Catastrophic Failure due to oil sensors leak
GEARWRENCH E-Torx Double Box Ratcheting Wrench, E10 x E12 - 9221 - Box End Wrenches - Amazon.com
I'm trying the remove the bottom screw of the left magnet solenoid on driver side. Thank you for your help again.
I used this wrench, open end. It’s slightly longer than the little sears wrenches I had. There are also wrenches called mini wrenches that are thin and come in a kit, but are not long.
when doing my sensors and coolant lines I got this.
and these are thin and ratcheting (though this made some easier, not the bolt you are looking at). That magnet also has a tough time coming out, possible but very tight, and new one going in may get messed up. Ymmv
harbor freight also has a long thin ratchet for sockets, great for the coolant pipe replacement.
Looks like that lower bolt will get jammed against the oil filter housing . I could be wrong - anyone able to sneak the upper driver side magnet in ?
Thread title is a bit inaccurate - oil sensors aren’t the issue but rather cam position sensors and cam solenoids, as is being discussed.
The failure, while inconvenient and requires some out of pocket $, isn’t what I would call catastrophic. Cylinder scuffing and piston cracking are more like catastrophic defects in my view.
Agree that proactive sensor and magnet replacement is good practice. Plus other “while you’re in there” parts replacement like hoses, belt, etc.
often wis is only complete when combining multiple documents. On the tensioner thread, the wis docs are there that include lots of breakdown.
I too got stuck where you did but was able to get the magnet out. Getting the magnet in was the hard part for me.
even though these are e10 bolts, you will find using a regular wrench on the open side is the only way to do it without following wis. That is unless someone invented an open ended e wrench. The closed or boxed sides of the wrench will fit on but not come off once the bolt fills the tight space. Oem expects we are coming at these from the front and we are trying from the top.
be aware some videos show a different oil cooler, the Amg split system after 2013 is the harder one.
because I continued into doing the timing tensioners and check valves, I was less concerned with keeping everything in place. It’s grueling but all in was about eight hours including turbo lines, all sensors and magnets, check valves and tensioners. Cost me about a grand in parts, from fcp.
below You can see that before removing the oil cooler for the tensioner job, this should get you where you need to be.
https://mbworld.org/forums/gle-class...-report-4.html
This would be very hard to do and it will not work. I tried that within my repair. I looked for the easiest way vs WIS. WIS is what I had to follow. Because there is a little placements dowel (at least in mine there was and pic are in the tensioner thread) in there, it requires everything in front of it to come out.
Sorry that's not the answer you want to hear. No other way other than the oil filter housing
Here is a thread that points it out on the m157 engine as well
https://mbworld.org/forums/w212-amg/...ine-noise.html
