E63 Order Cermaic brakes!?
Curious to how often and how much ($) the steel brakes are costing you guys vs how long until carbons need to be changed.
The only reason I would not get them. 10 THOUSAND and I know they get loud if you don’t seat them once a week.
My car car is the same spec as the one attached.
I think rotors will be good for at least 2 pad replaces.
Here are part numbers:
How many miles are you at / how hard do you drive that you need rotors replaced? How many miles do your front / rear pads last you?
I did not replace my brakes, they are more than 70% left. My car is daily and slightly over 13k miles right now.
I can't say I'm crazy driver, sometimes I can run 150mph but nothing serious
Another advantage is less unsprung weight. Not sure exactly how much the difference is, but it's right at the wheel, so perhaps a slightly improved ride as a result.
There's no brake dust
I wash my own car and continue to be amazed that there's really no work needed on the wheels, just rinse and they're done.
I wash my own car and continue to be amazed that there's really no work needed on the wheels, just rinse and they're done.Another advantage is less unsprung weight. Not sure exactly how much the difference is, but it's right at the wheel, so perhaps a slightly improved ride as a result.
I wash my own car and continue to be amazed that there's really no work needed on the wheels, just rinse and they're done.Trending Topics
If you are not going to drive your car as it can run you simply don't need CCB in a different way you will need to change rotors and pads in those intervals as I said
I wanted to get CCB tho, to avoid brake dust but after deep search - not worth it. Steel brakes are amazing on w213 and only one point you will want to get CCB - no dust. I don't care to wash my wheels once per week if I'll save $14k (if you are swapping CCB and not getting them with a car).
My personal recommendation would would be to get the CCB especially if you want black wheels. If $10k is a bit much to swallow and it is for most of us, really consider silver wheels.
It may not be relevant to you when buying a new or slighty used car, but one should be aware of the impact on second hand value when ceramic brakes wears out, 6-8 years down the road.
/J
/J
If you set up the wagon it will be your new canyon carver and without a doubt surpass your 911 in the twisties. I don't miss my 991 Turbo S at all.
Get the CCB's for your 4,700 lb rocket lead sled..No squeaks at all no matter how long it sits.
/J
But... they are delicate, so if you chip one of the discs taking the wheel off.. you are screwed.
I have them on my Porsche Turbo and at 20K they show absolutely no wear on the pads... Porsche says the discs can last to 180K.
