Hello it’s my first time getting after market wheels and i need help!
Old Nov 24, 2024 | 11:48 PM
mjsal's Avatar
I have a 15 E63s Wagon
will any of these fit:
Set 1:20x10.5
ET 45
20x9.5
ET13
Set 2:
Fronts are 20x9.5
Offset 28
Rears are 20x10.5
Offset 32
Thank you.
Old Nov 25, 2024 | 10:31 AM
Cla1111's Avatar
2015 E63 S
Did you trying using this site:
https://www.willtheyfit.com/index.ph...0.5&offset2=32
For reference, for my sedan the standard sizes front and rear are:
F: 9Jx19 ET37
R: 9.5Jx19 ET52
Also to give you an idea, I currently run a square setup 9.5Jx19 ET35 and I don't have any problem.
Old Nov 25, 2024 | 10:38 AM
rwt14's Avatar
2014 E63S AMG
F: 9Jx19 ET37
R: 9.5Jx19 ET52
I run the exact same setup. No issues for me either. One thing is that the front wheel is now closer to the strut, so if your tires are too wide up front, you may rub.
Old Nov 25, 2024 | 11:15 AM
Cla1111's Avatar
2015 E63 S
Not only to the strut. I have noticed that my front wheels are just few mm clear of the fender liner when turning left/right. I don't think you can push them more than that in the front. My tires are 255/35R19.
Old Nov 26, 2024 | 02:47 PM
brfatal's Avatar
2014 E63S AMG
Neither of those will fit properly. The fronts are waaay too aggressive on the 1st set and the rears too aggressive on the latter set. That's without taking into account brake clearance.
Old Nov 26, 2024 | 02:50 PM
mjsal's Avatar
would those fit?
would those fit?
Rear 20x10 Offset 38 Front 20x8.5 Offset 30
Old Nov 26, 2024 | 03:23 PM
brfatal's Avatar
2014 E63S AMG
Originally Posted by mjsal
would those fit?
Fronts will but the rears will poke. Again, that's without looking at whether the front wheels will clear the brake calipers. For reference, this is 9.5" +45:
Old Nov 27, 2024 | 11:35 PM
Rehabguy's Avatar
E63S
Set 1:20x10.5
ET 45
20x9.5
ET13
Set 2:
Fronts are 20x9.5
Offset 28
Rears are 20x10.5
Offset 32
Thank you.
Set 1. Rear specs will work with maybe a 285/25/20. Front Et is too low. I have seen ET18 done with stretch tire and it looks "unpretty" IMO.
Set 2. Front will work fine with 255/30/20. Rear is too aggressive.
