Seeing a lot of check engine light (2k+/- miles) on market
I’ve been seeing a lot of lower priced 2018 models with around 2-4k miles with this on their CarFax reports. I’ve found 3 of these within a week. They usually go for $5,000 under the normal ($89,000-$90,000). $95,000-$100,000 being average price. $110,000 - $115,000 for the edition 1’s with lower mileage.
Now I know this is something I should stay away from but I was just curious if this was common and what is it? Because this could still happen to any vehicle..
P.S. Any other buyer tips appreciated
I had the CEL for the 1, 6 misfire. After a couple of service visits the car has been fine for several months, but we'll see after I start burning some more summer gas. Reportedly the fix has been released to dealers and actually improved fuel economy - though I wonder if performance has been dialed back at all as part of it.
That happened to me on a 2003 Ford F-250 with 6.0 l diesel. They were having sticking injectors and modified the firing impulses to prevent the problem. As a result the power was dialed way back. They also eliminated the pilot injection fuel shot that helps start combustion and makes the motor quieter and less clanky. Following the fix I had to start turning off the truck going through drive throughs like Starbucks.
My feeling was that the 1, 6 misfire was not a hardware issue and one of the diagnostic / smog monitor settings being dialed down too tight and triggering on some edge cases. In my case they swapped around injectors and recalibrated them, likely rearranging the stackup of tolerances for each cylinder and dropping it below the alarm trigger. Likely MB looked at the diagnostic log info from a bunch of cars that were exhibiting the problem and were able to make a firmware change to work around the issue and stay compliant with smog limits.
Now that the fix is out, would I purchase a buy back car that was reacquired due to this problem, yes absolutely.
Happens more than you think. Carfax has started making this an little harder to completely hide but it's been happening for decades
I see a number of lower-priced cars with early MY 2018 build dates (often in 2017) with not-good things like "spark plugs replaced" early in their lives, and then scary things like "engine compression checked" and "transmission removed and replaced"... One sales guy tried to buffalo me with "it's an AMG car, of course they're going to check the compression!"
Uh, buddy. No.
I'm very hesitant to jump on one of these cars - even CPO, even significantly less expensive than many others - due to these reports.
Anyone have any thoughts as to these early car issues being functionally resolved, or are there manufacturing defects or design flaws somewhere in the early production cars that are causing these issues?
Uh, buddy. No.
I know I enjoy mine and I don't see anything close to replace it.
