New Dashboard Icon showed up
Sadly, the 4 cylinder mode does not activate reliably when cruise control is engaged, same for coasting mode.
Make sure that the "start/stop" system is "on" while you are in comfy mode and transmission is in "D" - not manual. Then go to a freeway (or any roads that you can drive 35mph and over) with a slight downhill and push your acceleration pedal not too hard but let it go faster sharply than release the gas pedal and it should go into "sailboat" mode. Also, you should not have anyone ahead of your car because distronic is checking road and if there is any car ahead too close will not allow to "slide". Also, do not touch the brake.
This matches what my book states. It's actually kind of odd because the kind of driver who really cares about mileage (I'm thinking about my wife) never reads the manual (I'm thinking about my wife) and would never discover the kind of arcane setting. The reason it's so hard to get to is that on all other models, even the E53, there's an E mode that enables coasting (Sailboat). When they did away with E on the E63 they obviously forgot that they orphaned coast mode. The I-set-like-C hack is what a typical programmer would dream up.
If people really see Sailboat in C, it must be a function of a different version of management coding. But on mine, it won't coast in C.
Every morning while I'm doing my commute on the freeway to the work I'm driving in "C" mode and almost 1/2 of the way I'm driving in "Sailboat" mode cause driving down from the hill in the toll lane. btw I've never tried to launch sailboat mode in any different modes besides "C".
Have no idea what's broken in your car.
It's also pretty neat how it's smart about not coasting on a down grade that's steep enough to need engine braking. I live on a mountain road and don't see the sailboat when heading down. It only coasts on gentle slopes or flat roads. But it most definitely does it consistently in I and not in C.
