What's going on with my throttle - scan logs
Old 10-18-2022, 03:30 PM
  #51
PeterUbers's Avatar
Received 2,029 Likes on 1,417 Posts
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Just wait till you get this sorted out... in our current cool "boost weather" with the mods you have currently ... you're mid to high ten's car ... it'll seem ridiculously fast when this is all dialed in
i wish we had a soft CEL... something pastel orange and more pleasant .. indicating these other issues which need to be addressed right away but don't warrant stopping the car, pimp mode, or a tow.
Fortunately however these ECUs are relatively smart and have a way of pulling back timing etc. etc. to try to protect the engine a bit, hence your restricted data points you identified when you were doing the logging. Once you get a misfire however, this engine doesn't seem to like that and can be significantly problematic
Old 10-18-2022, 05:32 PM
  #52
Robert AMG's Avatar
Cls63 & C32
he has an E63s 2016 with old bosch 010 pump? how is that?
Old 10-19-2022, 04:57 AM
  #53
PekkaH's Avatar
2015 CLS550 Shooting brake 4-matic
The pump in that car must be CWA100.2 like Robert said. I haven't heard that any CWA100 have gone bad. Have anyone else? If I remember correct that pump did stop working when trying to rewire it to run 100%. Are you really sure that there are not any fuse problems etc. Before order and change a new pump?
I also did believe that my new CWA100 was bad, when I upgrade my Bosch 010 to it. Some lovely fellow enthusiast in whats up group did help me out then. I just needed to find the right fuse and it worked nice.
I.T. Guy (10-19-2022)
Old 10-19-2022, 09:44 AM
  #54
I.T. Guy's Avatar
Received 1,145 Likes on 599 Posts
2023 E63S Wagon
This is a fear of mine
Before I tried the "always on" mod car was seeing 50-58C IAT and after mod the next day I was seeing 100C. So my fear is I blew the pump myself, will replace it, and still be slow with the new pump. LOL. I just don't know enough at this point about logging and this platform. What are other people's IAT's that are running high 10s? How different from ambient?
From dealer service work:
"Connect Star and Charger, perform quick test. Found Fault Code P023B00 actuation of coolant pump of charge air cooler has a short to ground. (this is from the always on mod IMHO which I removed before taking in to service) Raise Vehicle, inspect pump. Found connector stuck within pump. Found some corrosion and burn marking within connector. Check 12V and ground, found 12V not available. Check fuse, found fuse burnt. Renew fuse found pump shorted causing fuse to burn. Recommend replacement of pump and fuse."
I really hope the IC pump is the main problem, otherwise I will still be chasing only 87% throttle and very low boost PSI and power.
Old 10-19-2022, 09:55 AM
  #55
PekkaH's Avatar
Please check if you have that fuse 70 before you buy new pump. Those internet diagrams could be wrong etc. So you don't soon have two working pumps.
I can later see on my HPT logs what intake temps I did have with pump mod and let you know.
Old 10-19-2022, 10:32 AM
  #56
Siegmann's Avatar
2013 E550
~87% throttle is normal max. It's the percentage of the total voltage range where the throttle reaches full open.
Old 10-19-2022, 12:04 PM
  #57
PeterUbers's Avatar
If he blew his IC with this mod then itll
be the first post mod IC fail I've read about
Old 10-19-2022, 01:08 PM
  #58
PekkaH's Avatar
@I.T. Guy I did found one 0kp/h - 202kp/h ( 0mp/h-125mp/h) HPtuners log. Ambient temperature 21C, 34C IAT when starting the pull and end of the pull IAT was 44C. So 10C rise during the pull. And that pull was done with my old Bosch 010 pump with pump mod. I haven't log now with my current CWA100.2 pump. But I have made new personal Dragy record and run 60-130mp/h 7,59s after pump swap. So maybe the pump swap did help me out there and of course the pump mod also.
Old 10-19-2022, 02:06 PM
  #59
BCP
BCP's Avatar
2014 E63s
Thank you cancelling seemed easy enough.
How do we all know its the same?
So is there no improvement over stock? How does Renntech claim such an improvement?
If that's the case, can't I just let the dealer install theirs?
A friend locally has the Renntech pump on his 14 E63, he bought it that way, and it is the same pump as what comes stock on the 14-16 E63...albeit with Renntech branding.
Renntech's claim is based upon replacing the older Bosch 010 IC pump that came stock pre-2014.
Hopefully there isnt a wiring issue that's causing a short to ground after the always-on mod was removed.
You can let the dealer install their pump, but didnt you say it would take a while to come from Germany?
Old 10-19-2022, 02:31 PM
  #60
I.T. Guy's Avatar
2023 E63S Wagon
Yes in Canada the dealer said 2-3 weeks out for the pump. I asked if they would install a better aftermarket pump if I sourced it and they said "Yes for sure let us know when you get it we will book you in". I <heart> my dealer
Dealer pump was just under $900, FCP Euro pump was $570, and the RENNTech pump was $1350. I let the RENNtech order stand and it's on it's way. They were really nice and going to cancel it no problem. When they asked why I I wanted to cancel I told them I found the Pierburg 0005000486 and they said "Oh that's the OEM replacement - ours flows 3.5x more and ours comes with the harness". So, if anyone knows how to test the flow of the pump when it gets here let me know! It will be interesting to see what other markings are on it (if any) besides RENNtech and what the pump actually looks like and flows.
