*Love your curves and all your edges...Are they crazy or am I out of my mind?*
It all started innocently enough. I took the car in for new Pirelli's, which included a "multi-point inspection." The dealership then emailed me an "urgent" alert recommending new brake pads front and rear—3mm left on the rear, 4mm on the front. A steep but manageable $2,000 quote.
Then came the sucker punch. After I brought it in for the brake job, the service advisor called with an update: "Your rotors are at minimum spec, and they're going to squeak like crazy if you don't replace them." Now, the same job is suddenly an $8,704 quote!
For a standard brake replacement? $8,704?! Are they crazy, or am I out of my mind?
I've put the brakes on this outrageous charge, but I can't shake the feeling that I was just upsold to the point of absurdity. This went from a routine service to a wallet-draining financial crisis in a matter of hours. The thought of my car getting unnecessarily torn apart and paying nearly $9k for a brake job makes me sick.
Has anyone else experienced something this outrageous at a dealership? What would you do in my position? Please tell me I'm not the only one.
I sourced all Brembo discs and pads over the internet and paid a total of 700.-, including wear contacts. Front discs have the better and lighter aluminum hats too.
Install is easy, if you're handy with basic tools.
Oh, and that dealership did not want to sell you brakes. They wanted to sell you a new car.
check out brake section in our sticky:
https://mbworld.org/forums/w212-amg/...fixes-diy.html
typical dealer up charge
https://mbworld.org/forums/w213-amg/...ures-rant.html
https://www.facebook.com/watch/?v=11...ty=CarWizardFB
https://mbworld.org/forums/w213-amg/...e-shocker.html
https://www.reddit.com/r/AMG/s/xF6mYw96lP
Usually you can do two set of pads for each set of rotors. At 58kk mile on (I assume) stock pads you are highly unlikely to be at rotor minimum thickness.
New set of pads will rapidly conform to the old rotors. Do what's called a bedding in process - described here: Zeckhausen - he knows brakes EXTREMELY well
Then find an indy mechanic, and for the next set of pads you can then have them do rotors as well.
As others have said - if you are at ALL handy this car is super easy to do brakes on because of the construction of the calipers. Good luckl!
You can see this easily on the FCP Euro site ($405 for the front Brembo part and $1676 for MB, $169 for the rear Brembo part and $339 for the rears). Same exact parts.
Brembo front:
https://www.fcpeuro.com/products/mer...mer-2124210512
Mercedes front:
https://www.fcpeuro.com/products/mer...des-2124210512
Brembo rear:
https://www.fcpeuro.com/products/mer...mbo-09-a822-11
Mercedes rear:
https://www.fcpeuro.com/products/mer...des-2124230412
Buy stuff at FCP euro and if you can't do it yourself, just take it to a Good Indy who could knock this out in under 2 hours.
What's this car worth really, $25,000 or something like that and with $9000 that's like 35% of the car's retail.....
Heck no --- Get it outa there.
I just followed the instructions posted on this website which were very helpful/accurate all that is needed.
Parts off the internet were a fraction of what a dealership would want. I went with OEM rotors and EBC Red pads.
