handheld lowering module
#126
Lowered my family hauler (GL450) today with the same MBCANSOLUTIONS handheld module I used to lower my E43 in my previous post. The results were equally as good! I went pretty conservative at F: 1 3/4" R: 2" as to preserve ride quality. Although, I must say that the overall look has completely changed, especially because you don't see a lot of these lowered! (note: this is a separate handheld module then my E43, each module can only be used for one car.)
#127
Just got mine ... quick clarification so I don't mess it up.
Which is the correct sequence:
1. Start car > leave in Comfort > plug it in > set custom
2. Start car > put in Sport + > plug it in > set custom
3. Plug it in > start car > leave in Comfort > set custom
4. Plug it in > start car > put in Sport+ > set custom
#129
If it's the eBay one, the drive modes don't affect how you program the car. This module changes the car's default height value. The various drive modes that would have lowered the car say an extra 5mm, e.g. Race Mode, will continue to lower it but they'll do so relative to the new default height. The same is true when raising the car manually using the "raise" button. i.e. it will be raised 10 or 15mm... whatever the height increase is as set by AMG.
Installation instructions are here: https://www.ebay.com/itm/282847463816
#131
Administrator
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
Which one did you get, the Renntech or eBay one?
#134
His module allows you to adjust and set the new default position (i.e. position +/- 0) but I'm not clear how yours was lowered, was it purely software or something else?
#135
Super Moderator
Received 3,320 Likes
If you wanted to drop just a bit, you could do just 4-5mm via custom to drop to 32-33mm. I am not sure if you can enter a opposing number in the modules custom setting. If yes, you could raise the car a bit. Lets say minus 5mm would give you a 23mm effective drop.
Vic55 (04-10-2018)
#136
Super Moderator
#137
Administrator
You are lowered via manual sensor adjustment. Airmatic (and the ebay module) considers your car stock height, yet you are down 28mm. If you use the modules default drop, your total drop would be 60mm total, so that wouldn’t work.
#138
For anyone that wants clear answers it's really easy to message the guy via eBay. He answers super quick usually and he's a nice guy.
He can also ask for your VIN number and tell you whether the module will work for your car or not.
#139
Super Moderator
This is as far as I want to go with snow tires and bad weather. We still had snow over the weekend
#140
#144
I'm on a slightly backwards rake by the number s as well although the car doesn't look it. Mine is -20MM rear and -15MM front.Attachment 416192
#145
Originally Posted by Ariesfamous
Wow that looks good .
#146
LOL just put one together and charge twice as much on this forum. Like the exact same rear wings you can buy from ebay for half of the price!
#147
#148
Super Moderator
