Valvebody issues?
Old 10-11-2018, 02:32 PM
timm206's Avatar
C63 W204 / E63S W212 / E63S W212
Valvebody issues?
Hi i have a 2016 E63 S with 15k miles that seems to be showing early symptoms of transmission issues. Such as rarely kicking with a loud clunk noise when downshifting, usually happens when driven a bit hard and the transmission is hot. More evident symptoms are holding gears for too long on comfort mode and theres a delay when shifting from D to R and vice versa. Im starting to think that it either needs a fluid change or has a faulty/contaminated valvebody. Anyone experience similar issues? Thanks
Old 10-11-2018, 07:30 PM
dav461's Avatar
GTR
that’s normal
Old 10-11-2018, 09:15 PM
Lumi's Avatar
E63 AMG S
is their any slipping or odd behavior at full throttle?
You can get a benz scanner, someting like carly app for benz and see if there any codes stored for the trans.
Doing a fluid and filter change isnt a bad idea and isnt that bad of a job either.
if you have a S with LSD, doing a rear diff fluid change while you are at it is good aswell.
Old 10-11-2018, 11:22 PM
timm206's Avatar
No slippage or odd behavior at full load, only during normal driving. The one that bothers me the most is when it holds the gears for too long. Feels like the car has 150k miles lol and yes thats the plan actually, to change the diff oil, transmission fluid/filter and engine oil.
Old 10-11-2018, 11:56 PM
aircommuter's Avatar
600sel, ml320, Dodge ram 3500 customized, Dodge ram 1996 v-10 to Diesel conversion
Clunking noises are typically outside the transmission, driveshaft joints mostly. Delayed shifting is computer controlled unless solenoid valves are sticking. The fluid change is the first place to start if you don’t know when it was done last. Scan for codes.
Old 10-12-2018, 12:51 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
First thing to do is disconnect the battery overnight and see how it drives after the adaptations have been reset. Many of those symptoms may be resolved.
Old 10-12-2018, 09:34 AM
timm206's Avatar
I've heard that if the selenoids get contaminated with clutch material, that can inhibit them from doing their job 100%. Im the second owner and i dont think the fluid was changed so far.
Old 10-12-2018, 09:36 AM
timm206's Avatar
I see thanks for the advice, I guess ill try that after i change the fluid and see how it drives. If that doesnt work either i guess ill have to drop it off at the dealer.
Old 10-12-2018, 09:46 AM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
have dlr perform adaption on the trans
https://mbworld.org/forums/w212-amg/...r-service.html
Fluid change can not hurt
Old 10-12-2018, 10:13 AM
timm206's Avatar
Originally Posted by sunil517
Thanks for the info, i will definitely try that route
Old 10-12-2018, 12:54 PM
Iron Sheik's Avatar
E 320
Had the exact same issue around 46,000 km or 28,000 miles. Had the loud/harsh clunk noise when it was downshifting from 4 to 3 and from 3 to 2 coming to a stop.
Took it to the dealer and they changed the solenoids.
Car is 2016 as well and now has 65,000 km or 40,000 miles =D
If you are planning on keeping the car, like I am, get the extended warranty.
Iron Sheik
Old 10-12-2018, 01:49 PM
timm206's Avatar
Iron Sheik
Did changing the solenoids fully resolve this issue?
Yea i want to keep this car for a little while thats why i got a 2yr cpo extension at the purchase.
Old 10-12-2018, 01:51 PM
Iron Sheik's Avatar
E 320
Did changing the selenoids fully resolve this issue?
Yes it did
They will replace the transmission fluid in the process as well.
Iron Sheik
Old 10-12-2018, 01:53 PM
timm206's Avatar
Yes it did
Iron Sheik
Ok thank you for the input
Old 10-12-2018, 01:55 PM
Iron Sheik's Avatar
E 320
You are welcome.
Iron Sheik
Old 10-12-2018, 06:55 PM
PeterUbers's Avatar
Received 2,076 Likes on 1,449 Posts
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
First reset the adaptations
https://www.mercedescla.org/forum/41-cla-maintenance-care-detailing/12396-how-reset-adaptation-7g-dct.html?t=12396&amp=1
Old 10-13-2018, 05:39 AM
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
I am not sure that method is 100% working.
