Oil pump solenoids
#576
Best way would be to measure the resistance of the solenoid directly. Probably easiest on a V6 or for somebody using a pigtail to plug the connector, just because it would be difficult getting probes on the pins from what I remember from disconnecting mine.
Regarding resistors, some of those "anti hyper flash" ones for upgrading to LED turn signals may be an option. Low resistance, but could be wired in series. Use the other side of one of the pigtails and it should be a plug and play solution once we know a target resistance.
#577
Received 3,365 Likes
MY'14 W212 M276 3.5NA @55kMi
SOL POPPED A CEL....
For me any resistor bigger than 1W calls for a more practical solution. I am not into roasting plastics...
If you don't like to use a bulb, then wire up the coil of a spare relay.
The lower limit may be 150mA, it's a pulsed digital voltage from 10 to 90% duty.
This dummy load only useful if a specific range of ECU pop CEL... perhaps these ECU use reverse logic we don't know about. "Power needed to shut solenoid" ???
Don't make the wrong assumption to disregard what you don't know (I don't know that for sure either).
If i were you... I'd keep that all factory plugged until you can confirm how your engine controls interacts with your oil pressure.
And while at it perhaps we can all understand why your engine has CEL this mod....
#578
Received 2,031 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Or can you buy another solenoid and plug the engine harness into this ... and leave it dangling or zip tied ... the OEM solenoid will remain unplugged
#579
There is a harness inside the timing cover/oil pan... I am not sure the connector of solenoid and the external connector style will match without internal harness... 50/50, right?
#580
I'm away from my desk with WIS. Wondering if anyone can help find the part number
#581
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
I think a good way to get through this is to look for a P06DA00 via OBD-2 generic. It should NOT appear there, but if it does, you have a "lucky" ECU....
zk2004mb, please check for codes via OBD-2 generic mode and report back.
#582
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Received 1,601 Likes
#583
278-180-04-15 appears to be the solenoid. Actual picture of the part here: https://www.autohausaz.com/pn/MB-2781800415
It appears the solenoid should plug directly into the external harness without the need for the internal intermediate connector.
The internal connector is listed as individual pieces with a housing part number of 029 545 10 26. Scrolled back through this thread and found that matches the housing that plugs into the outside of the timing cover.
References: EPC section 18-015 (engine lubrication->oil pump), post 484 in this thread.
zk2004mb (12-27-2023)
#584
#585
Getting to the Root....
My brother in law just bought a 2017 GLS550 with 131k. M278. Thing runs flawlessly. I helped him unplug but he has a P0496 evap code (which he probably caused by not tightening the gas cap). Chasing that will make it tough to immediately notice if unplugging is causing a CEL.
"Unplugging oil pump control solenoid triggers CEL in M157
-- Perhaps the crankcase or intake pressure upsets some of ECU expectations. Perhaps the engine came equipped with an optional oil sensor. Something's different!!
-- Based on all known reports thus far, ECU does not CEL open solenoid circuit.
-- Let use a reputable scanner (Xentry, Launch, ...) with a solid scan of at least the ECU.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
#586
Let's try to get to the bottom of this issue for our collective interest:
"Unplugging oil pump control solenoid triggers CEL in M278 MY'15 S63-Coupe ".
I could be totally wrong with the conclusion from the inferior scanner.
Also, it's m157 not m278
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
CaliBenzDriver (12-27-2023)
#587
#588
In the OBD2 generic menu, there are 3 components, engine, AT and FPCM-FuelPumpCtrl.
There is only one code found in the engine category which is P06DA. The rest of two categories passed with no problem.
#589
Forking self-help path....
Thank you for pointing that out Peter ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
We can say that some ppl with M178 and 4Cyl have reported an active CEL from faulty pump solenoid circuit.
That's interesting!
Again I would recommend not to disconnect factory systems hopping nothing's changed. Bosch excels at managing zillions of different options. Who knows what combination they wanted to test ?![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
I'd recommended to open a thread under affected chassis forum or in Tech Talk... then we can try to help with specifics.
Here is a course of actions:
-- check live oil pressure activity
-- check solenoid linked to DTC
-- Test dummy load (bulb or solenoid)
Outcome CEL is reworked to be bypassed.
That's interesting!
#590
If this is the case, then simply plugging in a dummy solenoid will not remove the CEL.
The following 3 users liked this post by ImolaSix:
#591
different bones...
Go ahead and create a new thread under your own chassis forum.
We'll try to help you remove all the bad to enjoy nothing but the good.
#592
https://mbworld.org/forums/mercedes-...es-me-cel.html
CaliBenzDriver (12-28-2023)
#594
Do you happen to know the part number for this harness? Just confirming it is 2711 500 156
https://www.fcpeuro.com/products/mer...des-2711500156
Thank you!
#595
#597
Tasos has spoken:
#599
#600
So His take is a healthy engine could have accelerated wear due to cold weather start-up stress in a cold climate when unplugged.
