Lean long-term fuel trims at idle
Old Feb 20, 2025 | 01:16 AM
Matermerc's Avatar
2014 E63 AMG S
Before I go digging into the car or get time that is, just wondering what are some common places for vacuum leaks that could cause this lean condition. When coldish the ltft start at around 6-8. and once warm get upto 16-18. close to setting a check engine p0171 code. Its not quite there yet but i think it may be on the horizon. Do the pcv fail on the m157 similar to some other european make and models? do they have a similar effect and cause lean conditions and lean codes? let me know if anyone has ran into something similar. car has 78k miles now.
Old Feb 20, 2025 | 08:38 AM
JettaRed's Avatar
Veteran: Army
To be clear, you are saying that cold start LTFT is ADDING 6-8 percent fuel, and warm operation is ADDING 16-18 percent?
I don't see PCV listed, but a faulty valve could introduce unmetered air and cause a lean condition.
Old Feb 20, 2025 | 08:04 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
I think these lean trims are the incarnation of lag.
Little by little the ECU closes towards random misfires, then steady misfire...
If OP recognize lag in throttle response, there's a fix for that... no parts needed.
Old Feb 20, 2025 | 08:31 PM
Matermerc's Avatar
2014 E63 AMG S
It’s not lag. LTFT I stated were at idle. When cold and get worse as it is fully warmed up. Just trying to see if anyone here has ran into lean codes and what their fixes were. From what I see lean only at idle is usually some sort of vacuum leak or dirty worn maf sensors but not leaning toward maf since both would be very unlikely to go out at the same time. I’m strict about changing airfilters and only using Mann paper filters. I’m not into using kand n style due to poor filtration and don’t like the thought of ingesting dust on a motor with delicate cylinder walls like the m157. Thats just me though. Anyways, let hear from anyone with lean codes and what your fixes were. I can’t be the first one
Old Feb 20, 2025 | 08:44 PM
lean engine but not laggy
Ok you have lean engine without lag.
​​​​​Definitely not spark related as engine is combusting satisfactorily.
Normally a cold engine is richer than in closed loop, yours is still too lean... then low fuel supply.
Are both bank LTFT nearly equal or normal with only one offset?
Old Feb 20, 2025 | 09:36 PM
Matermerc's Avatar
2014 E63 AMG S
Both banks are very close to each other in terms of fuel trims.
Old Feb 20, 2025 | 09:57 PM
So that bails out a lot of unnecessary work.
A lot of fresh parts would not hurt but then, would do nothing to fix this either.
Can you read tank fuel pressure both at idle and under acceleration load.
What's current mileage?
