New Battery Dead, Alternator Working
Old Dec 24, 2018 | 06:39 PM
Vrodman's Avatar
2015 E63s AMG, 2020 GLC 43 AMG
Hey guys,
This is weird. Dealer put in a new battery under warranty about 2 weeks ago. I have been noticing that it doesn’t start with the normal energy. A bit slow. Today in the garage I noticed that the radio would shut off without the engine running after only 5 seconds or so. Normally that happens after 15 minutes at least. So then when I went to start the car, it would barely turn over and not fire up. Then the hands on the servo controlled clock started spinning around. All typical of power loss, ie: dead battery. I put my trickle charger/starter on her for 5 minutes and she started.
After she started, I disconnected the charger and checked terminal voltage with my multi-meter. I was getting consistent 14.3 volts while at idle. I was getting 12.8 with engine off. This tells me the alternator is working. Soooooo. Hmmmmmm. WTH is going on here?
I am wondering if when you get a battery replaced under warranty, maybe it is not a brand new battery? Maybe some reconditioned battery? Because it sure seems like they replaced a bad battery with another bad battery.
Oh, btw, I popped the blower box off above the battery to make sure they did replace it. It looked new and had “12/18” round sticker on it.
Any guesses?
Old Dec 24, 2018 | 07:19 PM
PeterUbers's Avatar
Originally Posted by Vrodman
Hey guys,
Any guesses?
yes they use brand new batteries
likely if not a fluke bad battery, there is something overdrawing the current while the car is off ....
https://mbworld.org/forums/w212-amg/...-question.html
Old Dec 24, 2018 | 07:24 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
Let the battery sit overnight and then check the voltage without starting the motor.
On rare occasions new batteries are not good.
Old Dec 24, 2018 | 09:05 PM
Vrodman's Avatar
Thanks for both replies. I actually was thinking about a drain also and forgot to mention it. So I was thinking maybe my alpine sub amp wasnt shutting off. So I checked it and is working properly.
Another interesting coincidence is that these battery issues started after 2 significant events that it went to the dealer for both. Left rear body damage from getting rear ended where the radar sensors were replaced for lane assist, AAAAND, the brand new motor being installed. Perhaps something is not properly connected in the various harnesses. Seems unlikely. But sure is quite a coincidence.
Good idea to check base battery voltage after sitting for some time. I will do that tomorrow. Maybe a weak cell in it.
Thanks Again. Merry Xmas!
Old Dec 25, 2018 | 08:49 AM
thxrick's Avatar
BMW 335i, 2015 GTI
That's a bummer. I have had battery issues with my BMW. When the battery is dying the car starts to act "quirky" and shuts off certain options to keep the car running.
I would bring it back and let them solve it. Yet another trip to the dealer...uggh! GL and Merry Christmas!
Old Dec 25, 2018 | 02:25 PM
Vrodman's Avatar
Update
First, Merry Christmas to everyone!
Looks like the mystery is solved. After being on the charger yesterday for hours and the charger saying “charged”, the battery was dead this morning. Nothing was left on. The car wasnt even driven after being charged.
But the BIG tell was the battery voltage this morning. 10.7 volts! Looks a lot like a dead cell. Looks like I will be having MB bring me a new battery tomorrow.
Old Dec 25, 2018 | 02:29 PM
thxrick's Avatar
BMW 335i, 2015 GTI
Will they really bring you one? Install it too?
Old Dec 25, 2018 | 02:48 PM
PeterUbers's Avatar
yes, it's cheaper than towing it and it's covered under mbcare or whatever it is called
the other thought is charging this battery then disconnecting it from the car and seeing if it maintains the charge without any current draw from the e63
Old Dec 25, 2018 | 03:29 PM
Vrodman's Avatar
Your other thought is not exactly correct. Reason being that a battery should never read below 12 volts even when drained. This only happens when a cell is dead within the battery. Drained batteries will still read 12+ volts. Also, the car almost starts at only 10 volts. This suggests the other cells are charged.
Regarding remote install of the battery, they really do do it. They put a new battery in my 2011 about 4 years ago right in my garage.
Old Dec 25, 2018 | 04:25 PM
cetialpha5's Avatar
Not sure where you got the idea that a battery shouldn't be below 12. Here's a state of charge chart, with a 10% charge, it would be at 11.5 volts. The low battery warranty actually kicks in at 11 volts. Mine reads as low as 11.5 volts in the winter when it's 20 degrees outside. Remember that state of charge chart is the no load voltage when the temperature is 70. I had mine charged up to 12.7 at one point and once I connected it, it dropped down to 12.3.
https://modernsurvivalblog.com/alter...-charge-chart/
You could check to see if there's a parasitic draw by checking the current draw.
