Methanol done the right way..
Old Feb 6, 2019 | 10:13 PM
b0kix's Avatar
Meth nozzle location
Meth nozzle location the right way.
Old Feb 6, 2019 | 10:58 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Seems about right...one more thing you have to pull the motor for. That and mounting in plastic and it’s not hard to understand why most of us went pre I/C and called it a day.
Old Feb 7, 2019 | 09:38 AM
Savage212's Avatar
2014 E63 AMG wagon
Yea that is the spot, is that before the IAT sensor as well? Do you think you would have to pull the motor to take off the intake? Looks doable with the engine in the car. What size jets?
Old Feb 7, 2019 | 05:11 PM
amgboy916's Avatar
2012 CLS 63
from the looks of it wouldnt injecting into the airbox provide similar benefits?
Old Feb 7, 2019 | 07:24 PM
hyperion667's Avatar
2012 CLS63
Old Feb 7, 2019 | 07:39 PM
b0kix's Avatar
dont have to pull the motor, is really pain in the *** if you do it in the car.
Old Feb 7, 2019 | 07:40 PM
b0kix's Avatar
i had it pre intercooler, but this will work way better.
Old Feb 7, 2019 | 07:45 PM
chiromikey's Avatar
It certainly should...
Old Feb 8, 2019 | 09:55 PM
e65's Avatar
e65
2014 E63 S model
2000cc/min post intercooler pre IAT sensor.
Old Feb 9, 2019 | 03:08 PM
FastWgn's Avatar
2016 E63 Wagon
Ignorant question - why is mounting in plastic an issue? Do the nozzles get hot?
(And I agree on pulling the motor to do this is, hmm, too much?)
Old Feb 9, 2019 | 05:01 PM
chiromikey's Avatar
It’s not that it can’t be done, it’s just that it will never be as secure as tapping into aluminum. And if you do screw up it’s not an easy fix...you’re most likely buying another extremely overpriced replacement. Other plastic parts (turbo cooling lines) are already failing on these cars so I’m just scared to even look at them wrong.
Old Feb 9, 2019 | 07:47 PM
e65's Avatar
e65
2014 E63 S model
Post intercooler pre IAT. If I was to go pre intercooler I would put those nozzles right into the turbo compressor housings. If I was to do it again I might do both pre and post. Let the intercooler take a holiday.
