Jacking the car - airmatic - is there a way to "lock" it?
Old Jun 6, 2018 | 10:58 AM
FastWgn's Avatar
2016 E63 Wagon
Quick question , and I have done a search.
When jacking up other air suspension cars (Audi for ex) there is a setting that locks the air suspension to allow the work without the air suspension counteracting it.
For our cars - what to do? I found in my search that leaving a door open alleviates the outcome, but is there a way to prepare the car for jacking?
Thank you in advance.
Old Jun 6, 2018 | 06:44 PM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
Just jack it up. No settings to change or worry about on MB
Old Jun 6, 2018 | 09:35 PM
FastWgn's Avatar
2016 E63 Wagon
OK - thank you. I read about people having issues with the car being sunk down after swapping wheels, etc.
Appreciate the advice!
Old Jun 6, 2018 | 09:46 PM
ItalianJoe1's Avatar
2003 CL 600
In general, if a door or the hood/trunk is open, it won't adjust for risk of injury. There isn't a way to "disable" it like some cars have though, although supposedly, the control unit is smart enough to realize that the car is being jacked up and doesn't try to adjust. I often have a car running on the lift and when I put it back on the ground, it's fully collapsed. Never have them lifted unevenly though, only with all 4 wheels off the ground and the car still level (where the car still thinks it's on the ground I guess)
Old Jun 9, 2018 | 11:02 AM
jnolan's Avatar
‘17 Carrera GTS, ‘16 E63 Estate, 1965 Shelby Cobra and a few more
it will and within the first 100 feet of driving it post-swap, it will correct itself.
Old Jun 9, 2018 | 11:05 AM
jnolan's Avatar
Old Aug 16, 2019 | 01:21 PM
Der Panzer's Avatar
2008 W204 C300. 2015 X166 GL550
That't not what he needs, yes it will relevel when you drive it off, but the problem is when you service the car and jack up one corner, the car is trying to compensate and will sink all corners. When I change winter/summer wheels/tires on my GL550 X166 the car will be sitting at the lowest setting when I'm all done. Lower than normal highway setting, you cant see the tops of the tires.
That being said I just leave the hood cracked open, to prevent this releveling while you jack up the car
Old Aug 16, 2019 | 09:06 PM
Rehabguy's Avatar
E63S
I remember reading that leaving a door open would prevent this, but, if memory serves me well, that didn't do "jack sh..." for me (lget it? jack sh... ). I found that the longer you have the car jacked up on one corner... the lower the car's rear dropped. As I got speedier with my wheel swaps (ie using two jacks to lift front and rear of either side at once and doing both wheels {not advising anyone to do this}) the car's rear sank less. Also, in my experience, the car's rear would spring back up within moments after you start the car even if you don't drive it.
Old Jul 17, 2020 | 02:02 PM
sergtsil's Avatar
2010 e550
Airmatic lock to Jack up mercedes
Just disconnect the battery, it will hold air in system.
Old Jul 17, 2020 | 02:14 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Haven't jacked the E63s yet but I changed rear pads on the GLE63s. When lowering the rear squatted down below normal ride height and I couldn't get the jack out until I turned the car on and the rear raised back up.
