handheld lowering module
#76
Just received my handheld lowering module for my E43. I put together a quick video showing how easy and fully customizable it is to use, you can set any ride height in mm. By far the best lowering system I've used on any car! The Ebay seller MBCANSOLUTIONS created a very good product and he said that he has plans to make it even more customizable in the future!
#79
Originally Posted by orenlasko
e63 wheels. Also what are your settings? It looks great...
#81
Sure fooled me lol
ive got an e63 ans they look EXACTLY the same
#82
Has anyone tried Lomo1:
http://loweringmodule.com/mercedes/e.../new-category/
i just got it for MY17 S63, but αm trawling so haven’t had α chance to get it install.
The best part for me is that you can do the adjustment right on your steering wheel without α tablet and all 4 corners can be adjusted independently.
#83
https://youtu.be/ggKdosI9A5Y
#84
https://youtu.be/
https://youtu.be/
#85
The rip-off from Renntech is that they link the module to the car permanently without any way to move it to another car. People change cars all the time, sometimes even after just a few months. So it's just a brick for any other car.
Plus the programming of the Ebay module is more advanced than the Renntech one.
The only difference I believe is that the Renntech module raises the car at speed to stock height (adjustable) while the Ebay one works more like links. So an alignment may be needed for Ebay one...
#87
Mine does not... at least as far as I can tell or have been told. As I understand it, his module overrides the car's definition of what the default ride height is so any change the car decides to make after using the module will be relative to that, e.g. the "raise your vehicle" doesn't raise it as high as it did before. I'll add, though, that this is my best interpretation based on observation, it's possible I missed something (since I'm in the car and don't get to see it raising itself at 80mph).
#88
Super Moderator
Received 3,171 Likes
At this point it literally makes no sense to purchase the Renntech.
#89
Super Moderator
#90
#96
Yes sir!
I ordered 3/4 of the Vic55 Special from Supreme... I had a set of 15mm HR spacers from my GTS that fit so I only ordered the 12mm and 4 sets of bolts lol.
Im gonna get a bit dirty and fit everything this weekend.
#97
Administrator
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
I have a long time friend who was an AMG tech who opened his own store by my house and is a sponsor here. He can lower the car by just going underneath and tweaking a few things which is where Im at now. But I kinda like the ebay module cause I want to drop the car a bit more and then see how its plus I want the option to really adjust it for conditions. Having my buddy do this would not make sense. Buying the Renntech would not make sense either.
As for spacers, I run 15mm fronts and 12mm rears via Supreme Power (sponsor here) in Fullerton CA.
Edit: to be clear, there are sensors underneath that set ride height, these are easy to manipulate but getting the right height when setting the car down is the art. Benzworks is my go to here in CA and they were able to lower my car in about 45 min for a nominal cost (no hardware no software) but I still am getting the module cause as I said, I need to drop it more but with the option to bump up quickly.
#98
Administrator
Nice brother, I dont think you will get too dirty as the spacers are plug and play. Smart move on the bolts as the GTS ones from H&R wont work with our hubs out front.
#99
Thanks!
