handheld lowering module
#101
Ok so I'm prolly going to buy this.
Just want to confirm how it works cause I don't even know how the oem air ride works.
I don't even know what the ride height button on the left does. #neverreadastinkingmanualandimnotabouttostartnow
Is it is from the factory, is it just a speed related thing or does the ride height differ depending on which driving mode one is in?
For example does the ride height adjust depending if one is in Comfort or Sport+ mode?
And if I understand correctly the module sets the desired ride heigh and the car still adjusts from that new baseline ... it does not set the new ride height and leaves it there no matter what. Do I have this right?
#102
Administrator
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
#103
#104
I used it again earlier to lower the car another 8mm. Sure enough, plugged it in, navigated the UX using the COMAND display and touch controller, started the engine and down she went. He's asking only $399... it's worth it.
https://m.ebay.com/itm/MERCEDES-BENZ...16?_mwBanner=1
#105
The Renntech module is obviously functional but, to my mind, it's quite literally daylight robbery. The cost of that OBD II dongle is probably in the order of 10s of dollars or less. Granted, there's an unknown element of R&D but still. The equivalent available from the guy on Ebay works perfectly at 1/4 the cost.
#106
Very! The first module he sent me had some glitches but, credit where credit is due, he tried at my convenience for hours to resolve the issue--we eventually made it work but he wasn't happy with the service and insisted that my money be refunded. I somewhat reluctantly accepted and acknowledged his commitment to a quality product by letting him know he can use my car as a guinea pig once he's identified a fix. Sure enough, 2 weeks or so later he contacted me to let me know he's shipped a new module with the fix at no cost. I pinged him when I got it, we went though various tests to help assure him it was now functional and it worked every single time. He still asked for no money but, he's a young engineer with a well-oriented moral compass and I now had a product worth paying for... so I insisted I pay and he accepted.
#108
Audi R8, Alfa Romeo Quad, 991tt,cls550, 997tt, 85 Carrera
So the new lower setting from the module is going to be the baseline- got that. So when you hit the raise car button on the left side, how much height is raised- 10mm?
#109
Worth asking... ugh, now I'm concerned my positive intentions are going to put the kid out of business. I doubt he can update the module you already have so it'll need to be a new one.
#110
Not looking for anything for free but mine was problematic from the beginning. Read my comments from when I received it originally.
#112
I just spoke this him to suggest that he chime in. He asked me to let any of you that have his rev 1 unit that's not working to simply contact him via eBay and he'll replace it for free.
#113
Originally Posted by limeypride
For me, the original device worked twice out of perhaps 100 attempts. The issue was getting the COMAND display to present itself at all, once it did, everything was fine. The new units work every time.
#114
#115
Mine is on its way ...
I think the way I'll set it up is obviously leave the factory and low settings alone, and set the custom to as low as possible.
The reasoning is that the only time I use the custom setting is when parked.
So with that in mind ... what is the lowest setting? And presumably if the car can't go that low it will just stop when it can't go any further down and stay there.
For those that are buying it he will accept $375 offers ... I don't know if he'll take less than that.
#116
GLC43, GTI, X3, Mazda3
limeypride (04-06-2018)
#117
My Individual or Comfort suspension (they're the same):
This is in Race:
This is raised with the button:
#118
I've not tested that. I only lowered it to my tastes, -22mm to begin with then to -28mm which is where she resides today--quite a bit bumpier on rough roads than -22mm. Raising the car (with the button I mean) raises it a lot to clear nasty pot-holes or car parks with steep exits/entrances.
This is in Race:
This is in Race:
#119
I don't understand, what looks very doable? It's definitely doable since you're looking at a photo of it '"doable'd" .
tonymiabmw (04-07-2018)
#120
I meant doable, drive wise. Should have said driveable lol. The comfort setting looks like more than enough to clear most steep driveways and parking lots without stressin. I’ve had much lower cars without scraping problems.
#121
As I'm sure you probably know, it's more about remaining suspension travel--the visual appearance is deceiving but, at this new ride height of -28mm, it's more sensitive than even my RS7 was and that had very little remaining travel since it was lowered using KW HAS springs atop Audi's DRC. So far, the AMG is livable, though... we'll see.
#122
Ohhhhhhhhhh, got it
#123
#125
Good question. Yes, there was but it wasn't unbearable... and I guess it makes sense that the ride gets progressively worse the lower you go... but the aesthetics... oh, it looks soooo good! It's all subjective but the stock drop was ridiculous; 22mm improved it no end but, after a week, it still wasn't where I wanted it to be (I'm probably contrasting it against my RS7) so I arbitrarily chose 6mm more. I like the look now but I'm paying a price in ride quality.
The following 2 users liked this post by limeypride:
BC-2 (04-06-2018),
