Buy a wastegate?
Old May 10, 2019 | 04:03 PM
Bryan Book's Avatar
2014 E63S
Buy a wastegate?
2014 E63S throwing p0299 code and I'm thinking it's a waste gate or bad turbo. I have replaced a leaky transducer and smoked the car with 0 leaks. Cleaned airbox sensors. Running UPD intake and filters are like new. Car seems to be in permanent limp mode.
I dont know what else it could be. Is it possible to buy just the wastegate? I couldn't find a serial number. I believe I have to buy the whole turbo package. Hopefully hear back from service dept on Monday with some answers. No warranty and afraid this is going to be expensive.
Old May 10, 2019 | 11:56 PM
timm206's Avatar
C63 W204 / E63S W212 / E63S W212
Is the car tuned? M157’s have high back pressure from factory so the gasses would easily pass thru the wastegate if the actuator is bad. Seems like the actuator is replaceable but the real problem is finding one to buy. Dealer will most likely Try to replace the whole thing even if wastegate alone is the issue. Also on the stock turbos sometimes a crack forms around the wastegate, due to temps and back pressure.
Its most likely going to be an expensive fix since they have to drop the engine to acess the turbos, hopefully its something simple like a sensor. Good luck.
Old May 11, 2019 | 08:17 AM
Bryan Book's Avatar
2014 E63S
Thanks for your reply!
My car just hit 49,000 miles. The car has been tuned for the last 1000 miles. Stg 2 tune with colder plugs, still factory DP's and did a Res delete. When I turn the car on I can see both arms move, also when engine is being revved. I thought maybe they were getting stuck open or possibly needed adjusted? If a turbo is bad, I'll most likely just upgrade them to Weistec or pure. I've just been trying to prepare myself to know what I need to do when the time comes. Still hoping it is a more simple and less costly fix. I'm happy with my car the way it is.
Old May 13, 2019 | 04:46 PM
5soko's Avatar
AMG
Try flashing back to stock and see what happens.
Old May 13, 2019 | 07:15 PM
Bryan Book's Avatar
2014 E63S
Cars at the shop right now. I know that was mentioned but I figured if the car didnt like the new tune, it would of threw CEL alot sooner. I should hear back from them tomorrow and make sure I update. I feel like alot of threads with the code no one follows up with what the problem was.
Old May 15, 2019 | 11:49 PM
timm206's Avatar
Not sure about it going out of adjustment but at this point sounds like a bad presuure sensor or turbo. Also ive seen people get ramdom cel’s due to an old/weak batteries, not sure how likely that could be the cause but its a possibility.
Old May 16, 2019 | 01:34 AM
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
I would also try to flash it back to stock file. Or less aggressive tune.
Something cracked open caused by extreme boost ?
Old May 16, 2019 | 09:34 PM
Bryan Book's Avatar
2014 E63S
Small update. The shop that had my car wont touch it because it's tuned. I'm going to flash back to stock and take it to local Merc Dealership. Car is still in limp mode, no lights on the dash.
Old May 17, 2019 | 01:35 AM
cocobeex's Avatar
Yea, some shops dont want to be liable when car is tuned.
I had P0299 code twice. (Under Boost condition)
one time, my vacuum hose that goes into wastegate diaphragm is cracked...
So, i replaced it and problem solved.
2nd time, it was my wastegate actuator rod (Passenger side) loose. (Really had no idea how that happened.)
I adjusted and sync both turbo with 9.5 In/hg. Problem solved.
The more aggressive tune actually caused P0234 code. (Overboost issue)
Old May 18, 2019 | 06:40 AM
kponti's Avatar
E63
What he said^^^.
Dealer replaced the transducer and plugged hose back in on 3 separate occasions over the life of the car, no dice. Problem kept getting more and more frequent as the mileage piled on.
Wasn't till another tech changed out the hoses themselves with some >$20 vacuum hoses that my problem permanently went away.
Old May 19, 2019 | 01:50 PM
Bryan Book's Avatar
2014 E63S
Originally Posted by kponti
What he said^^^.
I already had the transducer replaced a few weeks ago , but I replaced the Vacuum lines and rubber connectors on both wategates. Im on day two of the car back to normal. I'm going to hold off on removing the tune and see what happens over the next couple days
Old May 21, 2019 | 04:54 PM
try m3's Avatar
Top Answer: 1
M3, E55, cls63
I personally wouldn't run a stage 2 tune with stock cats/downpipes.