Now, i own xentry system.
I can tell you, the adaptation reset is totally different by using xentry.
Also, you can use xentry to re-adapt.
It has upshift, downshift, and acceleration downshift adaptation program.
Old 10-13-2018, 03:59 PM
timm206's Avatar
Yes true adaptation like the one youd need after clutch packs is more complicated and requires Xentry.
But thank you all for the ideas, ive decided to first take it to the dealer and go from there. Will make further updates.
Old 12-03-2018, 03:13 PM
timm206's Avatar
Update #1
Visited the dealer and they performed an adaptations reset. Initially after the reset the car was shifting worse but the dealer said it would do that for the first little while. However after 200 miles the shifting has improved "less jerky" but the transmission is still holding the gears for too long. Planning on giving it some more time then go for round 2.
Old 12-03-2018, 08:49 PM
PeterUbers's Avatar
That's why you always do a tcu reset at home... this is such a waste of time and defers any real work for the dealer ...
Old 12-03-2018, 08:54 PM
timm206's Avatar
I believe true adaptations reset requires a Xentry. Plus there was a software update for the transmission, the car is more responsive now since its freshly adapting to my driving style and the new software. But youre right, gotta jump thru the hoops in order to get them really going.
Old 03-07-2019, 04:16 PM
timm206's Avatar
Update #2
I took the car to the dealer again and was told by the SA that i needed to drive 2k miles after the adaptations reset, and was told that only after that 2k mile window theyd be able to start looking deeper in to the issues, such as dropping the pan and checking out the selenoids. Ok 2000+ miles pass and i still have the exact same issues, take it back and the dealer still cant help me, they said everything is within spec on their computer and they cant do anything about it. Lol what?
Total waste of time and energy, time to switch dealers.
Old 03-07-2019, 09:10 PM
Lumi's Avatar
E63 AMG S
Update #2
Do you have a work order for the adaptions reset....
Have to be specific with Benz, its not an adaptations "reset" you want which xentry mentions this wont help shift quality but you want to "perform adaptation" and under this, you will perform adaptation for the Wet start up clutch, upshifts, downshifts and accelration downshifts. So you want all 4 to be done.. Adaptations performed on these, not to reset adaptions which is when a component is changed.
Going down the tree of things to do for MCT issues,
Fluid and filter change,
check trans mount
Software update
Full adaptations
If all else fails, time to clean the solenoids and or replace, which isnt much of a big job anyways.
Old 03-07-2019, 09:35 PM
timm206's Avatar
check trans mount
Software update
Full adaptations
First off the car is under full warranty, i dont think i have to tell them anything. All i have to do is explain the issues im facing.
Transmount is fine.
Software was updated to latest at the first visit.
By adaptation reset i meant they re adapted via xentry. Xentry>Adaptations>Adaptation of the gear shifts>upshifts 1-2, 2-3, 3-4, 4-5, 5-6, 6-7>downshifts and so on.
Then they said it will further adapt to MY driving style in the next 2000 miles, which it did and the trans did become more responsive to my driving habits. But it didnt fix the issues i was complaning about. I believe they need to replace the selenoids on the tcu which i mentioned to the dealer but it was ignored.
And for the transmission fluid change, dealer should do it out of their end. The car is still under factory warranty +3 years of cpo. So if thats one of the remedies then i dont see why i should pay for a premature trans fluid change.
Old 03-08-2019, 07:38 AM
Lumi's Avatar
E63 AMG S
Transmount is fine.
I cant stress this, I have been to war with my dealers around me for treating me like a fool and my car like trash in terms of quality of work.
These service advisors and techs dont see enough of these cars and issues to be very knowledgable with them, that is usually why they either shotgun the problem and throw parts at it, or consider it normal to get you out the door.
There are good techs out there, they are rare.
Trans fluid is to be changed at 4 yrs or 40K miles, whichever comes first..
Mercedes benz of manhattan, failed to change my brothers rear diff oil at the 2,000 mile break in interval when it was brought into service... they told me its the customers responsiblity to pay and ask for certain maintenance items to be done. Lol. There is no winning with them.
You seem to be on the right track for sure. I would say solenoids must be next as you mentioned for sure.
Quick Reply: Valvebody issues?
