RENNtech E63 S AMG 4MATIC+ ECU Upgrade 773HP | 778 LB-FT
is proud to release their ECU Upgrade
for the 213 - E63 S AMG 4MATIC+
Maximum Power Output:
773 HP 778 LB-FT @ crank
665 whp 669 wtq @ wheel
Gains up to: +82 HP +84 LB-FT
0-60 mph: 2.79 sec
0-100 mph: 6.61 sec
60-130 mph: 8.27 sec
1/4mile: 10.88 sec @129 mph
*Performed on non-prepped asphalt and with OEM, Street-Legal and/or Non-Performance tires.
Data measured with Racelogic Performance Box.
*Note: Mercedes M177 engine performance when measured on the dyno obtains higher power numbers than rated from factory. Performance numbers published by MBUSA are a calculated average within a specific rpm range, which obviously result in lower power numbers than at the peak. HP and TQ gains calculated by RENNtech are always based on peak stock results measured by RENNtech and upgraded peak results measured by RENNtech.
There are ways to do things and there are ways to do things. I may have my selling dealer do the Renntech work on my car. They may or may not turn their head if a real issue pops up in the future. According to Renntech they are only supposed to charge the web pricing listed on their website but there's no 100% guarantee on that either.
as you said the reality is bleak for a customer ... you will be status 8 if a tune is detected on your ecu
why dont you look up what status 8 means....then report back to me
ill start the search for you
https://mbworld.org/forums/c63-amg-w...ty-voided.htmlm
https://mbworld.org/forums/w212-amg/...tech-tune.html
595 HP at the wheels?????
I though the crank numbers were 603 hp & 624 tq. There's no way in hell that's right. That means Mercedes massively underrated their E63.
So when I see happy dynos, I only judge the gains from the start to finish... thats key as you know. I have no doubt my car will dyno less than 595 which doesnt make it any slower just means a different dyno to your point.
It just makes me smile when I see vendors posting numbers that seem totally unrealistic with ridiculous prices for the same peak power you can get for half the cost..
Much like the lowering module for $1,400.00 when you could have a shop that knows what they are doing do it for $400.00 in less than an hour without screwing with the electronics..
Oh yeah and when vendors post products but won't post the price. I would never even call those venders, seriously what's the secret ?
Personal preference clearly but I moved from links to the modules and tires are lasting longer. Either way, it makes the car look better
numbers based on stock car? Stock performance exhaust? Without downpipes? What about future updates from MB or when I send my car in to the dealership can it be detected if I don’t revert tune back to stock? Or would I have to set it back to standard send the car in and reflash the tune again after collecting the car. I assume it’s a flash ..or is it an ecu replacement that I will have to physically remove and install back stock ecu
also regarding the lowering module..after installing via obd does height adjust automatically based on dynamic selector mode e.g comfort sport sport plus race? ( normal / low /lower/lowest) And I assume the module doesn’t have to be permanently plugged in once the files has been transferred right? Just a one time flash and I throw it away since it can’t be married to another vehicle
thanks
0-60 mph: 2.79 sec
0-100 mph: 6.61 sec
thanks
Our ECU Upgrade is a software flash of your OEM computer. You'll need to uninstall your OEM ECU computer and send that to us for the flash.
If you go to a MB dealer and he installs a new update, the ECU tune will be gone. In that case, just send the ECU to us and we'll flash it with our Upgrade for free.
Correct, the factory adjustments of the suspension still works, now based on the new lowered settings.
No, it doesn't need to stay plugged in. You plug the module in the OBD2 connector, it reads the old and writes the new software and turns from red to green in a few seconds. The module then can be unplugged and the car will adjust to the new settings after you turn on the engine.
Yes, the Module will be married to your car, however we do not recommend to throw the module away! You'll still be able to load settings with different height adjustments onto the module, in case you want to change/adjust it in the future. You can change the settings as often as you want via a PC or android app (iOS is in development).
I personally do not think that the Renntech lowering module is a bad deal. It's super easy to use and adjust and it is very non-invasive.
Unlike the older lowering modules that required that you install and wire a new module, this one is very easy. The only negative thing about the Renntech lowering module is that it is married to the car. I would be amazing if you could put it back to stock and then it gets divorced from the vehicle so it can be used on another vehicle.
I also do not think the price is that cost prohibitive for this car. The car is over $100K and the Renntech price tag is actually not that bad. It is also great for a customer that wants to install it themselves because it is very easy for them to do.
I have installed 5 of them at our shop and have been pretty happy with the results and the customers have been happy as well. I could have easily sold them on the links too but the module is what our customers were interested in.
Paying the ridiculous because ya got a Mercedes Tax is just a fools tax...
My old E500 is lowered with about $1 worth of washers that fool the sensors into thinking the suspension is riding too high, thus lowering it.
The market dictates the price, that easy. If another company comes out with a product that is as good/easy and therefore creates competition, they'll need to adjust their pricing. Until then, they can charge whatever they want and sell enough of them....
