Replacing Rear Air Springs on W212 E63
Old Jun 20, 2018 | 10:06 PM
dn325ci's Avatar
None currently
I've learned "rear air springs" are apparently the proper designation in a W212 AMG for the air suspension or air struts or generically aimatic that we have. On Father's Day I completed a successful replacement of the frequently leaky OEM air springs with the Arnott A-2790 (right rear air spring) and the A-2791 (left rear air spring). After looking at them together, the Arnotts are frankly the higher quality product. At exactly $400 all-in (one cost me $208 on Amazon, the other $192 - weird), they are significantly less costly too. Easy job. 4.5 hours of my time, though I was pretty slow for two reasons that I outlined in the W212 E-Class DIY posting.
Since I didn't see a DIY for this project here in the AMG forum, I just wanted to let you know that this DIY linked below from the general W212 E-Class forum is just fine. I included my key learnings at the bottom of it.
DIY Replace Rear Air Springs
Don
Old Jun 20, 2018 | 10:49 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Now if we could just find a decently priced front shock for these!
Old Jun 21, 2018 | 08:18 AM
Celicasaur's Avatar
W212 - E63 AMG
So freakin true.
Over here the dealer quoted me £1000GBP....EACH!
Old Jun 21, 2018 | 08:58 AM
dn325ci's Avatar
None currently
Originally Posted by Celicasaur
So freakin true.
Oof.
Old Jun 21, 2018 | 09:48 AM
amgggg...'s Avatar
2012 E63 AMG Wagon
Holy sh*t...are there any good aftermarket options for this car?
Old Jun 21, 2018 | 09:51 AM
amgggg...'s Avatar
2012 E63 AMG Wagon
Apparently not
Old Jun 21, 2018 | 10:16 AM
amgggg...'s Avatar
2012 E63 AMG Wagon
At least you can get Brabus (appear to be Bilstein coilovers) for a grand apiece? Would prefer that over stock Monroes.
https://www.gmpperformance.com/index...ail&PID=208630
Old Jun 21, 2018 | 12:36 PM
dn325ci's Avatar
None currently
So freakin true.
BTW are you talking about air struts or the electronically damped shocks? W212 E63 of course does not have front air struts.
Old Jun 21, 2018 | 03:05 PM
chiromikey's Avatar
Currently the front shocks are dealer priced at over $1k usd EACH with no aftermarket alternatives. It’s an effing joke!
Old Jun 21, 2018 | 06:48 PM
dn325ci's Avatar
None currently
Shut the front door! That's ridiculous. For a monroe shock.
Old Jun 21, 2018 | 07:01 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
That's was a good DIY tutorial from the general W212 forum!
Old Jun 21, 2018 | 11:36 PM
stormhammer's Avatar
2017 Ford Mustang GT350
Godspeed/another company makes some... well, $1000 coilovers - so, YMMV on the long term on them.
CKS also makes a set, but it would behoove anyone to reach out to Evasive for clarification on fitment.
http://www.evasivemotorsports.com/mm...KS-CO-MERCEDES
Old Jun 22, 2018 | 08:54 AM
amgggg...'s Avatar
2012 E63 AMG Wagon
I interpreted it as $1000 per strut since it says "Each". But that's some sort of mistake. I checked the Brabus part number online and it's 8900 Euro: http://www.brabus.com/en/deliver.php?id=13804
If they forgot a zero in the price, then it would make more sense. Those are some nice-looking coilovers.
Old Jun 24, 2018 | 04:11 AM
FastWgn's Avatar
2016 E63 Wagon
Don
Thank you for sharing this! Very instructive DIY from the other forum, and good to know it works the same way on our cars. Since this is one of the parts that a certified pre-owned warranty doesn't cover, it's good to have these!
BTW - personally I'm delighted this is not an integrated solution, since the rebuilders (like Arnott), 90% of the time do not refresh the internal shock, or sub a switchable shock for a one position one (which makes sense for them). That means you may be fixing your air leak, but the normal hydraulic shock is worn out over time (as they all are). With this setup you at least have a chance to switch one without the other.
Old Jun 24, 2018 | 09:34 AM
amgggg...'s Avatar
2012 E63 AMG Wagon
Actually, CPO does cover the air shocks, just not the rest of the system. That said, I had both shocks (air bags), compressor, etc. replaced under CPO when my passenger side shock failed last year. See attached for comparison of what's covered by CPO (Star Certified Warranty) and ELW (Extended Limited Warranty) which came courtesy of my dealer. This is for Canada, not sure if US coverage differs.
File Type: pdf
Old Jun 24, 2018 | 01:26 PM
AMG Rick's Avatar
2012 MB E63 AMG
air spring
Don
Very well done thanks.
