E-Series Burmester Audio problems (systemic?)
There are conditions where the speakers sound like they are blown -- more specifically, it sounds like the audio is getting clipped and distorted, however it will happen with the volume set just one notch up from muted, so it is not a volume issue (I normally listen at low volumes anyway).
I've been able to come up with a simple reproduction using 'Cottage in Wales' by Sam Eber, which is conveniently on youtube:
https://www.youtube.com/watch?v=S0246wNCvus&t=100
The problem is not mechanical vibration in the door/speakers/grille/etc.
If you disable the "automatic volume compensation", the problem decreases, but still exists, but local dealership seems to see this as a 'fix'.
The problem happens via carplay+iphone.
The problem happens via android auto+android.
The problem happens via android and iphone connected to bluetooth.
The problem does *NOT* happen via iphone in USB mode (decline carplay, it'll enter ipod mode from the car's perspective).
I suspect the problem does not happen with android in the same setup (i.e., with android auto disabled).. I have simply yet to try.
The problem does *NOT* happen via SD card playback (mp3 of the sample song was used for this test; unknown bitrate).. but then we're back to "no gapless playback".
The problem is not gain set on the iphone or android.
The problem is not the track in question being demo'd from youtube, or even the original recording.
The problem is not just one song -- that's just a good reproducible case.
The problem is not gain set in comand/audio -> that's all set to 0.
The problem is not specific to "surround on" or "off" -- happens in both conditions.
The problem is not isolated to any single speaker or group of speakers.
The problem also happens on a new-in-showroom E series sedan, but I was unable to test it on one with the '3d audio' upgrade.
The vehicle has all the latest software updates as of 2 weeks ago to try to remediate this, unsuccessfully.
I believe the problem is with the DAC/Amp/whatever the burmester uses and applies to certain input sources and not to others.
The standard workarounds I would use such as line-in (not available!@#!@), USB or SD card playback (no gapless audio support) are not viable, unfortunately.
I welcome any feedback on suggested resolutions. I have an open issue with my dealer on this.. I've requested they escalate it for awareness and, hopefully, a resolution. Unfortunately, I have found references back to 2015 for what seems to be this same issue.
-j
I appreciate the response, however. All previous findings of this issue seem to terminate there, which... is not a solution in my book. The automatic volume compensation is also supposed to normalize audio across sources -- that's important when listening to say, classical via BT/wired that may have a low volume for many of the parts, which results in turning the system up to say, mid-point. ... And that's just fine until you disconnect the phone, it jumps back to XM radio, and blasts your ears off.
-j
-j
trust me when i say, i’m picky too
but i wonder if mercedes, the dealer, and the majority of the world collectively just kind of want you to accept the fact that, it isn’t a major deal?
i’m sure you can find things wrong in every infotainment system, forever.
-j
I have recently bought a 2020 E63 wagon. I am hearing an ugly distortion in the Burmester stereo. I wondered if you had any success getting rid of it? I really hear it on CarPlay and bluetooth audio. I do not hear it on SD card or radio. Please let me know where you got to in your search for answers,
Best
Noah
Best
Noah
For CarPlay, assuming IOS still lets you, try this: disable carplay completely then connect your iphone. That should be "ipod mode" of sorts. I don't think that description is used anymore... when I tried that, I was able to get good audio through the USB connection without CarPlay enabled. That was a test point that makes me think it is software.
It's also not just CarPlay -- the same experience existed for me with Android/Auto -- on, noise, off, no noise.
As minor as it may sound to some, this is the most disappointing thing about my E63 as it shows up in almost every conference call I take while in the car. -- It's also NOT volume dependent. Certain audio will distort at the lowest of volumes I can readily discern and it isn't the source material.
If anyone has the proper gear and time, it might be interesting to send audio through an FFT analyzer out to the car, with another microphone setup to analyze the resulting output. I expect it's artificially clipping in software well before the physical components limits are hit.
I don't know how to get this resolved -- I was unable to test it on an S class or an E63S with the upgraded audio system as none were available at my local dealers at the time.
thank you,
Jason
It's the #1 thing I'm disappointed with in my first merc -- it's the only thing I'm disappointed with in my wagon. Is that major? Dunno.
-j
thank you,
Jason
I would expect a huge difference just from the change in the acoustic environment between the reference room and the interior of the car. But, any really weird additive hums or other distortions generated by the car's sound system may jump out.
