10 inch fronts?
Old May 20, 2023 | 11:39 AM
Krakenjack's Avatar
2014 AMG E63 S212 | 2018 Alfa Romeo Giulia Ti Sport Q4
10 inch fronts?
Has anyone here been able to get 10 inch fronts? I daily my car and not being able to rotate costs a small fortune in tires, i do 30k milles a year and would like to be able to rotate and get better use but i don't want to drop down to 9.5's in the rear. I'd like to do a 10x19 or 10x20 square. (10x18 if need be).
Just looking for any info on how to make this work/fit - i am mentally challenged when it comes to tire fitment @_@
Old May 20, 2023 | 08:07 PM
Rehabguy's Avatar
E63S
It has been done.
A member ran 20x10 ET35; 275/30/20 Square.
Old May 20, 2023 | 10:38 PM
I.T. Guy's Avatar
2023 E63S Wagon
I DD too no problems not rotating “properly”
what’s the issue?
Old May 21, 2023 | 01:44 AM
Krakenjack's Avatar
I’m getting not fantastic life out of my tires. Wanted to rotate for even ware. I do 30k miles a year…and would like to get 50k from a set of AS instead of 30k.
Old May 21, 2023 | 12:26 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
50k miles on a low profile tire? Is that even possible even with rotating?
Old May 21, 2023 | 03:13 PM
Krakenjack's Avatar
thats contientiels problem lol the AS have a 50k if rotate warranty lol
Old May 21, 2023 | 07:48 PM
ThreeSix's Avatar
G550
im running a 19x10 squared setup with 265 tires all around on my wagon. Front offset is currently +28 with 5mm spacer. I cant comment on tire wear as ive only put around 8k miles on the setup, but my front tires are still looking good, and I definitely get more life out of the tires with the ability to rotate them back and forth every 5k miles.
Old May 22, 2023 | 01:18 PM
E55 KEV's Avatar
Veteran: Air Force
So, you need a square set up in order to rotate so Conti will warranty replace them with new tires?
The Conti free replacement period is only 12 months. After that the tire "will be replaced charging the owner a pro-rated amount".
CT22_TCP_Policy.pdf
Is all that effort and cost of buying new wheels really worth it?
Old May 22, 2023 | 08:31 PM
Krakenjack's Avatar
CT22_TCP_Policy.pdf
i mean... that and a square setup just looks better lol
