"Hood Open" Warning at 60+mph
Old Feb 17, 2019 | 11:05 PM
Frank_Yang's Avatar
2015 E63
I recently replaced the AC Compressor at my friends shop. We have to take of the front pumper and electronic fan to be able to take out the old compressor and install the new one. It took us 4 hours. Nothing tricky. However, after we got the AC Compressor replaced, I got this wired "Hood Open" warning when I reach a speed of about 60mph. if I slow down to 40mph, it disappears. Anyone have any idea how to fix it? Reapply appreciated.
Old Feb 18, 2019 | 12:28 AM
PeterUbers's Avatar
The sensor is rising with the air speed at 60mph
can you tighten it down
Old Feb 18, 2019 | 11:19 AM
Frank_Yang's Avatar
2015 E63
that will be my last option. I am still trying to figure out why. I am jut so curious about the root cause.
Old Feb 18, 2019 | 03:11 PM
PeterUbers's Avatar
These can be faulty at times
Old Feb 18, 2019 | 03:18 PM
Ralcbah's Avatar
2018 E63S
Same issue on mine. Never had it fixed or addressed. Just had to open and close hood two times each time it was opened...sounds like Peter has the path forward.
Old Feb 18, 2019 | 03:51 PM
Frank_Yang's Avatar
2015 E63
wow ... that will be very annoying should I just replace both of the hood sensors? I just fund that even I do not have the driver side sensor connected, I do not get any warning message, until I am over 60mph. However, if I disconnect the sensor on the passenger side, I will get the hood open warning right after I starting moving at 2-3 mph. It seems like the one on the driver side is just been useless or not connect to the computer at all.
to my observation so far, it is the air pressure in the engine bay triggers the "Hood Open" warning message. I do not see any visible or noticeable hood movement at high speed. It was still at closed position at 60+ mph. The hood sensor should not be triggered by such a engine bay pressure increase. I could not put all the clue together. It is just so wired.
Old Feb 18, 2019 | 03:53 PM
Frank_Yang's Avatar
2015 E63
@Ralcbah , are you saying you have the same issue on you 2018 E63S ? It is still under warranty, right ?
Old Feb 18, 2019 | 04:26 PM
PeterUbers's Avatar
This may not be as easy as a sensor replacement with your latest description
Old Feb 18, 2019 | 04:27 PM
Ralcbah's Avatar
2018 E63S
Sorry bud.....no, not on my 2018....was on my 2014.
Old Feb 18, 2019 | 11:04 PM
Frank_Yang's Avatar
2015 E63
then what the issue would be ? Any idea? Appreciated
Old Feb 18, 2019 | 11:10 PM
Frank_Yang's Avatar
2015 E63
I have the same feeling, but I have no clue at all. Any idea? Appreciated!
Old Feb 19, 2019 | 11:39 AM
Vrodman's Avatar
2015 E63s AMG, 2020 GLC 43 AMG
I would recommend you re-trace your steps when you replaced the compressor. I suspect you inadvertently jarred the hood sensor a bit out of position. Way too coincidental that it came on after the compressor replacement job.
Old Feb 19, 2019 | 11:14 PM
Frank_Yang's Avatar
2015 E63
Thanks a lot to everyone's input!
The mysterious problem has been resolved mysteriously! My friend who operates a repair shop applied some penetration oil on both hood latches. After that, no warning message anymore. no explanation, what so ever! have a good night. Hopefully this can be helpful to anyone who has a similar issue.
Old Feb 20, 2019 | 09:40 AM
PeterUbers's Avatar
sometimes the e class Benz good seems closed and latched but only one side is latched and this is likely what was going on. This allows a little play in the hood and likely triggered the sensor. In your case the air flow at over 60mph lifted the culprit side and triggered the warming.
If you don't slam the hood down hard, it'll give a warning to me immediately that it's open, but you can also just press each side of the hood down and make sure it latches
glad it's fixed
Old Feb 21, 2019 | 01:34 PM
cperry's Avatar
E-63
By the way, left the dealership one day and had that come on in the rain and the wipers will be intermittent and stop until you get out and close the hood. It was a little scary with no wipers. I made it back to the dealership and they confirmed, hood warning, no wipers..........
Old Feb 21, 2019 | 02:12 PM
Vrodman's Avatar
Interesting. I'm guessing the edge of the hood near the windshield must interfere with the wiper mechanism if slightly open so the wipers get locked out. These Germans think of everything!
If not this, I have no idea why the wipers would get locked out due to the hood.
Old Feb 21, 2019 | 03:33 PM
Amg63-'s Avatar
CLS63 AMG
Theres actually a specific way you are supposed to close the hood. The owner manual has the instructions where it says to properly close it you are supposed to use decent force from a certain distance where you let it drop from there, i forget the exact details.
Old Feb 23, 2019 | 05:32 PM
Rehabguy's Avatar
E63S
Did a little search on youTube after reading your post. At first, I thought that letting the hood drop might not close it... I just felt like the struts are too tight to allow that to happen. I had been lowering it 'til the hook went past the safety rod (or whatever that metal piece is called) and then pushing down on the hood by the curves that outline the grille. But, I guess dropping it would work...
I will try this next time I got my hood open... minus the "push" he did at the end there
Old Feb 25, 2019 | 12:11 PM
Amg63-'s Avatar
CLS63 AMG
Yep, drop it with a bit of force, dont be afraid. This will ensure that it clips into the hood locks on both sides.