Old Dec 25, 2018 | 05:43 PM
Vrodman's Avatar
Negative terminal was disconnected. Therefore no load. With no load the batter was at 10.5/10,7 volts. From experience working as a mechanic many years ago putting myself through college, this is indicative of 1 bad cell within the battery. As I recall there are 6 cells within the battery casing. When this was seen, we ALWAYS replaced the battery.
I respect your experience and measurements. However, I have never seen a salvageable battery with no load reading in the 10+volt range. Also, this car and battery are in 60 degree weather here in N California.
Pretty confident here that the battery will be replaced tomorrow and be the end of it.
Old Dec 25, 2018 | 06:18 PM
cetialpha5's Avatar
Well that makes more sense. You didn't say it was disconnected in your earlier post.
Old Dec 26, 2018 | 06:21 PM
Vrodman's Avatar
So today, after all the great things MB has done for me, they dropped the ball pretty hard. Roadside service basically told me that no local dealerships offer roadside assistance any longer including my dealership that performed a battery swap 4 years ago in my garage. They said that I could call my SA and they sometimes will make exceptions and send out a tech, but that she cannot dispatch one. So I tried that but my SA is out this week for the holidays. I then tried to reach an alternate SA and failed to get anyone. Roadside said they could dispatch a tow truck to take my car to the dealer. Uh, no thanks. Might sit there until next week over a battery and my clear bra installation is happening tomorrow.
At this point I just went and bought a new battery and installed it in about 10 minutes. All is fine and working correctly now. The parts place actually told me they would take the battery back within 2 weeks if the dealer gives me a replacement. So thats actually better customer service than MB gave me today. I am trying to cut them somewhat of a break as the holidays do create logistic issues. Too bad cars don’t understand not to breakdown at Christmas. Lol
I did run one interesting test today. I connected my multi meter in series with one of the terminals disconnected in current measuring mode. I believe everything was off, and yet I was seeing a 7.5 amp draw. Hmmm. Thats apx 90 watts. That seems high to me. Maybe something was active though as not long before that I was trying to start the car without success. The old/new battery was shot for sure though as after an hour on the charger out of the car, it was still only giving 10.5 volts.
Anybody know (as in not speculating) if a 7 amp draw is normal. Seems high to me.
Old Dec 26, 2018 | 10:10 PM
PeterUbers's Avatar
That doesn't seem normal
That's like running an upright vacuum constantly off your battery
I take it the car was quiet .. meaning no fans or airmatic working .. the electronics would never draw 7amps
Old Dec 27, 2018 | 08:33 AM
Savage212's Avatar
2014 E63 AMG wagon
Are these car ever quiet? Mine makes all kinds of noises if I even glance in it's general direction!
Old Dec 27, 2018 | 12:59 PM
Vrodman's Avatar
So the car was left alone in the garage for about15 hours before I started it this morning. I imagine that if the car actually had a constant 7 amp draw for 15 hours it would either not start or barely start. But, it started right up quite strong. I believe something was running somewhere when did my current draw test. For batteries, it really comes down to duty cycle (% of time under load). So a constant 7 amp draw would be a 100% duty cycle at 7 amps. My guess, as we all know how active various systems are on these cars even while parked, is that the 7 amp draw stopped after things settled down.
I just cant believe it would have started so strong this morning otherwise.
As a side note: She was successfully delivered to the tint shop for Suntek clear bra and front door window tinting this morning! Picking her up in about 6 hours.
Old Dec 27, 2018 | 01:44 PM
taphil's Avatar
2024 GLE63s, 2021 E63s, 2018 GLC43
Mine is quiet when I haven't used it for a week and the battery drops to about 12.15-12.2V. Before that, it makes noises as though it's waking up and getting ready to run just when I open the door from the house to the garage and the garage lights turn on. Literally it wakes from sleep when the lights turn on, there's a moaning as a relay turns on from the engine bay, and farts from the air suspension and compressor pump.
Old May 29, 2019 | 08:58 PM
vvrjrlaw's Avatar
1994 S420 RIP (2/8/13), 06 CLS55, 02 ML55, 94 TT Supra, 89 Maserati 228, 911 Porsche Carerra
At “rest” the current draw should be no more than 1/2 amp (.5 amp). Mine was at 7.5 amps “resting”. Tracked it to the left sam unit. Until one comes in I just pull the related fuse at night and she’s fine in the morning.
Old May 29, 2019 | 09:56 PM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
The spec is .050 amps (50 milliamps) or less, not 1/2 amp
Old Jun 1, 2019 | 08:13 PM
vvrjrlaw's Avatar
Sorry, my bad.
