E63 S 4Matic M157 | Factory WIS Maintenance and repair documents
Mercedes-Benz Operating Fluids
Regards,
Joe
Can I have the instruction for rear differential fluid change please? If possible, I would like to know what kind of fluid and part numbers for the drain & fill plugs as well. Thank you so much.
WDDLJ7EB3DA079389
WDDLJ7EB3DA079389
The fill and drain plug part number is A3529970032. The other attachment is the MB gear oils spec. You're looking for the 235.61 spec for your 218.374 car. I used the Castrol as per the link below in my car.
Regards,
Joe
Regards,
Joe
Updated: Called MB dealer, provided them with VIN, they gave me Castrol Syntrax Limited Slip 85W-140. I am so confused.
Update: Called MB dealer, provided them with VIN, they gave me Castrol Syntrax Limited Slip 85W-140. I am so confused.
Hopefully someone can jump in with knowledge.
Regards,
Joe
I was gonna see if you could get me info to replace the rear main seal. I think dropping the transmission would be the easiest but not sure on all the specs. It’s probably a lot of info for everything 😬
it’s a 2014 E63 S
vin WDDHF7GB6EA881215
thank you!
it’s a 2014 E63 S
thank you!
Regards,
Joe
do you have the documents for replacing the front wheel bearing on 14 e63s?
WDDHF7GB1EA932152
tia
WDDHF7GB1EA932152
tia
Regards,
Joe
Regards,
Joe
Does anyone have WIS for the thermostat on m157 2013 ML63. Greatly appreciated.
QUOTE=Zerocarpileup;8693684]VIN # 4JGDA7EB0DA116960
Does anyone have WIS for the thermostat on m157 2013 ML63. Greatly appreciated.[/QUOTE]
In case you need the part number for the thermostat/housing assembly, it's A2782000615.
Regards,
Joe
Do You have documents/instructions for removal of the entire dashboard instrument panel ?
WDDHF9BB7EA886684
Best Regards,
Paul
WDDHF9BB7EA886684
Best Regards,
Paul
Regards,
Joe
