14 E63 AMG S 1/4 Mile time tune & down pipe
Old Oct 2, 2017 | 10:29 AM
727E63AMG's Avatar
2014 E63 S, 2017 GLE 43, 2020 Cadilac Escalade, 2019 Lamborghini Performante
Had my CKS down pipes and Eurocharged tune installed....car feels so much faster...acceleration is so much better and the sound is amazing. On Saturday I took the car to the track to see what I can run now...keep in mind my fastest ET was 11.649 at 122.93mph the track I go to is at 2700 ft altitude.
The times I ran on Saturday were 11.449 @126.28mph and 11.487 @120.6mph
I do have the UDP intake spacers with their filters and I did put 5 gallons of 110 octane into the tank and filled up the rest (15+gallons) with 91 octane..drove it around until there was a quarter left in the tank . The Eurocharged tune is made for 91 octane.
Hope that someone with more experience can explain the times to me...It just doesn't seam right that I ran almost same times with a trap speed difference of 6mph...I'm thinking the gas I put in is making it run unstable ? Maybe something else? Thx for your help
I'm attaching the time slips...
Old Oct 2, 2017 | 11:30 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
There’s not much to explain...well except that these cars just don’t respond like we were lead to believe early on. That timeslip is on par for what most others are seeing, especially considering your d/a.
Old Oct 2, 2017 | 08:17 PM
b0kix's Avatar
126 mph sound right , full downpipes?
Old Oct 2, 2017 | 09:32 PM
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
It was probably pulling timing up top. You were tracking fairly close through the 1/8 mile with the second run being slightly ahead but down only .76mph on the 1/8 mile trap. So you lost nearly 5 mph on the back half of the run. Did it get more humid out?
Old Oct 2, 2017 | 11:18 PM
727E63AMG's Avatar
Yep...turbo back down pipes with mid-pipes
Old Oct 2, 2017 | 11:20 PM
PeterUbers's Avatar
Shoulda just ran with 91....
Old Oct 2, 2017 | 11:21 PM
727E63AMG's Avatar
Weather was the same...just confused about the trap speed being so low on that slower run...
Old Oct 2, 2017 | 11:25 PM
PeterUbers's Avatar
Heat soak?
whats your corrected time with sea level
Old Oct 2, 2017 | 11:53 PM
727E63AMG's Avatar
Heat soak?
According to the sea level correction 11.261 @ 128.363 MPH
Old Oct 3, 2017 | 12:54 PM
PeterUbers's Avatar
11.2 is damn quick, nice job!! That’s what you’d be running by me in Chicago
Old Oct 3, 2017 | 02:31 PM
kponti's Avatar
E63
Why was there a 2 hour time between runs? Were there other runs? Were you in line the whole time?
Old Oct 3, 2017 | 03:37 PM
727E63AMG's Avatar
The place was packed...probably over 1000 cars at the track that night...they had a few classes....11.99 and quicker..12.99 and quicker and so on..so it took a while for me to run again...
Old Jun 10, 2019 | 12:37 PM
Hdaddy's Avatar
2016 E63S
I've always been told race gas (anything higher than 93 Octane) doesn't work well unless tuned, specifically. Also, you would need to drive around awhile (tank or more) to let the ECU adjust. Again, all of which I heard. This is an older post. Has the performance improved? I'm thinking of CKS down pipes. Also, did you have to purchase 02 sensor extenders?
Old Jun 10, 2019 | 07:35 PM
e65's Avatar
e65
2014 E63 S model
Log your intake air tenperature / IAT. Anything over 50 celcius and ECU will retard timing regardless of fuel octane.
Old Jun 11, 2019 | 01:59 AM
Ed99's Avatar
E63s AMG
I am assuming you have EC stage 2 tune with DP and I have seen consistent runs around 11.3 1/4 mile runs from some of the members here.
Old Jun 11, 2019 | 09:16 AM
kevy3's Avatar
2015 E63S, 2018 E63 EDITION 1, 2000 CIVIC SI EM1
That's because it needs a AMS Tune...… Eurocharged is all guestimates for actual hp and tq numbers.
Old Jun 11, 2019 | 09:50 AM
kponti's Avatar
E63
If OP even has the car still, I am sure he won't be taking advice on how to improve his times from 2017.
Old Jun 16, 2019 | 02:48 AM
727E63AMG's Avatar
I do have the same car lol...this is an old post I made. Where I live in Idaho the track is at 2700ft altitude and adjusted DA is never u der 3800ft altitude..especially now in the hot season..we see 4500+ DA.
I was able to get 11.2xx on the tune after I upgraded and reagapped the plugs...heat soak is a ***** up here so I added an ice tank and upgraded to pure turbo stg2...had the car back on the dyno at Eurocharged in Houston durring TX2K19 and was pushing 759whp and over 830whtq ....back at the track I ran a 10.97 with a ****ty 60ft of 1.89 do to all fours spinning..need to upgrade my tires they are pretty bad (on stock wheels) the 20inch rohanas I didnt race ..figured it would run slower since they are bigger...but DA adjusted time was 10.63..for whatever its worth.
Will be going back to the track soon with new tires 😁
Here is the link to the video I made at Eurocharged earlier this yr
Old Jun 16, 2019 | 02:06 PM
PeterUbers's Avatar
Damn son! I'm not even mad.... I'm impressed!!
Old Jun 17, 2019 | 03:14 AM
billvp218's Avatar
m157 SL63
https://youtu.be/ZsfvpEsQ0_k
The 759whp was on race gas, I assume ... what boost level? What was your 1/4 trap on the race gas run (DA adjusted)?
Old Jun 17, 2019 | 04:16 PM
e65's Avatar
e65
2014 E63 S model
probably low 130s for 1/4 mile.
Old Jun 19, 2019 | 08:53 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Nice times and with most our cars, they roll real fast but to much torque mgt to get the 60 foot times needed to get way into the 10s.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jun 19, 2019 | 11:59 AM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
Any issues with the pure turbos? Any transmission problems? Is trans built also? Curious about long term reliability
Old Jun 19, 2019 | 12:48 PM
MBHR's Avatar
E63 S-AMG
I maybe wrong here, but try leaving only five gallons of 93 and do a run. The weight reduction might improve your overall drag time. ...my two cents worth
