Smell of gas after driving
Old Nov 9, 2022 | 12:37 AM
vdubpower's Avatar
i drive them all, fast and hard
Very odd. After a drive I usually get out and open my rear driver side door as I place my bag in there for work. I have noticed a gas smell from the driver side of the car after a drive. I don't smell it anywhere else around the car. I don't see any leaks anywhere either and the car is driving fine. I don't smell it inside the car either. Has this happened to anyone
Old Nov 10, 2022 | 07:37 PM
PeterUbers's Avatar
W211 had an issue with the tank leaking though I think this was fixed for w212.... anything weird around the fuel cap? Can you pop the seat bottom out in the rear and smell for leaks?
Old Nov 11, 2022 | 12:21 AM
vdubpower's Avatar
I have a basic scanner, i can start with that. and pull the seats this weekend. Is there a HOW to do that somewhere on here.
I dont smell anything inside the car, but its just apparent when standing by the rear door. I always open it after a drive to get my bag. I dont think there is any greater smell when i open the door. Still no visible leaks.
Ill check in morning if any smell after sitting overnight....
just passed 90000 miles...mostly issue free....... I guess hello Hyundai ionic 5
Old Dec 2, 2022 | 06:49 PM
vdubpower's Avatar
**** under the seat...hurray
Old Dec 2, 2022 | 06:51 PM
PeterUbers's Avatar
so under the rear seat? Like the w211's?
Old Dec 3, 2022 | 03:37 AM
vdubpower's Avatar
yep. left side is sender , right side is pump
Been recommened to change both, even tho leak is left side
So 211 also does the same?
just noticed on your sig, 2 cars bought back by mbusa, why
Old Dec 3, 2022 | 10:38 AM
PeterUbers's Avatar
yep i mentioned it above
https://forums.mbclub.co.uk/threads/...l-leak.133368/
both e550's had bad transmissions ... bad batch apparently that year ... failing clutch packs with harsh shifting