Old 10-19-2022, 02:49 PM
  #61
BCP
BCP's Avatar
2014 E63s
Pierburg CWA 100.2 specs https://www.tecomotive.com/en/products/CWA100.html Pierburg CWA100
The CWA100 or CWA100-2 is a performance enhanced version of the CWA50.
The dimensions and the weight is nearly the same.
This closes the gap between the CWA50 and the CWA200.
Suitable for instance for intercooling in combustion engine vehicles and cooling of various systems in electrical vehicles.
Specifications:
  • Name: "Pierburg CWA100-2"
  • Operation voltage: 8-16 volts
  • Weight: approx. 1.0 kg
  • Current consumption: 8.5A max. / (approx. 0.2mA in standby mode)
  • Nominal diff. pressure: ≥ 0.75 bar *
  • Flow rate: approx. 30-35 l/min @ 0.75bar / 40-45 l/min @ 0.50bar
  • Speed: approx. 7000 rpm
  • Temperature range: -40°C – 110°C (water) / -40°C – 120°C (ambient)
  • Protection: IP 67 + IP 69 K
Renntech pump specs: Testing showed our Intercooler pump flows an impressive 8.7 G.P.M. @ 11.6 P.S.I. compared to the OEM pumps 3.00 G.P.M. flow rate.
Old 10-19-2022, 03:00 PM
  #62
I.T. Guy's Avatar
2023 E63S Wagon
Thank you!
Old 10-19-2022, 03:45 PM
  #63
Robert AMG's Avatar
Cls63 & C32
the Renntech pump and what you have now on your car are the same cwa100.2, they are talking about the older bosch pump which has less flow,
you can found it new Pierberg branded for less then 300 euro from Germany, but before check your fuses and harness pins.
The following 2 users liked this post by Robert AMG:
BCP (10-31-2022), PekkaH (10-19-2022)
Old 10-19-2022, 04:51 PM
  #64
I.T. Guy's Avatar
2023 E63S Wagon
The following 3 users liked this post by I.T. Guy:
BCP (10-31-2022), mbwillgrubs (10-21-2022), PekkaH (10-19-2022)
Old 10-19-2022, 04:55 PM
  #65
PekkaH's Avatar
You are crazy man!
My CWA100.2 did cost me 266e from Germany.
But hope you can solve your pump problem soon!
Old 10-19-2022, 05:01 PM
  #66
I.T. Guy's Avatar
2023 E63S Wagon
I do feel regret.
Old 10-21-2022, 12:10 PM
  #67
mbwillgrubs's Avatar
2013 CL 63, 2002 E 55, 04 Jaguar XJ8, 66 Jaguar XKE
put the pump in a gallon of water and time how fast it takes to empty.
Old 10-21-2022, 02:49 PM
  #68
PekkaH's Avatar
Maybe this picture helps some builders after us to know what those Bosch 010 and CWA100.2 pumps really looks like.
Left Bosch 010 and right CWA100.2
The following 2 users liked this post by PekkaH:
BCP (10-31-2022), I.T. Guy (10-24-2022)
Old 10-28-2022, 02:56 PM
  #69
I.T. Guy's Avatar
2023 E63S Wagon
And here’s the Renntech.
Dang it.
Old 10-31-2022, 10:59 AM
  #70
I.T. Guy's Avatar
2023 E63S Wagon
Car waiting on a pump still since Renntech took that one back. They were super nice and helpful even with the return, so I have to give them some kudos as they seem like a great company to deal with. Thank you all for the info on it being the same pump.
BCP (11-01-2022)
Old 11-04-2022, 01:52 PM
  #71
I.T. Guy's Avatar
2023 E63S Wagon
I got tired of waiting for my dealer appointment and made an appointment with ECC Tuned for next week.
Man I can't wait to feel how the car drives all sorted with the stage 2. I'm rushing to get it done now before snow flies and tires change so I can do some Dragy.
Crossing my fingers....
Old 11-04-2022, 02:11 PM
  #72
Mojo20032004's Avatar
2014 E63S
Going s2 with a broken pump is a disaster waiting to happen. More power means more heat!
Old 11-04-2022, 02:14 PM
  #73
PeterUbers's Avatar
i think he means ecc is installing the pump??
I.T. Guy (11-04-2022)
Old 11-04-2022, 02:25 PM
  #74
2014 E63S
I think I read it wrong 🙄
Old 11-04-2022, 02:47 PM
  #75
I.T. Guy's Avatar
2023 E63S Wagon
ECC is going to do the pump, the PLM heat exchanger, and then sort out whatever else might be wrong then dyno it. My ECU and TCU are from ECC via Jose at Boosted Benz anyhow so why not go to the source to find out what's up.
I'm a slow learner. I should have just called ECC on the way home from the track.
PekkaH (11-04-2022)
Quick Reply: What's going on with my throttle - scan logs
