Eurocharged Stage 2 Flex Fuel Tune - full E85 tune
Definitely a steal for the power!
Man that is insane My dyno is set for next Tuesday, dragy will be here this week then the flash. But this Full E85 is really bunkers.
Nice man now drop some Mickey Thompson ET 2 street (bad *** drag radial) 30 psi heat them up and lay into it.
Nice numbers..
I'm very happy for you.
I'm glad to see others getting similar results to mine on stock hardware.
This helps validate the tune and eliminates a lot of the guesswork surrounding aftermarket mods. With all my previous testing, I was having a hard time justifying expensive aftermarket hardware to reap performance benefits. Your dyno plot helps solidify my feelings regarding aftermarket mods. If my business model was based on the sale of downpipes I'd be a little worried right now.
Now we get to look into the longevity of the tune, and only time will tell there.
Maybe this is the start of the second wave of tunes for these cars now that the field has matured.
Because the max torque has been moved further up the power band, the transmission seems to like it better. For my E50 tune I purposely asked Jerry to keep it under the 800 lb-ft threshold as that seems like the magic number. I have not detected any slipping with my tune. I can't speak to Jerry with his more aggressive tune.
Great ingenuity on your part for seeing this on a different approach. I'm still sticky with the E50 tune but my objective will be the TCU flash which should help propel this beast into the high 10's.
With all the logging I've been doing I struggle with what any more torque brings to the table... the TCU restricts the usable torque down low, so having extra on tap that you can't use seems a waste to me. Once the car is rolling, the upper band of the rpm range is used... and then we are only talking 30 or so more horsepower separation between the tunes, and where torque is much less a factor in acceleration.
The other reason I like the E50 versus full E85 tune is borne out of concern for longevity of the fueling system.
Because I'm running a blend, I get the benefits of the gas detergents and lubricants that are evident in the 93 octane gasoline. This will hopefully keep things lubricated. Those running straight E85 would be advised to run a bunch of 93 through the system occasionally.
Like you, my next step is a TCU tune to truly unlock the performance of these cars. Without that in place, then there will be a no reason, IMO, to look any further at the torque available with the more aggressive tunes.
Your horsepower made will be a condition of the octane rating of the fuel in the tank. You don't have to run ethanol to reap the benefits of the higher octane.
Just know that when running the E50 tune (aka Brutus Tune), you will be restricted to a maximum of E50 concentration in the tank. This restriction is because of the stock fueling limitations of the AMG hardware.
If you put a full tank of 104 race gas in the tank you don't have the injector worry as the fuel rate required is less than when running an ethanol blend.
In closing...
93 octane in the tank - overall reduction in performance but still around 640 awhp
E50 (max) in the tank (100 octane) - 680 awhp/ 780 awtq
Race gas (100 octane) - similar to E50 above
The octane rating will drive the power available from the tune. I'm am going to the track next Friday (17th) and plan on putting race gas on top of my E50 blend to increase the octane rating to something north of 100 octane to see if that gets me into the 10's...
If you get the E50 tune realize you don't need to use ethanol. It will gladly run on straight gasoline, but the tune gives you the flexibility to run up to E50 concentrations safely if you have access to the cheaper fuel.
my E50 tune is a hybrid between the Stage 1 tune that Seb is running and the stage 2 tune the requires hardware support that is still being worked by Jerry. That dyno is at the top of this thread.,
The Stage 1 tune can run anything from 93 to straight E85 and runs around 15psi. It makes the least amount of torque but similar horsepower to mine.
My Stage 1+ tune runs 18 psi but is hardware restricted to E50 because I don't have the necessary hardware upgrades to make power safely with ethanol concentrations above E50. It makes 680 awhp/780 awtq
The Stage 2 tune coming from Jerry runs 18 psi, but has the hardware modifications to run full E85. He is making 705 awhp / 840 awtq. This tune is not for sale yet and will need supporting mods.
Clear as mud?
PS all three tunes will gladly run on race gas as well...
In closing...
Clear as mud?
I am completely stock in all aspects with the exception of water meth for air charge cooling. we disable the meth when dyno'ing and I've run without it in the quarter with zero change in performance.
Intake - Stock
Air Filter - Stock
Plugs - Stock and Stock gap
Down pipes and Cats - Stock
Exhaust - Stock w/ muffler delete
I run Weistec Water Meth kit with smallest nozzles - 250cc
TCU - stock (unfortunately)
Fastest to date was 11.05@129.5 running E50, on stock Pirelli P Zeros set at 51 psi a corner, with traction control off and brake boosting.
Best 60' was 1.7
Best 0-60 was 3.2 seconds
I'm at 88,000 miles currently and its daily driven. if you maintain the car and don't beat on its mercilessly, then it'll be fine.
I had to change my engine mounts at 65K, but that's to be expected when you've got upwards of 50 quarter mile runs under your belt.
I am completely stock in all aspects with the exception of water meth for air charge cooling. we disable the meth when dyno'ing and I've run it in the quarter with zero change in performance.
Intake - Stock
Air Filter - Stock
Best 60' was 1.7
Do you know if your Brutus tune is available to the public yet from EC?
I suggest emailing Jerry direct. I expect he will be pretty swamped today though after Seb's dyno dropped....
Clear as mud?
Apparently the tune I am running is the same as his from what he said to me a couple of weeks ago. He has the hardware upgrades which is why his makes more torque because the tune can demand more?
This is quoted from Jerry
Try this file now! It pulls so hard in 3rd gear from 4000 to redline. Trq is controlled heavily to protect gearbox….
There is one that is invalid for some reason
Hey I'm just enjoying the ride here and start establishing the W212 as an *** kicker in the 1/4 mile and street racing !!
Clear as mud?
Some other tuners like AMS (from what I hear) are pushing 20-21psi boost and achieving barely 600WHP and with huge 750 WTQ that is really not that usable as you explained due to tq limits on the AWD/E63
TCU limits set by AMG:
1st gear TQ limit: 650nm/ 480 FT LBS (@ the engine)
2nd gear TQ limit: 750nm/ 553 FT LBS
