squeaky/creaky front end
Old Jun 9, 2020 | 01:06 PM
Mikesoja's Avatar
2014 E63s AMG
Got the link to the YouTube video I made below for some reason I can't upload it?.
But basically I can sit in my car jump up and down and the front will squeak and creak? does the bushings need lubricant and if so which one? And what type of lubricant?
https://m.youtube.com/watch?v=7TxzDr...ature=youtu.be
Old Jun 9, 2020 | 01:50 PM
_KO_'s Avatar
2015 CLS63, 2020 GLC300 Coupe
I had the same issue maybe 2-3 months back. Changed the drivers side control arm and it solved the issue
Old Jun 9, 2020 | 01:54 PM
Mikesoja's Avatar
2014 E63s AMG
Oh ok upper or lower??
Old Jun 9, 2020 | 02:43 PM
_KO_'s Avatar
That’s the picture the mechanic sent me, is that The lower control arm? It was the most irritating sound driving slow and hearing it over every bump. I would hear it getting in and out of the car.
Old Jun 9, 2020 | 03:11 PM
wseikow's Avatar
E63S 2016 [W212 ] :::: E55 2002 [W210 ] [31k miles] ::: TARGA4S 2007 [ 997.1 ]
I had the same 6 months ago.
Mine was under warranty
MY2016
Old Jun 9, 2020 | 05:21 PM
Mwd759's Avatar
E63
Lower control arm
I just changed mine it was the lower control arm.
Old Jun 11, 2020 | 12:28 AM
Rehabguy's Avatar
E63S
https://mbworld.org/forums/w212-amg/...y-squeaky.html
Old Jun 11, 2020 | 11:14 AM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
Same thing here. On the driver’s side. Replaced under warranty.
Old Jun 11, 2020 | 11:17 AM
Mikesoja's Avatar
2014 E63s AMG
nice did you do it yourself or at a shop?
Old Jun 13, 2020 | 12:11 PM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
Same here drivers side
What I noticed is that nothing was wrong with the hardware except that the arm was moving to the rear of the car off the bushing. I swap out the arm and had an alignment done and all was good. I did an oil change and guess what the arm is starting to move off the bushing again. Good thing I kept my old arm and hard a friend centered the bushing and he spot weld the bushing to the arm to prevent this movement. Next oil change I will swap to my old modified arm and will be doing the same with the arm I removed as I have a few W212 family/friends. The arm is the same for all W212 not difference n AMG or E350 E550 all the same.
Old Jun 13, 2020 | 05:35 PM
Rehabguy's Avatar
E63S
Really?! That's insane! You remember ball park how many miles you have driven the car before this was observed on the new arm? MB needs to step up and take responsibility for this. Not cuz this "was once a $100K car" but cuz it's very apparent there is something wrong with the way the car was built. All of us had the same exact part fail (mine gave out at 30K.)
Old Jun 13, 2020 | 06:15 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
I’m at 35,000 miles on mine and I already had the lower control arms replaced once at about 20,000 miles. I get the creaking and clicking every time you turn dealer said it was normal but I’m taking it back since I still have a year and a half left of extended warranty. I agree this is ridiculous that this part feel so bad
Old Jun 13, 2020 | 08:31 PM
Rehabguy's Avatar
E63S
"Yes, It's normal for these cars to go through a driver's side cross strut every 15-20K miles" I have never heard of a bigger crock o' .... Are you sure it's the same part that has gone bad again though?
Old Jun 14, 2020 | 09:37 PM
5soko's Avatar
AMG
Yea, this is very common and honestly unacceptable.
Ive seen them go bad in 10K-15K miles on some cars. Always the drivers side.
Old Jun 15, 2020 | 09:25 AM
Ncbimma's Avatar
E63S
Just had both sides done about a month ago. Saw the issue on the driver side during a midpipe install...
Guess I'll need to keep an eye on things and watch if they start to go bad again- I like that spot weld idea, but wonder if it alters the bushing material heating it up or makes it behave differently.
Old Jun 15, 2020 | 10:04 AM
Mikesoja's Avatar
2014 E63s AMG
Hey if you ever do the spot weld on one of those arms again can you make a video?
Old Jun 15, 2020 | 11:39 AM
sunil517's Avatar
@around 17k with a dealer arm
if I did not have my old arm I would have tried a RockAuto arm. My old arm ws also a replacement. One I have my welded arm I am sure it will be the last time I chance it unless the ball joint goes.
Funny my friend E350 one at 10k no problem one with 70K no problem.
An E550 with 90k is starting to show movement and he will be getting a welded arm once I remove mine. it must be power related.
Old Aug 24, 2020 | 10:50 AM
Mikesoja's Avatar
2014 E63s AMG
Hey so if anyone has this issue like I displayed in the youtube video(also in cylinder heads picture), it is the result of a bad driver side lower (rearward) control arm had it changed and its all good now!
Old Sep 18, 2020 | 10:02 AM
FastWgn's Avatar
2016 E63 Wagon
This has happened to me again - third time in 55k miles.....
same squeaky noise....
To be replaced next week under warranty.
This is crazy.
Old Sep 18, 2020 | 01:04 PM
I.T. Guy's Avatar
2023 E63S Wagon
Same squeak
warranty
control arm
hasn't been back for me
Old Sep 18, 2020 | 04:18 PM
Rehabguy's Avatar
E63S
This is crazy.
That is absolutely insane!
Out of curiosity, do you track or road race your car or something?
Old Sep 18, 2020 | 04:52 PM
FastWgn's Avatar
2016 E63 Wagon
Nope - not even close.
Never tracked the car, no road racing (too old). Usually alone, so no heavy weight. Never drive hard when loaded.
Do I drive for fun? Yup. The one thing I do think about is that I drive 99% with suspension in Comfort (roads around here are pretty poor). Maybe that allows for more suspension movement and hence faster movement of the bushing?
I am a bit **** about noises etc though. Maybe others just ignore the squeak and don't care?
No idea how you can track this car with that lower arm? It must move.
One heavy braking zone followed by transition and turn will move this thing right away.
Old Oct 25, 2020 | 01:32 AM
Mojo20032004's Avatar
2014 E63S
Are you guys preloading the bushing/control arm before tightening the bolt/nut? This is a common mistake that is often overlooked and leads to bushings failing faster then normal
Old Oct 25, 2020 | 07:30 AM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
I have replaced just about everything...
But the noise persists. Mine sounds more plasticky and less metallic. Only thing I haven't done is shocks, they are next. Ridiculous design and build quality on a car like this.
Old Nov 11, 2020 | 09:13 AM
crazybear's Avatar
2014 E63
I'm having the same issue; bushings for both the lower control arms and torque struts are bad. Can the bushings just be replaced or does the entire component need to be replaced?
