19 E63 AMGs Wagon - at idle sounds like a knocking sound
Old Jun 18, 2019 | 07:13 PM
northern2020's Avatar
S4
Greetings
At dealership just finished up with 1st service and tech just identified at cold startup a knocking sound that disappears when engine warm.
Incidentally yesterday I also noticed in race mode, a metallic tin sound when car was gearing down from engine bay.
any insight appreciated !
Old Jun 18, 2019 | 07:24 PM
PeterUbers's Avatar
And did he pull any codes? Does he think it's bad gas? Bad plugs?
Old Jun 18, 2019 | 07:28 PM
S4
No codes / no misfires
Old Jun 18, 2019 | 07:32 PM
S4
Sounds like a Diesel engine
Carac's Avatar
2018 E63S Wagon
Sometimes there's a tick from my exhaust at startup that goes away pretty quickly when warm. Not all the time, just occasionally.
Old Jun 19, 2019 | 02:03 PM
S4
From Tech : "normal engine noise when car is cold, noise caused by an exhaust gas after treatment function which intermittently causes the engine to run more roughly. Noise comes from the two-mass flywheel"
Old Jul 16, 2019 | 12:17 PM
antoniorb's Avatar
AMG E63 W213
it's the flywheel. go change it. every E63 in my town had this, even ours.
Old Jul 16, 2019 | 12:28 PM
S4
Did you replace it and did they have to drop the engine to do it?
Old Jul 16, 2019 | 01:01 PM
antoniorb's Avatar
AMG E63 W213
replaced it.
didnt drop the engine, did it from underneath.
antoniorb's Avatar
AMG E63 W213
replaced it.
done under warranty by the way.
Old Jul 17, 2019 | 02:11 PM
amgliturbo's Avatar
AMG E63s
My 2019 E63s (purchased in March) from the day I 1st got it, has a popping/knocking sound while idling until it warms up. I was at my local MB dealership 2 weeks ago to have a new tire installed due to a screw puncture -- they had just received a new E63s that was out front. I asked the service person cleaning the car if it made the same popping sound as.mine. He started it and it too made the same noise as mine.. He said it had something to do with the initial timing of the engine and that the noise had something to do with a valve related to the exhaust-- that it was normal. A few days later I was at a Lotus dealership and a guy pulls in with a E63s--he too said he had the noise and he was told by his dealership that it was normal. Not that long ago I recall someone else noted the issue in a thread on this forum.
Old Jul 17, 2019 | 02:33 PM
amgliturbo's Avatar
AMG E63s
Is the flywheel issue a mechanical problem that will result in failure or bad for the engine in some way or is it just that the sound is an annoyance?
Old Jul 17, 2019 | 03:22 PM
Agent-A01's Avatar
05 W211 E500, 03 C215 CL55 AMG
Annoyance more than anything.
Old Feb 19, 2023 | 06:00 AM
EndlessAuto's Avatar
E coupe
nope. Absolutely nothing to do with flywheel.
Purge valve. And normal noise.
