Buzzing/electrical noise from engine after shutdown
there is a tsb to correct an issue if it's running for longer than say 10 minutes
The noise is as mentioned, a fan or aux pump, and it's normal for them to run up to an hour after shutdown to control temperatures, anything you do to wake the car back up will reset that time on most things. Some are keyed to engine shutdown but things like the cooling for the lights is not.
