Front drive shafts - do they break often on our cars?
Just got car back from service. When cleaning I saw that the drivers side CV joint cover was torn and the grease had escaped. Must have happened in the last 1500 miles since I know it was NOT torn at that time. Mileage is 45k now.
They replaced the boot only (2213300285)
(Picture courtesy of FCP Euro)
The passenger side was replaced at 32k miles, and then the entire axle was replaced (2213306400)
(Picture courtesy of RMEuropean)
That time the car was driven longer after boot leaked and hence got the classic CV "clicking" noise. So, in 45k miles BOTH CV joint boots have busted. Feels unusual? I have seen it in the past on other cars of course, but it usually happens later in life (more miles or higher age - older rubber), not on BOTH sides and in two years and 45k miles.
Anyone else have similar experience?
For those NOT under warranty - worth checking on the boots regularly, the driveshaft is $1,100 and up for the part alone. The boot is $70....
what about driving in winter with the salt and other corrosives?
If you do not catch it in time and the CV joint runs dry, you are right, you will hear a clicking noise when turning, esp when applying torque at some time (and no need to gun it - some torque is enough). Usually, by the time you can hear it, the CV joint is shot and you need to replace the joint which for MB means entire axle ($1,100+). Labor cost is about the same since you need to remove axle to replace the boot..
Following up on this.
Found yesterday that the inside boot on the driver's side is leaking a sliver right where it's attached to the inside axle (see arrow). Are you saying there is a boot kit for the inside as well? I have not been able to find that part in any diagram.
https://parts.mercedesbenzofwappinge...kit-2213300285
Get a copy of the EPC/WIS on eBay for about $8.50. Well worth it when you want to know a part number and don't feel like waiting for a reply or searching forever for that old thread that mentioned it.
https://www.ebay.com/itm/2019-Merced...d/123730293730
There's actually no boot kit for the outer joint. There is on the W211. But in Europe there is a boot kit for the other joint. In the US, they just make you buy the entire joint and boot which is a lot more than just the boot. But you can search and find the European one out there for sale on eBay.
The question was slightly different - and I already knew the part number (see the first post in this thread). I was trying to understand if there is also a boot kit for the INSIDE boot. The kit I (and you) describe) is for the OUTSIDE boot (CV joint).
The outer one is discontinued by MB but you can find that part number on eBay and Febi says theirs is compatible.
https://www.ebay.com/itm/New-Febi-Bi...B/273326657560
I've replaced a few ripped boots. Some of it is just the luck of the draw, and other mechanics tend to say the left tends to go first because it's shorter and tends to move more than the right so maybe just how much turning you do to eventually cause the boot to rip or whether there's road debris to cause a rip.
I'm starting to think the boot kit contains both?.....
