Oil pump solenoids
Old Apr 13, 2025 | 02:38 PM
  #3451
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Don't forget you mentioned API SQ is coming out, and here I am still waiting for API SP x-cess gen 2
Oh boy, like waiting for a new phone to release or something. There is always something newer.
The way inventory are reduced everywhere, the newest SQ formula is going to target the masses of Toyota/Ford 1.8L 4Cyl. turbos with "gas saving" formula... the greatest burnt oil for 15kMi.
Chemical limited lubrication with dismal viscosity is not what ECU need to seal rings. Bosch will need to revamp timings computation for drafty cyl.
Old Apr 13, 2025 | 02:42 PM
  #3452
Originally Posted by KristiyanPetrov
xcess gen 2 have SN and SP
It's not really region based. It's...
old stock : SN
new stock : SP
SP formula is targeting turbo GDI with less calcium to prevent dirty engine LSPI.
When given a choice prefer SP.
Old Apr 13, 2025 | 02:51 PM
  #3453
W205C43PFL's Avatar
I will stick with SP then The API SP(ecial)/S(u)P(erior) formula.
Old Apr 13, 2025 | 02:52 PM
  #3454
W205C43PFL's Avatar
old stock : SN
new stock : SP
We humans need that calcium
Old Apr 13, 2025 | 03:18 PM
  #3455
KristiyanPetrov's Avatar
C43 AMG '17 / Stage II
We know available inventory vary, sometimes older SN, sometimes newer SP:
Prefer 5w-40 API-SP over SN in a PAO grade.
whatever it is called (clean/xcess/power).
The key is to not use effective viscosity to redline your turbo while your rings are far from sealed.
Just keep up Rpm above 2200 to keep up spraying not burning to make cleaning/sealing progress.
> NO QUICK CLEANERS...
-- A while ago we talked about CLEANERS, flushes...
Cleaning engine surfaces removes protection.
-- You don't want to stress high-output without surface protection.
-- It may be safer to go slow cleaning route...
Hence using only semi-effective viscosity for now and no harsh cleaners.
It's possible... I don't know how safe given redline habits.
then i will order power 5w40 since seems to be a bit better than a xcess
I wonder when API SQ X-Cess Gen 2 will come out
ohh.. it seems you will be 2 ish specs behind (i can't believe that you can't find it anywhere online that is avail too...)
Old Apr 13, 2025 | 03:19 PM
  #3456
W205C43PFL's Avatar
I am doing the next oil change latest October, could be earlier though, hopefully there is stock by then.
Old Apr 13, 2025 | 03:25 PM
  #3457
fingers crossed
Old Apr 13, 2025 | 04:35 PM
  #3458
W205C43PFL's Avatar
fingers crossed
I guess if there isn't I can always switch : )
Old Apr 13, 2025 | 06:11 PM
  #3459
JettaRed's Avatar
Veteran: Army
Here ya go everyone!
https://www.castrol.com/en_us/united...html#tab_5w-50
Old Apr 13, 2025 | 06:13 PM
  #3460
W205C43PFL's Avatar
*rubs eyes and glasses lens*
API SQ????
Old Apr 13, 2025 | 06:15 PM
  #3461
JettaRed's Avatar
Veteran: Army
Still, I think I want to wait until they get an MB approval. Sadly the new Castrol Edge does not come in 5W-40. That seems reserved for Castrol Edge Euro Car formulas.
Old Apr 13, 2025 | 06:20 PM
  #3462
are we gonna chase now SQ i still did not tested SP and SQ is out hahahahaha
Old Apr 13, 2025 | 06:23 PM
  #3463
JettaRed's Avatar
Veteran: Army
Not me. I'm still using SN in my C350 (only because I had Molygen 5W-40 to use). I will likely continue with the SP rated Pennsoil 5W-40 in my SL400.
Old Apr 13, 2025 | 06:28 PM
  #3464
W205C43PFL's Avatar
https://cimg4.ibsrv.net/gimg/www.mbw...2e5a8e5b56.png
Did we discuss the differences with the Euro formula and the regular one before?
Old Apr 13, 2025 | 06:29 PM
  #3465
W205C43PFL's Avatar
The good news is you don't need SP in non turbo engines anyways
Old Apr 13, 2025 | 07:01 PM
  #3466
The good news is you don't need SP in non-turbo engines anyways
Can't go wrong with "MB Appproved" lubricant right?
-- What happens to oiling effectiveness during formula transition ??
SN to SP
SP to SN
Old Apr 13, 2025 | 07:44 PM
  #3467
W205C43PFL's Avatar
SN to SP
SP to SN
For those that don't do high RPM driving, 5W-50 might be beneficial in the long run though. Which MB doesn't approve
Old Apr 13, 2025 | 09:40 PM
  #3468
CASTROL SQ: PAO ??
Nice digging! This 5W50 API-SQ is great news.
There will still be tough engine oil produced for our niche application.
Is this new Castrol trully PAO based or
a premium group-III synthetic ?
wrap sheet
wrap sheet
"3x stronger than leading full synthetic"
Castrol Edge newest SQ !!
Flash point 220C: near Amsoil 225C.
Tag line: "STRONGER FOR LONGER" what's not to like.
Old Apr 14, 2025 | 09:22 AM
  #3469
Manny_c450's Avatar
C450
I also am using the Pennzoil Euro 5w40 in the c450 (same 3.0 bi turbo m276 engine as your sl400).
I was using Molygen before but found pennzoil is much cheaper and is of good quality/cleaner from what I hear due to natural gas.
Why did you switch from 5w50 again?
Old Apr 14, 2025 | 11:55 AM
  #3470
idk how cheap is on your side but in my country 5l cost 130usd...
Old Apr 14, 2025 | 09:14 PM
  #3471
JettaRed's Avatar
Veteran: Army
I'm sure the Castrol Edge is great oil, but it did not have MB approval and I want something that is MB 229.5 approved. I bought a bunch of it, so I may use it in my 2004 Audi TT. Lots of miles on the car (>255,000). But oil has been changed no more than 5,000 miles during that time. It may benefit from the 50 weight portion.
Old Apr 14, 2025 | 09:17 PM
  #3472
JettaRed's Avatar
Veteran: Army
Here it's $46 for 6 quarts on Amazon. I've not been able to find it other than on Amazon.
Old Apr 14, 2025 | 09:25 PM
  #3473
JettaRed's Avatar
Veteran: Army
Correction: It's also at Walmart!
Old Apr 15, 2025 | 01:34 AM
  #3474
E63SAMG2014's Avatar
2014 E63 / 2017 CLS 63 / 2015 G63
Can we get a poll going for
pennzoil
motul xcess gen2
amsoil
m1
etc etc anything that is 05w40 api-sp and sn rated
Old Apr 15, 2025 | 02:58 AM
  #3475
VASTLY DIFFERENT PRODUCTS
pennzoil
motul xcess gen2
amsoil
m1
Engine oils products are like tires... they are vastly different from brand to brand and models.
5w-40 oils can get greatly oxidized with age and heat.
(full synthetic vs. PAO)
amsoil /motul /...
m1 /pennzoil /...
I noticed that true PAO synthetic oils are never cheap.
You have already rated this thread Rating: Thread Rating: 14 votes, 4.29 average.
