Oil pump solenoids
Old Jun 24, 2024 | 01:43 AM
  #1951
S-Prihadi's Avatar
Originally Posted by gumsie
I'm surprised that Petronas isn't listed here given they were an MB F1 sponsor.
You need to scroll down more...........
Old Jun 24, 2024 | 03:02 PM
  #1952
gumsie's Avatar
AMG CLS63S SB.
Ah, Ok. Yah - I see.
Old Jun 24, 2024 | 03:32 PM
  #1953
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
I have not read one good argument for why 229.5 is critical, especially with good used oil analyses from non-229.5 oils (including good old Rotella T6).
Old Jun 24, 2024 | 03:46 PM
  #1954
JettaRed's Avatar
Veteran: Army
Because it is made with Mercedes-Benz Kool-Aid! Duh! 🙄
Old Jun 24, 2024 | 07:16 PM
  #1955
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
ROTELLA SOLID VISCOSITY
That diesel Rotella T6 has outstanding results with pristine strong viscosity after 10kMi abuse.
Not the oil type that rushes to be W30: real protection insurance to go the distance.
Now about the high ZDDP... it could be fine as long as engine doesn't ingest oil, cats/lambda won't see much of it, right?
ZDDP is so effective that I was thinking about running T6 next but I don't want to stray from my already unusual path to help reproduce results.
I might give this T6 a shot next year not to introduce too many variables ​​​​​​
Old Jun 26, 2024 | 04:35 PM
  #1956
Holtgraver's Avatar
2021 E350 Sedan
Not sure if this is relevant to this thread, but skimming above, I got the impression that the engine problems went away on the 205 with the 2019 model. Perhaps not..
Another 274 engine problem: Car is 2019C300 4MATIC with 51,200miles. Just had a major repair of the engine to replace the "Directional Oil Valve". I think it's in/near the oil pump. The Check Engine Light came on solid, and I took it to dealer right away. They had to disassemble nearly the entire front end: frame, suspension, steering, axles, engine mounts, ... I purchased the car on 12/07/22 and bought the extra 2 years of warranty for $2745. This repair would have been about $3,100 if I had not bought the extended warranty.
If you like the W205, I'd wait until I found a 6 cylinder version. Here's some data from Wiki:
https://en.wikipedia.org/wiki/Merced..._C-Class_(W205)
Old Jun 26, 2024 | 06:05 PM
  #1957
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
I would not call it KoolAid, though I agree to some extent. The MB spec is a variation of the EU spec.
The important part to me, is the comment from Lake Speed Jr about the "package" since the " package" is based on what the oil encounter: alloys, surface finish, coatings, ring design, etc.
As I have mentioned before, the advice I got from a trusted provider of components to several high end automotive manufacturers was: higher oil pressure can only help, just be careful not playing with oil package. The oil, the engine, and several components are "tuned together". Whatever that means is to anyone to interpret
Old Jun 26, 2024 | 06:32 PM
  #1958
serviced back to stock...
This is excellent Mercedes service done by the book.
Now your engine managed oil pressure is back in stock MOD-0 condition.
You can regain all the fuel savings with the advanced 0W-40 lubricant.
Old Jun 26, 2024 | 08:11 PM
  #1959
JettaRed's Avatar
Veteran: Army
...Another 274 engine problem: Car is 2019C300 4MATIC with 51,200miles. Just had a major repair of the engine to replace the "Directional Oil Valve". I think it's in/near the oil pump. The Check Engine Light came on solid, and I took it to dealer right away. They had to disassemble nearly the entire front end: frame, suspension, steering, axles, engine mounts, ... I purchased the car on 12/07/22 and bought the extra 2 years of warranty for $2745. This repair would have been about $3,100 if I had not bought the extended warranty.
The 6 cylinder version would be a C400 or C43 AMG. (Did they make a C400?). I'd also like a little more information regarding the "Directional Oil Valve". What exactly is it? Is it a check valve? Did they give you the codes for the CEL?
Old Jun 26, 2024 | 08:13 PM
  #1960
kevm14's Avatar
C450 or C43. From memory the C450 was 2016 only and then 2017+ was the C43.
Old Jun 30, 2024 | 10:45 AM
  #1961
S-Prihadi's Avatar
Guys,
TEST in progress :
Piston Cooling Oil Spray Nozzle opening pressure
at : https://mbworld.org/forums/e-class-w...-pressure.html
Old Jun 30, 2024 | 10:50 AM
  #1962
W205C43PFL's Avatar
Guys,
TEST in progress :
Following!
Old Jun 30, 2024 | 11:26 AM
  #1963
W205C43PFL's Avatar
Yup correct, C 450 was only available as a 2016 model year until they went full two digital nomenclature in the form of C 43 for model year 2017 and beyond. Obviously not to be mistaken with the W202 C 43.
The C 450 is pretty much identical to the C 43 other than the C 450 not having a few stuff like (When I meant C 43 in this comparison, I only meant the W205 pre-facelift C 43, the facelift C 43 has many cosmetic changes which I outlined here: https://mbworld.org/forums/c450-c43-...ml#post8858401)
The C 450 was called Mercedes-Benz C 450 amg sport
The C 43 was called Mercedes-amg C 43
The C 450 was available in Dakota Brown (796) while the C 43 never had that option (if I recalled correctly)
The C 450 doesn't have the amg badge in the tachometer but still gets the checkered flag style.
The C 450 has an amg badge on the fenders while the C 43 has biturbo and 4Matic.
The diamond grille of the C 450 does not have the amg badge while the C 43 has one, similar to the diamond pin grille of the pre-facelift AMG GT.
The C 450 has the amg and C 43 badge in the rear while the C 450 has the C 450 and 4Matic badge.
The C 43 has amg on the engine cover while the C 450 doesn't although early C 43 production models doesn't have it either.
