Need help diagnosing P0087 - Fuel Rail/System Pressure - Too Low
Old Sep 30, 2020 | 09:10 AM
crazybear's Avatar
2014 E63
Hello all,
I have a 2014 E63 with around 66k miles; I occasionally get the P0087 code (Fuel Rail/System Pressure - Too Low) whenever I drive the car hard. CEL comes on and car goes into limp home mode, but after I clear the code car drives normal. I've gotten the code about 2-3 times over the course of 1 year of ownership. Car is stock except for resonator delete and UPD cold air induction kit.
It's the only code that comes up. What do you guys think could be the issue? Faulty fuel sensor? Clogged fuel filter? Do these cars even have external fuel filters?
Thanks for the advise.
Old Sep 30, 2020 | 12:02 PM
nota_amg's Avatar
2013 SL550 BiTurbo
the fuel filter is built into the driver's side(Left) sending unit(in the tank). You'll need to change the entire unit as the filter is "not serviceable". Best price I've found so far is here.
Filter P/N(driver's/left side) is: 2184700495
Punp P/N(Passanger's/right side) is: 2184700595
I would monitor/log the HPFP circuit pressure and see what it is doing. Pressure should stay steady and not drop significantly(you'll see a slight drop, when going full throttle, but it should recover almost immediately). Could be a filter or lift pump issue, but you'll usually get a LPFS Low Pressure code before you get a HPFP Low Pressure code. It is possible you could have a faulty HPFP, or a bad injector, or even a faulty HPFP Circuit Pressure Sensor.
Old Sep 30, 2020 | 12:27 PM
crazybear's Avatar
2014 E63
What can I use to log HPFP? Would the torque app work?
Old Sep 30, 2020 | 12:32 PM
nota_amg's Avatar
2013 SL550 BiTurbo
yes, I use Torque to log. There is NO PID for Low pressure fuel pressure, only the high pressure circuit can be seen, just FYI
Old Sep 30, 2020 | 05:55 PM
crazybear's Avatar
2014 E63
So I was able to log: lowest fuel rail pressure got was around 1430psi (~98bar) at fuel operating temp and idle at around 700. When I revved it, it would go up significantly. Short terms were fine also. Not sure what else to do. Maybe add a bottle of fuel system cleaner.
Old Sep 30, 2020 | 06:56 PM
nota_amg's Avatar
2013 SL550 BiTurbo
check your PMs...lol
Old Oct 1, 2020 | 10:03 AM
crazybear's Avatar
2014 E63
thank you, got it.
Old Oct 1, 2020 | 10:11 AM
crazybear's Avatar
2014 E63
For everyone else following, I logged this morning and fuel pressure still seemed fine while cruising (1540 - 1760 psi) and for hard pulls (up to 5k rpm) it got up to 2500psi. I didnt see a dip in the psi nor did I get a CEL. I will keep logging and see if I can replicate the issue. Its been really inconsistent.
Old Jul 8, 2021 | 02:54 PM
Crunch69's Avatar
ML350, E550 Coupe, 53 F100, 458 Italia, 458 Spyder
Old Jul 8, 2021 | 02:55 PM
Crunch69's Avatar
Was there a fix? I haver the exact same issue on the same engine
Old Jul 8, 2021 | 06:44 PM
crazybear's Avatar
2014 E63
Not really. I used some fuel system cleaner and it hasn't been back since. It was fairly inconsistent.
Old Mar 29, 2022 | 10:02 PM
Siegmann's Avatar
10-second E550
@nota_amg Does the sending unit normally include a new seal for the cap/bezel?
Old Apr 22, 2022 | 10:54 AM
nota_amg's Avatar
2013 SL550 BiTurbo
​​​​​​No, seals and caps are reused. If the seal is damaged, you can get one from MB to replace it.
Sorry for the late response, new job... Haven't been online in a while...
