water pump replacement
Old Sep 4, 2025 | 07:36 PM
Mr. CVE's Avatar
MY06 E55
My 212 E63s has a leaky water pump.
initially a plastic pipe was leaking, so changed that, and now it is the water pump itself.
It is NOT the turbo hoses, as I checked them.
It is dripping from the bottom of the water pump.
I know this is not a fun job.
I am trying to prepare for this, and starting a prayer list to ALL the gods !!
I was looking to swap the turbo pipes ( plastic parts only and put a rubber hose between the old aluminum pipe and the new plastic pipe .
Any suggestions ?
I have a new water pump
I have a new plastic thermostat.
Anything else that will be expected to break while I am there ?
And any suggestions ?
I can't seem to see how to get access. I did the plastic pipe before, but even if I could remove the fan, that would be a help.
Does the fan need to be out ?
Old Sep 4, 2025 | 07:40 PM
PeterUbers's Avatar
From the sticky under section "fluids"
https://mbworld.org/forums/w212-amg/...king-m157.html
and the sticky
https://mbworld.org/forums/w212-amg/...fixes-diy.html
Old Sep 4, 2025 | 08:26 PM
Mr. CVE's Avatar
MY06 E55
Thanks for that, on all the ones I read they seems to change the whole turbo water pipes.
Not sure if my car is different ( Right hand drive ) but getting to the turbo end of the water pipes seems impossible.
I am sure I read somewhere that they left the aluminum part on the turbo and cut the plastic off and did the same to the new pipe and fitted new plastic end to the pump and made a small hose joiner with hose clamps.
cant seem to find it any more. anyone done this ?
Old Sep 5, 2025 | 08:17 PM
Jaybird123's Avatar
2015 E63S Sedan, 2014 E550 Coupe, 2013 E350 Wagon
It’s not impossible to reach them, but it is definitely a PITA! I’ve done it a few times on two different W212’s. You need a very specific thin long ratchet and you will likely bleed/yell/cry. Don’t forget to do the oil filter housing gasket and the spring-loaded piece on housing. How many miles on your engine?
Old Sep 5, 2025 | 11:21 PM
Mr. CVE's Avatar
MY06 E55
100,000 miles
which is the spring loaded piece ? will look it up and order those parts now
Old Sep 6, 2025 | 07:41 AM
Jaybird123's Avatar
Apparently it’s called oil filter housing thermostat cap…plastic circle with locking tabs and o-ring. Costs roughly $20, hopefully attached a pic below
Old Sep 6, 2025 | 08:06 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Fan does not need to come out. It has not been mentioned on this thread but I also would simply replace the plastic section of the hose for the driver side turbo with a rubber hose. Couple different threads reference the exact Goodyear brand hose that you can use. No matter what, every fitting every plastic piece and every other cooling hose in that region you will be replacing.
Old Sep 6, 2025 | 10:39 PM
Mr. CVE's Avatar
MY06 E55
thats what i want to do, can't find the threads about it.
Old Sep 6, 2025 | 10:41 PM
Mr. CVE's Avatar
MY06 E55
why do you suggest replacing this ? does it need to come out ? or just do it while you are there. my car has done around 120,000 miles.
Old Sep 7, 2025 | 05:09 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
https://mbworld.org/forums/w212-amg/...e-upgrade.html
but as mentioned you’re gonna need to replace all of the plastic you come in contact with. This means you will have to buy new hoses in order to get the new plastic connectors to then upgrade and modify. Plastic fittings are not available separately in the aftermarket.
Old Sep 7, 2025 | 06:14 AM
that was my thread I can track it down at some point this morning.
Old Sep 7, 2025 | 01:15 PM
PeterUbers's Avatar
it's in the sticky
https://mbworld.org/forums/w212-amg/...ml#post9177689
https://mbworld.org/forums/w212-amg/...coolant-2.html