The C 43 has a performance exhaust option and the C 450 doesn't.
The C 450 has the amg speedshift 7G Tronic+ while the C 43 has the amg speedshift 9G Tronic and the non amg speedshift base transmission first appeared on the W213.
I think the suspension of the C 450 was softer than the pre-facelift C 43, the facelift C 43 suspension was a huge improvement.
The C 450 calipers have Mercedes-Benz while the C 43 calipers has amg badging.
The C 450 doesn't get the amg screen with the oil temperature, transmission temperature, boost etc. but was available after an update.
The C 450 doesn't have a boost sensor if I recalled correctly so even after having the amg screen, that boost meter never works.
The C 450's infotainment startup amg logo is different to the C 43.
The C 450 shares the same brakes as the C 43 just the caliper lettering is different.
The C 450 might had came with red seat-belts standard.
The C 43 steering wheel also got an amg badge
The C 43 had access to the amg private lounge the C 450 didn't but was also opened up later on.
I forgot if the C 450 had amg branded floor mats but amg line C 300 had it so I would think it did too.
I forgot if the C 450 illuminated door sills have amg or Mercedes-Benz.
If I recalled correctly, the C 450 called it Agility select while the C 43 called it Dynamic Select for switching drive modes.
Those are the differences I observed after comparing the two vehicles back then. I might had missed something though.
Personally, what the C 43 sold me over the C 450 was the performance exhaust and the performance not the amg badge. I rather it didn't have an amg badge because it would had been cheaper in both insurance and maintenance. amg tax is a real thing. I also rather it was kept as C 450 because the W202 C 43 was if I recalled correctly one of MBs' first AMG plus that had a V8 but that's story for another time. Other than that, I love the C 43, main thing I love about it nowadays really is the fact it has a M276.
The C 400 is basically a C 300 but with the M276, the horsepower is less than both the C 450 and C 43. The C 400 doesn't have the slotted/divided exhaust tips (I know it is fake) as the C 450 and C 43.
Despite the C 450 not having performance exhaust, it still sounded somewhat different to a C 400.
Well, back on topic for a second, this oil pump solenoid mod is awesome : )
Old Jun 30, 2024 | 12:25 PM
  #1964
slobo's Avatar
X218 CLS500 4-Matic 9G-Tronic / X204 GLK250 CDI 4-Matic 7G-Tronic
I think you only made a small mistake. As I could remeber, the C450 has a standard 7G Tronic Plus. There was never a Speedshift Transmission. Maybe the C450 AMG had a little faster shifting time, but the transmission was never a Speedshift. But I could be wrong, It's a few years since it was actual.
Old Jun 30, 2024 | 12:28 PM
  #1965
W205C43PFL's Avatar
I see, will happily stand corrected if that is the case.
Old Jul 1, 2024 | 12:24 AM
  #1966
PeterUbers's Avatar
clarified here
https://mbworld.org/forums/c-class-w...g-tct-mct.html
and here
https://media.mbusa.com/releases/rel...450-amg-4matic
Old Jul 1, 2024 | 06:43 AM
  #1967
slobo's Avatar
If I understood correctly, I was right. Or not?
Old Jul 1, 2024 | 08:08 AM
  #1968
JettaRed's Avatar
Veteran: Army
I did not know this. I have the @BenzNinja tranny upgrade that adds Sport+/Agility mode to my 7G Pluss transmissions. I think I will test it out to see if it works on my non-AMG transmissions. I know previously, when in M mode, the transmission would still automatically shift when about to stall or at redline.
Old Jul 1, 2024 | 08:16 AM
  #1969
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Mine does shift (well, I have not pushed it THAT far)...on my old E46M3 (SMG) it would let you blow up the engine bouncing off the rev limiter.
Old Jul 1, 2024 | 08:20 AM
  #1970
W205C43PFL's Avatar
Appreciate this, I looked it up more out of curiosity: https://mbworld.org/forums/c-class-w...ml#post8994600
MB is pretty conflicting what they want to call that transmission.
Old Jul 1, 2024 | 08:21 AM
  #1971
W205C43PFL's Avatar
I believe you are right because other than the ordering guide, no further material mentions speedshift in the C 450 transmission.
Old Jul 1, 2024 | 08:25 AM
  #1972
S-Prihadi's Avatar
Mine is 7G Plus tranny. The M mode will shift upon redline and will downshift when engine RPM too low aka bogged down.
If MB does not allow shift up in redline in M mode, it will then need to cut fuel like oldie manual car with EFI when over-revved....otherwise engine will suffer.
  #1973
TomZVB's Avatar
R231 SL 63
It’s boat season (as well as audit season, ugh) for me so I have not been paying attention to much else.
Glad to see there’s still a lot of chatter!
I’m due for my B service according to the IC - will be switching over to a 5W50 during service.
Old Jul 1, 2024 | 02:36 PM
  #1974
AMG__POWER's Avatar
2024 c300 , 2006 E55, 2005 e320, 2007 gl450, 2025 glc300, 2025 e450
I saw some posts in the thread regarding coolant temp fluctuations from the dash screen to real time. Here is my findings after data logging today in 78-83 degrees, driving on open highway around 80mph I was about 12-13 over the mb coolant screen and in traffic as high as 23 over.
Old Jul 1, 2024 | 03:10 PM
  #1975
W205C43PFL's Avatar
amg vehicles will cut fuel as you mentioned and not shift if in manual mode.
That got me curious, since you mentioned over-revving, reminds me of this I came across on someone's car that was over-revving, it looks very bad I wonder what happened, why is the ECU allowing the car over-revving. https://mbworld.org/forums/c-class-c...-problems.html
You have already rated this thread Rating: Thread Rating: 14 votes, 4.29 average.
