can say this...ecu tunes can be vastly different from one another, especially around low gear torque deployment. Is it working around torque limits, removing torque limits, decreasing torque limits? I don't know to be honest.
Old Aug 31, 2017 | 01:39 PM
e65's Avatar
e65
2014 E63 S model
did the cold air kit improve your trap speed
Old Aug 31, 2017 | 04:57 PM
727E63AMG's Avatar
It has not from what I can tell. I did run a 123mph first time I went to the track running 11.82...speed stayed in the 121-122.5 range
Old Sep 1, 2017 | 10:52 AM
Amg63-'s Avatar
CLS63 AMG
sounds like it lowered your trap speed?
Old Sep 1, 2017 | 11:05 AM
PeterUbers's Avatar
Not enough data to make a good conclusion on how the filters affected his trap; likely didn't do anything to it
