Standing Burnout
If something works out I will let you know
Took some video which I may upload later, but I was also unable to get drift mode to burnout from a stop.
At anything over about 5 to 7 mph they start to spin pretty easily, though I didn't do any big smokey burnouts, instead I let up as soon as the tires started to spin.
I had my car on the dyno a month or so ago, and had a bunch of faults when I left. Everything went away after jumping on the freeway for a few minutes however.
Made 561hp/578tq on a dynojet in case anyone is wondering
If you google w213 service menu, you will find a guide how to get to menu with it... you shouldn’t really use it for road.
P.s. still trying to figure out how to burnout.. some people say you have to bypass certain gear ?!?!
561 whp, is your car 2017 production year?
it’s a mode that made specifically for dyno measurement. It switches off all secure systems such as abs, 4matic, differential.
I was happy with the number, probably would have made a bit more but they only had a couple fans on the front end for the radiator, and not much going to the intercoolers.
I'll also check to see if it can do a brake stand burnout as well
But open your drivers door and read the 4 digits on the jam sticker denoted like this (xx/xx) and you will see. My car is 02/17 and it puts up similar numbers on a mustang load bearing dyno.
However, from anything over a few miles an hour the tires will light up just fine. Just for fun today I popped it in drift mode and rolled on the juice as I was turning slightly in a parking lot. Was moving maybe 5 MPH. The tires immediately spun and the car went sideways remarkably fast.
