Whine Noise after reving??
Old May 8, 2020 | 04:41 PM
kolkhara's Avatar
s430
Hey Guys,
I have a 2016 e63s that has a whine after reving, I don't think its normal but Ive heard it on other e63s. Today I ran across a video with the same exact whine after rev. Does anyone know where it comes from?
Heres the link to the video
Old May 8, 2020 | 05:29 PM
mrjohntan's Avatar
M3, S212 E63
I think you're referring to the turbo spool?
Old May 8, 2020 | 06:19 PM
NoVAe63s's Avatar
2016 E63s
I get the same thing, seems to have just started recently. I think it’s at all RPMs if you listen closely, just more noticeable on a rev since the exhaust note drops off but the whine lags a little.
Drives me nuts and worries me a little. But I get past it knowing I have an intact warranty. Without that I’d be driving myself crazy tracing that bad boy down.
Old May 8, 2020 | 06:20 PM
kolkhara's Avatar
s430
"I think you're referring to the turbo spool?"
no after he lets off the throttle you can hear a sound that slowly winds down as the rpm goes down. Sounds like power steering pump winding down, or the pulleys .. the main portion is to listen after he lets off the throttle
Old May 8, 2020 | 06:21 PM
kolkhara's Avatar
s430
Im out of warranty
I tried to track the sound down and I have no idea. What year your is your e63? as longs as others experience it I guess I shouldn't be too worried.
Old May 8, 2020 | 07:49 PM
NoVAe63s's Avatar
2016 E63s
Originally Posted by kolkhara
Im out of warranty
2016
here is video of mine, I’m guessing some accessories are electrically driven and ramp up and down based on RPM. Annoying for sure.
Old May 9, 2020 | 05:14 AM
kolkhara's Avatar
s430
2016
https://youtu.be/cT4YQZ2ORJM
that's the exact noise I have and the exact "location"
at first I thought it was the turbo going bad but realized it wasn't .. other things I can think of is its coming from the trans?? Im going to do a test and switch in neutral and try it to see if it still comes up.
Old May 9, 2020 | 05:34 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Typical turbo notices are a whisle mostly heard on decel at standstill. “Usually” it’s a quieter whistle when accelerating only because everything else become louder.
Bad turbo noises are closer to a dentist drill sound where you can hear the whistle mixed with a slight grind.
This all being said, you could make sure to look for turbo related oil leaks and any oil based smoke upon startup and acceleration. A bad turbo is very noticeable when it happens.
Old May 9, 2020 | 06:10 AM
kolkhara's Avatar
s430
I don't think this a turbo issue, I hear it after the throttle is released slow grind just like the video posted above, it matches the rpm so its most likely something that is driven by a belt or in the trans. I wonder if any one else experiences it in their car.
Old May 9, 2020 | 02:24 PM
NoVAe63s's Avatar
2016 E63s
Sound emanates from the passenger side, so is related to the turbos I would think it would be both sides. Unless the starboard turbo is coincidentally failing between our two cars. I would think if the turbo was failing there would be some code that would be thrown as well.
Coolant pump, alternator and idler puller appear to be on that side? If related to the tranny, I hope to get a full flush done in the next few weeks and we’ll see if that helps.
Old May 9, 2020 | 04:31 PM
kolkhara's Avatar
s430
I don't think its the turbo, I took off the charge pipe and found no oil and the intake pipe I found no play in the turbo. Could be the coolant pump or alternator. Ill keep looking into it. Let me know if you find anything. Thanks for your feedback!
*Edit* So far its three cars with this... Random car on internet showing off exhaust, mine and NoVAe63s... any one else seeing this?
Old May 9, 2020 | 04:53 PM
kponti's Avatar
E63
My dealer replaced the alternator when I had that noise, came back after a few months though. Doesn't seem to be an issue to worry about
Old May 9, 2020 | 06:27 PM
NoVAe63s's Avatar
2016 E63s
Back in the good old days you had room to work around the engine compartment and I would listen to accessories through a wooden stick or dowel. Could find all sorts of stuff like failing bearings.
These days you’re lucky if you could slip a dollar bill between parts. Me thinks manufacturers intentionally do this to kill the shade tree mechanic and pump up service department revenue!
Old May 9, 2020 | 07:34 PM
kolkhara's Avatar
s430
Thats good feedback, thank you for that. The sound comes from the passenger side of the engine compartment right where the alternator is located.
replacing the alternator on this car is a mission. WIS says rad fan needs to be removed and coolant lines need to be removed, then the rack n pinion needs to be detached and lowered. Its not an easy task. If it is the alternator its not worth replacing just for the noise it makes.
Old May 10, 2020 | 12:35 AM
SAMzE63s's Avatar
E63s
kol khara loooooool
Old May 10, 2020 | 05:53 PM
NoVAe63s's Avatar
2016 E63s
Originally Posted by SAMzE63s
kol khara loooooool
Does that mean eat doodoo in Arabic?
Old May 10, 2020 | 06:11 PM
SAMzE63s's Avatar
E63s
yep, literally lol.
Old May 10, 2020 | 06:30 PM
NoVAe63s's Avatar
2016 E63s
Kinda amazing that insults are pretty much universal no matter the language or culture.
I once worked with a Cambodian guy that grew up in some remote jungle far away from civilization. He said he used to prank his villagers by smearing poop on the leaves of low-hanging branches along popular trails. At the end of a walk through the jungle all these guys would complain that their foreheads smelled like sh*t.
That’s funny no matter where you come from.
Old May 11, 2020 | 12:24 AM
SAMzE63s's Avatar
E63s
lol that’s nasty but funny
his username kolkhara caught my attention lol
Old Jun 12, 2020 | 04:48 PM
NoVAe63s's Avatar
2016 E63s
Update - performed the full transmission service and oil change, noise is still as loud as ever.
Old Jun 12, 2020 | 05:33 PM
DAMG63's Avatar
w211 E55, w213 E63s
this is somewhat normal ( as abnormal as this may sound) - had a 14 c63, made the same whining noise. currently have a 14 cld 63, same noise, and all of my other buddies here local have their 63's and made the same exact whine noise.
my best friend is a master Mercedes tech and has informed me this is normal due to the design of the pulley system within the 63's both n/a and turbo. nothing to worry about
hope this helps...
cheers!
Old Oct 25, 2022 | 10:04 PM
Dakintosh's Avatar
13 S550 4MATIC, 14 S63
hope this helps...
cheers!
This is great to hear. My S63 has this whine, it's driving me nuts trying to track it down.
Old Mar 10, 2025 | 12:38 PM
carranza913's Avatar
2013 e350, 2016 S63
Sorry to bump this thread. Did anyone ever figure this out? My S63 has same whine.. only noticeable in low gear and high rpm.
Old Mar 10, 2025 | 12:52 PM
DAMG63's Avatar
w211 E55, w213 E63s
check pulleys
Also check your tires, could be some uneven, where maybe on the inside of the tire?
Old Mar 10, 2025 | 01:29 PM
2013 e350, 2016 S63
It is rpm related and sounds like it comes from timing cover on passenger side. I have the new timing chain as mine is 2016. No codes no performance issues. Just bugs me.
