Kw lowering springs question
What I'm asking is, if I set the links to a certain ride height since you have to adjust these manually, what happens when I switch the dampening to s+? Does the car lower itself some more, or does it just change the stiffness only
Hope this helps.
Hope this helps.
Hope this helps.
(PS, I thought you were selling the car?)
And I was, but supposly 58k is to expensive for a 22k miles e63 😣
Ride Height Thread 2017
Dampening modes also affect ride height?
On a slightly different note yet related to discussion... Be gentle on them KW Links
WD40 is your friend
I am convinced this is why the kit comes with 3 links
WD40 is your friend
https://www.ebay.com/itm/15345410876...mis&media=COPY
OP, the above eBay link sells metal rear lowering links that are 10 million times nicer and easier to install and remove than the plastic turds that come in the $1K HAS kit. It'd be an additional expense but well worth it IMO.
