Eurocharged Stage 2 Flex Fuel Tune - full E85 tune
The main thread in particular is:
https://mbworld.org/forums/w212-amg/...fuel-tune.html
I didn't want to muddy that thread with a Stage 2 variant of the tune.
What differentiates a Stage 1 from a Stage 2 tune? Simply the fact that a Stage 1 tune operates within the confines of the OEM hardware and doesn't require any supporting hardware mods to function safely.
The title of this thread is "EC Stage 2 Flex Fuel Tune" however.
What follows is the dyno plot from Jerry's development car running the full E85 setup.
Those of you follow my thread realize that my flex tune is hardware limited to E50 concentrations because my OEM fuel pump cannot deliver the necessary flow rate to safely go beyond that.
For comparison's sake, here my E50 dyno...
It's no slouch, making 680 awhp / 780 awtq tune only, without all the unnecessary supporting mods like intakes,. exhausts, etc. I still have to take the time to blend my fuels to get the necessary octane rating and ethanol content however. For me it's a no brainer.
There are those out there though that want the performance but don't want the hassle of mixing fuels. For my tune, the only alternative then was to run race gas if I wanted those performance numbers as a daily. I'm too cheap for that.
While Jerry was helping me create a Stage 1 flex fuel tune, he was really keen to see what it took to create a true Flex Fuel Tune that could accommodate full E85. It was evident from my tuning efforts that fueling was the Achilles heal that needed to be overcome if he was to realize true E85 capability.
What follows is, to the best of my knowledge, the only published dyno run of Jerry's W212 E63S running his Stage 2 Flex Fuel tune with a full tank of E85. To achieve this Jerry had to augment the fueling system with an upgraded fuel pump.
This dyno should spark plenty of discussion. These performance numbers are approaching BT numbers, and all from the addition of an inline pump and a tank of E85 (105 octane).
If you guys are interested in having the flexibility of one tune that switches between straight 93 octane fuel and straight E85 fuel, and don't mind augmenting your fueling system, then this Stage 2 file seems to tick all the boxes...
The numbers do match however...
I'll try and see about getting a dyno plot with equal scales...
to be fair tho e85 has an average of having 20-30% less mpg vs gas. So the dollar to dollar amount comparison isn’t fair. Also e85 is 105+ octane ms-109 is only 100 octane. I’m not against e85 at all, actually I’m excited. But definitely want to see a fair comparison of higher octane fuel and what this motor can handle over 105 octane and how much our fuel pump can handle pressure wise .
I was occasionally experiencing fuel cut due to the cars inability to deliver the fuel at a rate demanded by the tune.
I'll go back through my logs to see if I can determine what that flow rate was.
If we could determine what that flow rate was for ethanol then we could use that flow rate number for gasoline.
How much power that would make would depend on a tune that could recognize it and adapt for it though.
Jerry's car is running the AMS Cooling System
From the data logs I saw from his dyno session, the most he saw was an increase of 10 degrees under load during the dyno runs. This was really good! More importantly, the temps recovered really fast... faster than mine did.
I have not seen any quarter mile track logs but I suspect they will be equally good. E85 burns cooler than gasoline so I don't see temps being an issue either.
As a point of reference, my tune runs the same boost.. 17 to 18 psi, and I've got many multiples of data from the dyno and track to call upon. I have stock cooling though I do use water wetter. Under track conditions the max I saw was an increase in IAT's of 30 degrees at the end of the quarter mile run. I would see similar temp increases when on the dyno. I can only infer that Jerry's car would not experience any more increase in temps than he saw on the dyno owing to the superior cooling hardware his car has.
I think it would be good to take the vehicles to the next Texas Mile event and see what sustained boost over 26/28 seconds does to intake and exhaust temps.
Both cars are running stock exhaust with Cats, though Jerrys are HF Cats... mine are stock. That will only improve matters for him.
yes agreed . My bad fellas lol. But yes if I remember correctly a lot of guys go off the mon rating, especially with top end power . Especially with boosted motors and adding timing. But it’s been a while maybe things have changed.
