Are rod bearings a maintenance wear item for those who run a tune?
It doesn't matter if you're running 50 horsepower or 850, it should never be a metal or metal contact bearings. If there is, it's a matter of minutes before they fail.
I've never heard of any bearing failures with an m157 or any Mercedes to date
It's too true! The BMW community has to replace rod bearings on basically all of the M cars, until the more recent motors (2014+).
But, it seems like all of them have some sort of fatal flaw (similar to the oil in sensors on E63). For the F8x M3/4, rod bearings are fine and can handle a ton of power, but instead you have the crank hub problem, where the crank hub bolt can work itself out and grenade the motor. So, now you are seeing used car posts for those M3s advertising "crank hub fix already done." The pricing on that crank hub fix varies wildly... I've seen quotes from $2,500 all the way to $7500, but the most common is between $5-6k.
He must be working on a lot of BMWs lol, Naaaa rod bearings shouldn’t be a concern on this engine. There are many 157/278 motors running stupid numbers with no issues. This usually becomes and issue when a manufacturer uses very tight tolerance like BMW does.
But the rods are! The nannies don't seem to protect the engine as well on (aggressively) tuned cars when there is ping, knock, bad gas, bad spark, older plugs, any worn ignition items, rods like to give it up.
If you are tuned it is imperative to keep everything running tip top. And if you fill with less octane or bad gas don't WOT until it's all perfect again.
And find a safe tuner. Tuners that wring out that last 20-40HP for the dyno-war win are putting things too close to the edge so when something does go "wrong" (old plugs, bad coil, bad gas, tired fuel pumps) it's not pretty.
Stay safe out there!
