Square wheel setups on S212 E63s
Old Aug 13, 2025 | 01:13 PM
Rickflair01's Avatar
2015 E63s
Any square wheel setups that folks are running? I'm looking at a set of Apex forged wheels and daily drive to the tune of 20k miles per year and would be interested in rotating tires to get a little more life out of them. I have the attached options and have to run a 5mm spacer with the Apex wheels if I want to run the center caps. I am running stock suspension. Thanks in advance for any help
Old Aug 13, 2025 | 01:52 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
My W212 2011 has 19's on all four corners for that very reason...when I get back home I will check the size. It was a HUGE PITA to find a wheel that would fit over the calipers, fit the offset and fit front and rear.
Old Aug 13, 2025 | 02:05 PM
2015 E63s
Thank you
Old Aug 13, 2025 | 10:14 PM
Rehabguy's Avatar
E63S
I remember these from a few years ago... Hope this info helps:
F & R : 19x9.5" ET35 with 265/35R19. Camber plates up front "that make this rub free"
20x10 et 35 all around. Tires are contisport 275/30/20
Old Aug 14, 2025 | 04:16 PM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
@Rehabguy
I was just about to post your car with the TE-37s
Old Aug 14, 2025 | 04:36 PM
I forgot to look, I also forgot that the front has shim/plates in it (I think) I have not messed with that car in so long.
Old Aug 14, 2025 | 10:34 PM
Rehabguy's Avatar
E63S
Originally Posted by thesaintusa
@Rehabguy
Not my car. That wagon belonged to a dude who went by "Jimmez" up in Canada. He owns/works at a shop up there and he played around with wheel set ups a lot. He def. had good wheel fitment knowledge on W212s.
Old Aug 14, 2025 | 10:36 PM
My bad you are right.
Old Aug 15, 2025 | 03:00 AM
ThreeSix's Avatar
G550
19x10+33 squared with 5mm spacer up front
Old Aug 15, 2025 | 06:58 AM
2015 E63s
What wheels are those?
Found it in one of your previous posts. Those look sharp.
Old Aug 15, 2025 | 07:50 AM
FastWgn's Avatar
2016 E63 Wagon
@ThreeSix - why debadge and then get personalized plate with E63 WAG? Sort of defeats the purpose? Just curious.
Old Aug 15, 2025 | 11:18 AM
ThreeSix's Avatar
G550
19x9.5+25 squared Apex VS5-RS. Front has 5mm spacer up front making it a +20 in order to run center caps. 265's all around
Old Aug 15, 2025 | 11:20 AM
ThreeSix's Avatar
G550
and here's some in 20" fitment
Old Aug 15, 2025 | 11:48 AM
2015 E63s
Is that actually your car? I saw those pictures with the clear silvers on their website.
And no rub? Looks like rears are close.
Thank you
Old Aug 15, 2025 | 11:58 AM
ThreeSix's Avatar
G550
Thank you
yes, this was my car. I worked with Apex to get some fitment options for our platform.
There was zero rub in the rear, no fender modifications at all.
Old Aug 15, 2025 | 12:03 PM
2015 E63s
Thank you. When I reached out via the web I just got a reply of "you can find some fitment options for that platform on our web site." There are actually quite a few options but wanted to talk it through with someone. Appreciate your responses.
Old Aug 15, 2025 | 10:54 PM
Jaybird123's Avatar
2015 E63S Sedan, 2014 E550 Coupe, 2013 E350 Wagon
What tire profile? 265/30 or 265/35 on these? Looks sharp btw
Old Aug 17, 2025 | 12:22 AM
ThreeSix's Avatar
G550
the tires were 265/35R19 Falken RT660, which run a bit wider than your typical Michelin Pilot Sport 4S in the same size
Old Aug 27, 2025 | 10:38 PM
Elevated's Avatar
e63s
Love this wagon! Ive seen it on an Apex promo video! What are the wheel specs for a 20" set up? I may run down this same route!
Old Aug 29, 2025 | 05:12 PM
alpinaturbo's Avatar
E63 Wagon
I run 19.9.5 ET50 all around with 20mm spacer up front, still left the 285/30x19 on rear off old wheels and put 265/35x19 up front. I reduced front camber form -2, to -1.7, and got tiny bit of rubbing on a not-rolled little big of front fender just by the bumper: will roll that section.
Next is to try 285/30x19 on the front, same Michelin 4S as current 265s.
I will have to measure the front fitment, to find the right spacer size to use to clear strut and fenders.
I am undecided on 19x10s.
I was meaning 265/35x19 square, hence 19x9.5
After fitting 265, I still found it is "front traction limited" in hard cornering, so will try 285 on 9.5, and research to see if 10" will give significantly better better support to 285 to benefit front side-bite-traction or not.
10" wheel is heavier, and I have to purchase again, both negatives. Current wheels are 19lbs each, so reduced unsprung weight - which in all honesty I did not feel. Yes, I expected change in feel, there was none. But front end grip is UP by stepping from OEM 255/35 on 9" to 265/35 on 9.5", say 10% up. I need last 5%, maybe 285 on 9.5 will do that, to get it totally front to rear balanced, for backroad. bombing on California Mountains-Canyon roads.
Old Sep 11, 2025 | 04:48 PM
macavant's Avatar
W212 E63 Estate | E90 M3 |4L Q7
Thanks for sharing @ThreeSix - your setup looks awesome.
I'm looking to get the ML-10RT in the ET25 (ET20 with the caps).
Do you get rubbing in the front with your +20 setup? TIA
Old Dec 27, 2025 | 11:39 AM
boosted305's Avatar
broom
Damn that looks GOOD! Are these the same +25 Rear and +20 Front as the 19's?
Old Dec 27, 2025 | 11:45 AM
RVAE34's Avatar
S212/M5T/Z31/240Z/3rd gen Tacoma
Damn, those 20's look better than expected on the wagon
