2014 replacement rims
Old Oct 15, 2023 | 08:08 PM
e55joe's Avatar
2014 E63s,2004 E55, 2006 STS-V, 1969 Camaro RS/SS 396, 2012 Centennial GS Corvette
Ok im tired of having to fix my rims from all the cracks. What are the best replacement rims and size. Pics also what they look like. Preferably ones that wont crack
Old Oct 15, 2023 | 08:12 PM
PeterUbers's Avatar
first question-
What's your budget?
Old Oct 15, 2023 | 08:14 PM
kenneyd's Avatar
poop
Something forged
​​​​​​ generally, those are least likely to bend
Old Oct 15, 2023 | 09:40 PM
Faast's Avatar
'91 964 Turbo, '02 E55's & '14 E63s-w
I have a set of HRE's as well as Vossen (forged) in black stock sizes that I might part with.
send me a PM with your email and I will forward you the pictures.
Old Oct 15, 2023 | 10:27 PM
CZ 75's Avatar
E63 AMG
I’m running Vorsteiner V-FF 103’s with no issues. Flow forged and run about $2k.
Old Oct 16, 2023 | 06:52 AM
e55joe's Avatar
first question-
What's your budget?
Nothingbcrazy couole thousand
Old Oct 16, 2023 | 11:16 AM
PeterUbers's Avatar
4 true forged rims with 4 new tires for $2000 will be less likely unless you're buying used.
Example (select construction->"forged" in filter):
https://www.tirerack.com/wheels/resu...4&autoModClar=
Old Oct 16, 2023 | 11:27 AM
FastWgn's Avatar
2016 E63 Wagon
Check out HRE Flowform, a bit of a hybrid approach. Strong without breaking the bank.
Have had FF01s for a season and after cracking / bending 3 OEM rims over the last few years, they are still perfect. (knocking on wood so hard my knuckle hurts.....)
Old Oct 16, 2023 | 11:40 AM
cotmfk's Avatar
On the shoulder
You may get lucky on aliexpress or something like that, but for $2k, it's going to be tough to get quality wheels.
$4,500 can get you a nice set of BCForged or similar. I've had those wheels on my cars in the past with great success, including driving in pothole filled Northeastern US.
Old Oct 16, 2023 | 08:53 PM
e55joe's Avatar
I had the RFX1 Rohana. Aren't they flow forged also?
they didnt last long not even a year out of them
Old Oct 16, 2023 | 10:24 PM
coolchuck's Avatar
2016 E63s
Yes they are flow forged. I’ve read on other forums they don’t hold up well (bend easily, some finish issues). Shame because they have some really nice designs.
Vossen hybrid wheels seem to be a good option and they usually have a Black Friday sale so you can save some money.
Old Oct 17, 2023 | 11:28 AM
brfatal's Avatar
2014 E63S AMG
Originally Posted by kenneyd
Something forged
Forged wheels are more likely to bend. The issue with cast wheels is more so cracking. Forged wheels aren't necessarily more durable than cast.
Old Oct 17, 2023 | 02:29 PM
cotmfk's Avatar
On the shoulder
I've only heard what Kenney was saying - forged is lighter and stronger. Less likely to bend. Not saying you're wrong, but do you have any links? Appreciate it. Would love not to have to spend tons on wheels...
Old Oct 17, 2023 | 04:19 PM
PeterUbers's Avatar
good article on this - nothing scientific/empiric tho
https://www.turnology.com/tech-stori...forged-wheels/
Old Oct 17, 2023 | 05:51 PM
brfatal's Avatar
2014 E63S AMG
The primary advantages of forged wheels over cast come down to manufacturing and design. By mass forged wheels are stronger. This means that you can use less material, making wheels lighter, to achieve a given benchmark of structural durability than cast wheels. While it is frequently the case, being forged doesn't mean they are stronger than cast wheels as that still comes down to the wheel design. There are a bunch of examples of this such as SSR Comp Cs, which were VERY notorious for bending, and VS Forged wheels, which have fairly low load ratings. The other big advantage is customization. A company can produce any wheel design to any specs they want machining them out of billet aluminum rather than having to make a boatload of different casts (which is $$$) to produce a bunch of different designs.
As far as bending vs cracking: Forging creates a stronger, tighter grain structure and less porosity. It takes more force to create a catastrophic failure such as a crack, so the metal is more likely to deform and bend where a porous, less dense crystalline structure of cast wheels will cause larger separation between bonds from an impact and thus crack before forged wheels would.
